Posting PeopleSoft Supply Planning Updates to the Transaction System
After you create a workable plan in PeopleSoft Supply Planning, create the recommendations into the PeopleSoft transactional system using the Post Updates process. There, the recommendations are distributed into the various components as planning updates, where you can review them. You can also select to have updates automatically approved, where applicable.
Page Used to Run the Post Updates Process
| Page Name | Definition Name | Usage |
PL_POST_REQ |
Extract new orders and changes to existing orders from the planning instance. Validate and stage orders for application to the transaction system. |
Understanding the Post Updates Process
The Post Updates process enables you to generate PeopleSoft Supply Planning updates for PeopleSoft Order Management, Inventory, Production Management, and Purchasing.
The Post Updates process performs these steps for the specified run control:
Locks the business unit for posting planning updates, as indicated by the business unit group associated with the planning instance.
Two posts cannot run concurrently for the same business unit and data type. If the business unit is locked by another process, the system displays an error in the message log.
Calculates the item horizons.
Processes all of the selected data types.
For each data type, the process:
Selects data for processing.
Initializes the staging and exception tables.
Validates changes.
Approves valid orders.
Updates staging and exception tables.
Unlocks the planning instance data type.
Multi-Process Post Update
You can post updates using the Post Updates process (PL_POST) or using the Plan Multi-Process Post job (PL_POSTM), which separates the Post Updates process into several child processes to enable concurrency. Multi-process post updates enables you to use multi-CPU servers or schedule child processes to occur on different servers.
PeopleSoft Supply Planning uses JobSet functionality to enable you to schedule a combination of serial and parallel jobs. When you select the Multi-Process Post Update job on the PeopleSoft Process Scheduler page, the system schedules the processes to run serially or parallel, as needed. If a process fails, the system determines which, if any, subsequent processes it should run. For example, if the Multi-Process Post Update Start process (PL_POST_MPS) process fails, the system does not run subsequent processes. However, if the Post Production Updates process (PL_POST_PR) fails, the system still runs the Post Sales Order Updates process (PL_POST_SO), as the remaining processes in the Multi-Process Post Update job can run independently of the others. If any single process fails, you can correct the situation, then rerun the Post Updates process for the corrected section.
Calculating Item Horizons
The process calculates these item-specific horizons:
Planning Time Fence Date = Current Date + Planning Time Fence.
Action Message Cutoff Date = Current Date + Action Message Cutoff Fence.
Released Order Fence Date = Current Date + Released Order Fence.
Firmed Order Fence Date = Current Date + Firmed Order Fence.
Released and firmed dates are used with planned production only.
Selecting Data for Processing
The Post Updates Process considers these options when selecting data for processing:
| Term | Definition |
Planned Order Status |
Planned orders must have a status of Planned or Firmed. Canceled planned POs are posted for supplier scheduled items, if the orders were previously posted to the transaction system. Actual orders are not subject to this validation. |
Actual Order Change |
The Post Updates process selects only actual orders that have changed. The process compares the planning instance order against the actual order in the transaction system and selects only those orders where changes occurred. Planned orders are not subject to this restriction. |
Action Message Cutoff Date |
If you did not select the Ignore Cutoff option on the Post Updates page, the process selects only those records where the planning-suggested due date or actual due order date are less than or equal to the item's action message cutoff date. Planned orders do not have an actual order due date. |
Initializing Staging and Exception Tables
The Post Updates process deletes records from the staging and exception tables based on the initialization options. If you selected All by Selected Planned By in the Items field on the Post Updates page, the process deletes all of the records if you also selected All Data Types in the Types field, or if you selected Posted Data Types in the Types field and the corresponding order types were selected for processing. The process deletes records for only those items matching the Planned By option criteria that you selected on the Post Updates page.
If you selected Selected by Planning Instance in the Items field on the Post Updates page, the process deletes all of the records for items that it locates in the PL_BU_ITEMS table, if you also selected All Data Types in the Types field, or if you selected Posted Data Types in the Types field and the corresponding order types were selected for processing. The process deletes records for only those items matching the Planned By option criteria that you selected on the Post Updates page.
If you selected Selected by Planning Instance in the Items field on the Post Updates page and entered a business unit, the process deletes all of the records for items in the business unit that it locates in the PL_BU_ITEMS table.
Validating Changes
If the Post Updates process encounters an error while validating changes made in PeopleSoft Supply Planning, it writes the error to the Review Post Errors Inquiry for the data type. You must make the appropriate changes manually in the transaction system.
If an order date change is less than the item defined reschedule in or reschedule out range, use the Post Updates page to define how the Post Updates process handles the order date change. The Post Updates process can mark the change in error, approve the order automatically, ignore the order, or accept the order change through standard approval and validation.
This table lists the Post Updates process validation rules for order types:
| Order Type | Valid Changes | Exceptions |
Actual Purchases |
Planned Purchases |
Add a planned order. |
Planned order created in a prior planning instance has been converted to a PO. |
Actual Production |
Planned Production |
Actual Transfers |
Planned Transfers |
Add a planned order |
Planned order created in a prior planning instance has been converted to a transfer order. |
Sales Orders |
Change the scheduled ship date and time. |
Quotes |
Buying Agreement |
Change the requested ship date and time. |
Material Stock Request |
Updating Staging and Exception Tables
The Post Updates process inserts orders with errors into the appropriate exception table. These exceptions can be seen in the Review Post Errors Inquiry for the data type.
