PeopleSoft Application Fundamentals
The PeopleSoft Supply Chain Management Integration PeopleBook provides you with implementation and processing information for the PeopleSoft system. However, additional, essential information describing the setup and design of the system resides in companion documentation. The companion documentation consists of important topics that apply to many or all of Oracle's PeopleSoft applications across the Financials, Enterprise Service Automation, and Supply Chain Management product lines. You should be familiar with the contents of these PeopleBooks.
The following companion PeopleBooks apply specifically to the PeopleSoft Supply Chain Management Integration PeopleBook.
PeopleSoft Applications Fundamentals PeopleBook
PeopleTools PeopleBook: Integration Broker
PeopleSoft Components PeopleBook
