JRuby Licenses
JRuby is Copyright (c) 2007-2018 The JRuby project, and is released
under a tri EPL/GPL/LGPL license. You can use it, redistribute it
and/or modify it under the terms of the:
Eclipse Public License version 2.0
OR
GNU General Public License version 2
OR
GNU Lesser General Public License version 2.1
jnr-posix (https://github.com/jnr/jnr-posix),
jruby-openssl (https://github.com/jruby/jruby-openssl),
jruby-readline (https://github.com/jruby/jruby-readline),
yydebug (https://github.com/jruby/jay-yydebug/)
are released under the same copyright/license.
Some additional libraries distributed with JRuby are not covered by
JRuby's licence. Most of these libraries and their licenses are listed
below. Also see LICENSE.RUBY for most files found in lib/ruby/stdlib.
asm (http://asm.objectweb.org) is distributed under the BSD license and is
Copyright (c) 2000-2011 INRIA, France Telecom
All rights reserved.
jline2 (https://github.com/jline/jline2) is distributed under the BSD license:
Copyright (c) 2002-2012, the original author or authors.
jzlib (http://www.jcraft.com/jzlib/) is distributed under the BSD license:
Copyright (c) 2000-2011 ymnk, JCraft,Inc. All rights reserved.
The "rake" library (https://github.com/ruby/rake) is distributed under
the MIT license, and has the following copyright:
Copyright (c) 2003, 2004 Jim Weirich
jcodings (http://github.com/jruby/jcodings) and
joni (http://github.com/jruby/joni) are distributed
under the MIT license without copyright.
Bouncycastle is released under the MIT license:
Copyright (c) 2000 - 2006 The Legion Of The Bouncy Castle.
jnr-x86asm (https://github.com/jnr/jnr-x86asm) is distributed under the MIT
license with the following copyright:
Copyright (C) 2010 Wayne Meissner
Copyright (c) 2008-2009, Petr Kobalicek <kobalicek.petr@gmail.com>
psych (https://github.com/ruby/psych) is distributed under the MIT license:
Copyright (c) 2009 Aaron Patterson, et al.
The following libraries are redistributed under the Apache Software
License v2.0, available below.
invokebinder (https://github.com/headius/invokebinder)
jffi (https://github.com/jnr/jffi)
jitescript (https://github.com/qmx/jitescript)
jnr-constants (http://github.com/jnr/jnr-constants)
jnr-enxio (https://github.com/jnr/jnr-enxio)
jnr-ffi (https://github.com/jnr/jnr-jffi)
jnr-netdb (http://github.com/jnr/jnr-netdb)
jnr-unixsocket (https://github.com/jnr/jnr-unixsocket)
joda-time (http://joda-time.sourceforge.net)
maven (http://maven.apache.org/)
options (https://github.com/headius/options)
snakeyaml (https://github.com/asomov/snakeyaml)
unsafe-fences (https://github.com/headius/unsafe-fences)
racc (runtime only, https://github.com/tenderlove/racc) is
distributed under the same license terms as the Ruby standard
library. This includes all files under lib/ruby/stdlib/racc.
See LICENSE.RUBY.
json-generator and json-parser (https://github.com/flori/json) native
extenstions under the same license terms as the Ruby standard library.
See LICENSE.RUBY
The complete text of the Eclipse Public License is as follows:
Eclipse Public License, Version 2.0
The complete text of the GNU General Public License v2 is as follows:
GNU General Public License, Version 2
The complete text of the GNU Lesser General Public License 2.1 is as follows:
GNU Lesser General Public License, Version 2.1
The following licenses cover code other than JRuby which is included with JRuby.
Licenses listed below include:
* Apache 2.0 License
* BSD License
* MIT License
The complete text of the Apache 2.0 License is as follows:
The complete text of the BSD license can be is as follows:
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
1. Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
3. Neither the name of the University nor the names of its contributors
may be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
THE POSSIBILITY OF SUCH DAMAGE.
The complete text of the MIT license is as follows:
The full text of the zlib licence:
Copyright (C) 1995-2013 Jean-loup Gailly and Mark Adler
Zlib Data Compression Library License
4th party dependencies
Bundler
Rake
minitest
Jar-dependencies
lrb
License: MIT
Erb
rubygems-update
License: Ruby
Ruby is copyrighted free software by Yukihiro Matsumoto <matz@netlab.jp>.
You can redistribute it and/or modify it under either the terms of the
2-clause BSDL (see the file BSDL), or the conditions below:
1. You may make and give away verbatim copies of the source form of the
software without restriction, provided that you duplicate all of the
original copyright notices and associated disclaimers.
2. You may modify your copy of the software in any way, provided that
you do at least ONE of the following:
a) place your modifications in the Public Domain or otherwise
make them Freely Available, such as by posting said
modifications to Usenet or an equivalent medium, or by allowing
the author to include your modifications in the software.
b) use the modified software only within your corporation or
organization.
c) give non-standard binaries non-standard names, with
instructions on where to get the original software distribution.
d) make other distribution arrangements with the author.
3. You may distribute the software in object code or binary form,
provided that you do at least ONE of the following:
a) distribute the binaries and library files of the software,
together with instructions (in the manual page or equivalent)
on where to get the original distribution.
b) accompany the distribution with the machine-readable source of
the software.
4. You may modify and include the part of the software into any other
software (possibly commercial). But some files in the distribution
are not written by the author, so that they are not under these terms.
For the list of those files and their copying conditions, see the
file LEGAL.
5. The scripts and library files supplied as input to or produced as
output from the software do not automatically fall under the
copyright of the software, but belong to whomever generated them,
and may be sold commercially, and may be aggregated with this
software.
6. THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
PURPOSE.
Racc
prime
power_assert
net-smtp
net-imap
net-ftp
matrix
net-pop
License: Ruby, BSD-2-Clause
JRuby distributes some ruby modules which are distributed under Ruby license:
organization.
the software.
file LEGAL.
software.
PURPOSE.
Test-unit
License: Ruby, BSDL, PSFL
test-unit is copyrighted free software by Kouhei Sutou
<kou@cozmixng.org>, Ryan Davis <ryand-ruby@zenspider.com>
and Nathaniel Talbott <nathaniel@talbott.ws>.
a. place your modifications in the Public Domain or otherwise
b. use the modified software only within your corporation or
organization.
c. give non-standard binaries non-standard names, with
d. make other distribution arrangements with the author.
a. distribute the binaries and library files of the software,
b. accompany the distribution with the machine-readable source of
the software.
file LEGAL.
software.
PURPOSE.
Exceptions
* lib/test/unit/diff.rb: This license and PSF license
rss
rexml
rdoc
BSDL-2-Clause
Copyright (C) 1993-2013 Yukihiro Matsumoto
