Common Elements Used to Review Production Control Post Errors
| Field or Control | Description |
Production ID |
The system displays the production ID or production schedule associated with the update or the error. If the message or update is pertaining to a new order for a production schedule then Schedule will appear in this field. |
Click the Item Search button located next to the Item ID field to access a transfer page of item-related links. On the transfer page, click the Item Search link to search for items using the Item Search Criteria page. Note: Link options on transfer pages vary depending on the component and the item with which you are working. Note: Only items with a status of Active or Discontinue are valid. |
