Understanding Planning Problems
PeopleSoft Supply Planning enables you to view and analyze data before committing the plan or running another iteration of the plan.
Planning Violations and Exceptions
PeopleSoft Supply Planning separates planning violations and planning exceptions into two main component categories:
Planning violations: An exception or error that might be visible to the planning solvers.
The solvers might attempt to correct the error. A solver execution should reduce the number of these violations.
Planning exceptions: An exception or error that is not visible to the planning solver.
Generally, exceptions preexist in the model data or are caused by manual interaction with the model data. A solver execution run may not reduce the number of exceptions, except where the exception is removed when a solver corrects a related error. A solver execution run should not increase the number of exceptions.
Supply and Demand Analysis Reporting
PeopleSoft Supply Planning offers a wide range of query and reporting possibilities. You can use any of our standard reports or alter them to suit specific business needs.
With PeopleSoft Supply Planning, you can:
Identify items with on-hand quantity but little or no demand.
Identify the quantity and value of on-hand stock levels above the excess and safety stock level at a period end.
Calculate when inventory levels will fall to zero (or near zero) based on actual and planned demand, as well as actual supply.
Report on all of the planned reschedules–including transfers, production, purchase orders (POs), and sales orders within a selected date range and for a specific planning instance.
Report horizontal planning data by selecting and naming only row types that you want to view.
Row types can include supply, demand, on-hand quantities, and available-to-promise. You can dynamically select the data to be reported.
Report on detail resource usage–machines, crews, and tools–within a planning instance, based on scheduled and planned production.
