Reviewing Production Control Post Errors
This topic discusses how to review Production Control Post Errors
Pages Used to Review Production Control Post Errors
| Page Name | Definition Name | Usage |
PL_PROD_EXCPT_SRCH |
Define the search criteria for the production control post errors that you want to review. |
PL_PROD_EXCEPT_SPL |
View the production control errors that occurred from the Post Updates process. |
Review Production Post Errors - Search Page
Use the Review Production Post Errors - Search page (PL_PROD_EXCPT_SRCH) to define the search criteria for the production control post errors that you want to review.
Navigation:
Select the search criteria for the production post errors that you want to view. Select a unit or plan unit group; order type, and at least one error type.
Error Type
| Field or Control | Description |
Cancel/Delete/Closed |
Select this check box to view cancellation, deletion, and closure errors that occurred in PeopleSoft Production Management and are associated with the search criteria that you selected. |
Calendar Violation |
Select this check box to view errors pertaining to calendar violations—order dates that are not valid for the manufacturing calendar or a five day work week—associated with the search criteria that you selected. |
No Production Area |
Select this check box to view errors pertaining to no production area—the item on the order does not have a valid production area—associated with the search criteria that you selected. |
Order Changed |
Select this check box to view order change errors associated with the search criteria that you selected. The order in PeopleSoft Production Management changes after being loaded into PeopleSoft Supply Planning. |
Pick Plan Generated |
Select this check box to view pick plan errors associated with the search criteria that you selected. The pick plan has already been generated for the order; therefore, you cannot apply changes. |
Tolerance |
Select this check box to view tolerance errors that are associated with the search criteria that you selected. When you run the Post Updates process, you can decide how the system should handle the updates pertaining to the reschedule of orders that are within tolerance. One option is to post an error if the reschedule update is invalid. See Posting PeopleSoft Supply Planning Updates to the Transaction System. |
Illegal Substitution |
Select this check box to view illegal substitution errors associated with the search criteria that you selected. The component substitute does not appear on the bill of materials as a valid substitute. |
No Routing |
Select this check box to view no routing errors associated with the search criteria that you selected. The production operation does not exist on the routing for the item on the order. |
Previously Converted |
Select this check box to view previously converted errors that are associated with the search criteria that you selected. These type of errors occur if, for example, a planned production order is created but not applied before it is brought back into PeopleSoft Supply Planning. The next time that you run the Post Updates process, the planned production order may have already been converted into an actual production order from the last run. This may cause a doubling of the orders in the system. |
Open Pegs |
Select to include updates to orders that are pegged to unfulfilled demand. |
Quantity Change |
Select to view quantity change errors associated with the search criteria that you selected. The system changes the production order status to In Process. Quantity change for production orders with a status of In Process are flagged as error. |
Review Production Post Errors - Production Errors Page
Use the Review Production Post Errors - Production Errors page (PL_PROD_EXCEPT_SPL) to view the production control errors that occurred from the Post Updates process.
Navigation:
When this page initially appears, it includes all of the post errors that meet the selection criteria. You can view more information pertaining to the error by selecting the different tabs— Details, Quantity, Dates, Inventory Pegging, and Substitution.
Message Text |
Displays error message text associated with each post error. Messages are:
