Setting Up the UCC/EAN Manufacturer ID
To identify a manufacturer ID and starting container number, use the UCC/EAN Manufacturer component. You need to specify the manufacturer ID and starting container number for the label printing application in order to create a standard bar code accessible to all companies in the trading chain.
This section discusses how to specify the manufacturing ID.
Pages Used to Set Up the UCC/EAN Manufacturer ID
UCC/EAN Manufacturer ID Page
BCT_MFGID_SETUP
Specify the manufacturer ID and starting container number.
Use the UCC/EAN Manufacturer ID page (BCT_MFGID_SETUP) to specify the manufacturer ID and starting container number.
Navigation:
SCM Integrations, and then Barcode Labels, and then Setup UCC and EAN Mfg ID, and then UCC/EAN Manufacturer ID
Field or Control Description
Manufacturer ID
Enter an ID that is included in the extract file for the shipping container labels so that it can be formatted by the label printing software to create an industry-standard bar code label.
Shipping Container Serial ID
Enter an ID to uniquely identify the shipping container. Enter the starting container number, with up to nine digits, or leave it blank to start at 1. The shipping container serial ID is included in the extract file for the shipping container labels so that it can be formatted by the label printing software to create an industry-standard bar code label.
