Setting Up Vertex on a UNIX Platform
Vertex provides a configuration
file called PSVTXCFG that contains similar entries to the ones in a Microsoft Windows
registry. This file must be accessible to the Vertex-supplied shared
libraries. Define an environment variable called PSVTXCFG in psconfig.sh, and
assign it the location of the configuration file. Define the variable
for both the application server and PeopleSoft Process Scheduler so
that the variable can be used by the Vertex software.
