Processing Backbone Interlinks
This section discusses how to run the Backbone Interlink process.
Page Used to Process Backbone Interlinks
BankBone InterlinX - Process Request Page
SAC_BBIX_RUN_CNTL
Initiates transferring data from one PeopleSoft database to another.
Use the BankBone InterlinX - Process Request page (SAC_BBIX_RUN_CNTL) to initiates transferring data from one PeopleSoft database to another.
Navigation:
SCM Integrations, and then BackBone InterlinX, and then Run BBIX Process, and then BankBone InterlinX - Process Request
Field or Control Description
Override
Select this check box to override the integration's default filter with a custom filter to use when processing the integration. Once selected, the system makes the Filter field available for entry.