For valid planned orders, the process:
Updates the existing order if the order header exists in the staging table.
Staging tables can be seen in the Approve Updates Workbench for the data type.
Inserts the header and all of the valid children into the staging table if the order header did not exist in the staging table.
For valid actual orders, the process inserts the order into the staging table. For actual purchases, sales orders, quotes, buying agreements, the process inserts only one row per distinct schedule.
The Post Updates process assigns new records in the staging tables a sequence number from the INSTALLATION_PL table. Sequence numbers are reset to 1 after the process assigns the sequence number 999,999,999. The process reserves sequence numbers as blocks by counting the number of valid records, then updating the counter by the appropriate amount, noting the first and last order number reserved.
Projected Useup
For discontinued items, the Post Updates process publishes the last date that a supply or demand has occurred (the useup date) with the final inventory balance resulting from that change in inventory position (the useup quantity on hand).
Post Updates Page
Use the Post Updates page (PL_POST_REQ) to extract new orders and changes to existing orders from the planning instance.
Navigation:
Common Information
| Field or Control | Description |
Planned By |
Select any combination of distribution plan, material plan, or master plan items for posting. The selection determines what data is initialized and processed. |
Initialize Data Types |
Specify the data to include in the staging and exception tables after you run the Post Updates process. The data tables that you include are determined by the combination of values that you select in the Items and Types fields. When you run the Post Updates process for a planning instance, you send the transaction system a set of recommended changes to the supply plan (written to the staging tables), as well as those changes that cannot be implemented due to validation errors (written to the exception tables). Use the Items and Types fields to specify how to delete the data from the previous Post Updates process. In the Items field, indicate whether you want to delete all of the prior data or delete only the data for items in the planning instance. In the Types field, indicate whether you want delete all of the prior data or only the data types that you intend to add back. This table lists the valid combinations and the corresponding Post Updates process action: |
| Type Field Selection | Item Field Selection | Action |
All Data Types |
All by Selected Planned By |
Initializes all of the data tables for all of the items that you included in the Planned By option criteria. |
All Data Types |
Selected by Planning Instance |
Initializes all of the data tables that you included in the Planned By option criteria, but only for those items included within the corresponding planning instance. |
Posted Data Types |
Initializes all of the data tables selected for posting for all of the items that you included in the Planned By option criteria. |
Posted Data Types |
Initializes all of the data tables selected for posting that you included in the Planned By option criteria, but only for those items included within the corresponding planning instance. |
Planning Engine
The system restarts the planning engine at the end of the process so that links that show supply and demand appear on approval pages.
Pre-Post Auto-Shutdown |
Select to stop the planning engine before running the Load Planning Instance process. |
Post-Process Auto-Startup |
Select to start the planning engine after you run the Load Planning Instance process. |
URL (uniform resource locator) |
Specify the location of a planning server where you want to start the planning engine after the Load Planning Instance has finished. If you do not specify a URL here, the system uses the default URL. |
Select All |
Click to include all of the data types that appear in the Posting Options group box for processing. |
Clear All |
Click to exclude all of the data types that appear in the Posting Options group box for processing. |
Selection Criteria Tab
Select the Selection Criteria tab.
Select |
Select to include the corresponding data type in the Post Updates processing. |
Ignore Cutoff Fence |
Select to ignore the item's cutoff fence for the corresponding data type. If you do not select this option, the Post Updates process includes only changes and new orders that occurred prior to the calculated cutoff date. |
Inside Tolerance |
If an order date change is less than the item defined reschedule in or reschedule out range, define the action that the Post Updates process is to take. Values are:
Pegged Approval Option |
The Post Messages and Exceptions process will be updated with these options for approving changes to pegged orders:
Note: These options will only apply to orders that can be flagged as pegged. |
Validation Options Tab
Select the Validation Options tab.
Approval Options |
Specify whether the Post Updates process can approve changes automatically. Values are:
From Offset, To Offset and Based On |
Enter an offset from the current date for the horizon and indicate whether the horizon is based on the Start Date, End Date, or Both. These fields are available for entry only when you select Auto Approve Within Horizon in the Approval Options field. |
Approve Schedules |
Select if you want the Post Updates process to approve orders for supplier scheduled items automatically. If you define the corresponding Approval Option as automatic, but you do not select this option, the Post Updates process does not automatically approve supplier scheduled items. If you define the approval option as Manually Approve, the Post Updates process ignores this option. |
Allow Violation Approval |
Select if you want the Post Updates process to apply the corresponding Approval Option to planned production or transfer orders that have violations. If you want to exclude planned production or transfer orders with violations from the Post Updates approval process, you should run the Demand Violations Extract process prior to running the Post Updates process. The Demand Violations Extract process adds entries in the SPL_VIOLATIONS table for planned production and transfer orders that are pegged to a lower level supply order with a violation. |
Expedite Options |
Select an option for the Post Update process to consider. Additionally, this process also checks supplier lead times. If planned or changed purchase order messages are within the supplier lead time, the system marks the message Expedite and you define the expedite option using the Expedite Options column. Values include: Planning Time Fence: Select to have the system consider the planning time fence and flag planning messages to be expedited that are within the time fence. If a change has occurred to a purchase order within the planning time fence, the system marks that change message as expedite in the Post Updates process. supplier Lead Time: Select to have the system consider supplier lead times and flag planning messages to be expedited that are within the lead time. If a change has occurred to a purchase order within the supplier's lead time, the system marks that change message as expedite in the Post Updates process. |
