1.3.2 Defining PeopleSoft Maintenance Management Requirements
For PeopleSoft Maintenance Management, to enable the bar code option when you print a work order, you must install the appropriate bar code font, Code 39 True Type font, on the process scheduler.
To integrate Microsoft Project with PeopleSoft Maintenance Management, you must install Microsoft Project 2007 or higher on a Microsoft Windows-based process scheduler server and update the Microsoft Project Integration Application Engine (WM_MSP) process definition to use this process scheduler server.
