Using Work Management in the Procurement WorkCenter
The PeopleSoft Fluid Procurement WorkCenter can optionally use the Work Management Framework, which is an Enterprise Components feature.
This topic discusses how to set up Work Management for the Procurement WorkCenter and provides an example for one delivered Procurement Exception: PO Sourcing Errors.
Understanding Work Management in the Procurement WorkCenter
The purpose of the Work Management Framework is to view and manage transactions when they appear in the My Work section of the WorkCenter.
It is important to understand the Work Management Framework from a high-level perspective before applying it to PeopleSoft Procurement. Refer “Understanding the Work Management Framework” (Enterprise Components) to gain a foundational overview before proceeding with the details below.
The Work Management Framework provides actions and filters to My Work pagelets to assist users with managing a large list of transactions. Users may assign a specific transaction to themselves, defer the transaction for follow-up to a later date, or mark a transaction as not an exception (inactive). Filters allow the user to view transactions not yet assigned to anyone, transactions assigned to themselves, inactive transactions, or a full list of all transactions. You can also view a history of actions taken on the transaction.
Setting Up Work Management for the Procurement WorkCenter
This list provides the steps to setup the optional Work Management feature for the Procurement WorkCenter:
  1. You need the EXOC_USER role to access Work Management.
  2. Access the Enterprise Components: Work Management Link ID's Page.
  3. Search for Link ID corresponding to the My Work section for Procurement WorkCenter where you want to use the Work Management feature.
    Link IDs corresponding to the Procurement WorkCenter My Work are:
    Link ID Description
    BUYERCHGRQST_LNKID
    Change Request Errors
    POSSRCERR_LNKID
    PO Sourcing Errors
    POSONHLD_LNKID
    POs On Hold
    POSNOTBCHK_LNKID
    PO Budget Check Exceptions
    PODOCTOL_ERR_LNKID
    Document Tolerance Errors
    PODISPERR_LINKID
    PO Dispatch Errors
    POSDENIED_LNKID
    Denied POs
    REQSCHGRQST_LNKID
    REQOPEN_LINKID
    Reqs Saved not Submitted
    REQDENIED_LINKID
    Denied Requisitions
    REQNOTBCHK_LINKID
    Req Budget Check Exceptions
    REQ_SRCERR_LNKID
    Requisition Sourcing Errors
    REQSONHLD_LNKID
    Requisitions On Hold
  4. Select the View button to access the Enterprise Components: Enable Work Mgmt Exception Page.
  5. Select the Enable option to activate the Work Management feature for that Link ID.
  6. Follow instructions in the Enterprise Components documentation for the Enterprise Components: Enable Work Mgmt Exception Page to complete your setup.
Pages Used to Manage Work in the Procurement WorkCenter
Procurement WorkCenter Page - PO Sourcing Errors (Work Management Enabled)
PO_EXCEPTION_WC_FL
Access and manage PO Sourcing Errors in various views.
Use the Procurement WorkCenter page to access and manage POs with sourcing errors when Work Management is enabled.
Navigation:
Select the Procurement WorkCenter tile.
This example illustrates the fields and controls on the Procurement WorkCenter - PO Sourcing Errors (Work Management Enabled).
Procurement WorkCenter With Work Management
When Work Management is enabled for an exception, there are two changes on the WorkCenter page:
  • The View drop-down box appears above the grid.
  • Additional action options are added to the Actions button.
The actions for PO Sourcing Errors are Purge, Recycle, and Edit Staging Error. When Work Management is enabled, additional actions are available depending on the option selected in the View field: See Enterprise Components: Understanding the Work Management Framework, Actions by View section.
