Reviewing PeopleSoft Order Management Post Errors
This topic lists a common element and discusses how to review PeopleSoft Order Management post errors.
Pages Used to Review PeopleSoft Order Management Post Errors
Review Post Errors - Search Page
PL_OM_EXCPT_SRCH
Define the search criteria for the PeopleSoft Order Management post errors that you want to review.
Review Post Errors - Sales Orders/Quotes Page
PL_SO_EXCEPTION
Review the PeopleSoft Order Management post errors that pertain to sales orders or quotes that occurred during the Post Updates process.
Review Post Errors - Buying Agreements Page
PL_BA_EXCEPTION
Review the PeopleSoft Order Management post errors that pertain to buying agreements that occurred during the Post Updates process.
Common Element Used in This Section
Field or Control Description
Message Text
The system displays error message text associated with each post error message. Messages are:
  • Cannot be Applied Due to Cancel, Delete, Close, Ship, or Hold.
  • Cannot be Applied Due to Order Change.
  • Order was Rescheduled Within Tolerance.
  • Quantity Changed in Planning Engine.
  • Order was Canceled by the Planning Engine.
Use the Review Post Errors - Search page (PL_OM_EXCPT_SRCH) to define the search criteria for the PeopleSoft Order Management post errors that you want to review.
Navigation:
Supply Planning, and then Commit Plan, and then Order Management, and then Review Post Errors, and then Search
Select the search criteria for the PeopleSoft Order Management post errors that you want to view. Select a plan unit group or ship from business unit, order type, and at least one error type.
Error Type
Cancel/Delete/Closed
Select to view cancelation, deletion, and closure errors that occurred in PeopleSoft Order Management and are associated with the search criteria that you selected.
Order Changed
Select to view order change errors that are associated with the search criteria that you selected. The order in PeopleSoft Order Management changes after being loaded in PeopleSoft Supply Planning.
Within Tolerance
Select to view within tolerance errors that are associated with the search criteria that you selected.
When you run the Post Updates process, you can decide how the system should handle the updates pertaining to the reschedule of sales orders, quotes, and buying agreements that are within tolerance. One of the options is to post an error if the reschedule update is invalid.
Quantity Changed
Select to view quantity change errors that are associated with the search criteria that you selected.
Quantity change errors occur if changes are made to the order quantity in the planning engine.
Planning Canceled
Select to view all of the orders that were manually canceled within PeopleSoft Supply Planning.
Open Pegs
Select to include updates to orders that are pegged to unfulfilled demand.
Use the Review Post Errors - Sales Orders/Quotes page (PL_SO_EXCEPTION) to review the PeopleSoft Order Management post errors that pertain to sales orders or quotes that occurred during the Post Updates process.
Navigation:
Supply Planning, and then Commit Plan, and then Order Management, and then Review Post Errors, and then Sales Orders/Quotes
When this page initially appears, all of the post errors that meet the selection criteria appear on the page. You can view more information pertaining to the error by selecting the different tabs—Exception Details, and Dates, —on the page.
Use the Buying Agreements page (PL_BUYING_AGREEMNT) to review and maintain parameters for buying agreements, such as releases, order quantities, and expected shipment dates.
Navigation:
Supply Planning, and then Refine Plan, and then Order Management, and then Buying Agreements
When this page initially appears, all of the post errors that meet the selection criteria appear on the page. You can view more information pertaining to the error by selecting the different tabs—Exception Details and Dates—on the page.
