Navigating PeopleSoft SCM Integration Documentation
If you are using integration with the PeopleSoft Supply Chain Management (SCM) applications, please refer to this topic to find the information you need.
PeopleSoft SCM provides powerful integration technology. You can integrate with specific application suppliers or share transaction or definitional data directly with suppliers or customers.
Oracle has information organized for functional users and technical implementers on how to set up and use enterprise integration points (EIPs) in PeopleSoft Supply Chain Management.
Integration Information Flow
When you're learning about EIPs, it is suggested that you follow the following order of information:
Step Documentation Type of Information Primary Audience
Learning what EIPs are delivered with your application.
Application documentations
Functional descriptions of EIPs
Power users and managers
A high level understanding of the EIP architecture, and the types of technologies for which SCM delivers EIPs.
PeopleSoft Supply Chain Management Integration
EIP overview information
Descriptions of EIP groups integrating to specific technologies (warehouse management systems, electronic data collection, and so forth)
How to set up EIPs and understand the delivered design patterns.
PeopleSoft : Enterprise Components
EIP setup information
Design pattern descriptions
Functional and technical implementers
Mapping EIP data
Interactive Services Repository
Technical details for each EIP
Creating or customizing EIPs
PeopleTools: Integration Broker
Information on using this technology to create your own EIPs
Power Users and Managers
If you are looking for information on which EIPs to use and what they can do for you, you can find overview information as follows.
Area Location
Overview of EIPs and integration technology
See PeopleSoft SCM Inbound EIPs.
Functional description of individual EIPs.
The respective application documentation.
EDI information
See PeopleSoft Electronic Data Interchange: PeopleSoft Electronic Data Interchange.
Warehouse Management Systems information
See General WMS Integration Issues.
Healthcare application information
Electronic data collection information
See Understanding Electronic Data Collection.
Sales and Use Tax information
See Understanding PeopleSoft Business Interlinks to Taxware Sales and Use Tax.
Transportation Management information
See Understanding the Transportation Management System Integration with PeopleSoft Inventory.
Functional and Technical Implementers
Resources for technical information are in the Enterprise Integration section of the PeopleSoft: Enterprise Components, PeopleTools: Integration Broker and the Interactive Services Repository. There are also specific overview sections and examples in the PeopleSoft Supply Chain Management Integration
Area Location
See Setting Up Service Operations.
Chunking information
See Setting Up Chunking.
EIP processing Information
See Processing Inbound EIPs.
See Processing Outbound EIPs.
Inbound error handling
General technical information
For technical details about individual EIPs, use the Interactive Services Repository (ISR) in the My Oracle Support website located at https://support.oracle.com/CSP/ui/flash.html.
Inbound EIP (subscribe) specific information
See Understanding This Troubleshooting.
Outbound EIP (publish) specific information
See .Understanding This Troubleshooting
