Setting Up PeopleSoft Installation Options for Vertex Q Series
The Set Up Financials/Supply
Chain, Install, Tax Provider Installation page provides one option
for Vertex Q Series: Using TDM. Although
PeopleSoft applications as delivered do not currently support this
option, it is included in case you want to configure it to work with
your business processes. Set up the Using TDM (using
Tax Decision Maker) option in your Vertex environment settings. Use
of TDM is set up in the Vertex registry on a Windows NT platform and
in PSVTXCFG.SH on a UNIX platform.
To display options for Vertex Q Series, Vertex must be chosen as the Tax Supplier on the Overall Installation Options page and Vertex Q Series as the Vertex Tax Application on the Tax Provider Installation page.
