Open Source Software Included with Oracle Outside In Technology
Required notices for open source software products or components distributed with the products are identified in the following table along with the applicable licensing information.
| Provider | Component | Licensing Information |
Alexander Roshal |
UnRAR |
UnRAR - free utility for RAR archives License for use and distribution of FREE portable version The source code of UnRAR utility is freeware. This means: 1. All copyrights to RAR and the utility UnRAR are exclusively owned by the author - Alexander Roshal. 2. UnRAR source code may be used in any software to handle RAR archives without limitations free of charge, but cannot be used to develop RAR (WinRAR) compatible archiver and to re-create RAR compression algorithm, which is proprietary. Distribution of modified UnRAR source code in separate form or as a part of other software is permitted, provided that full text of this paragraph, starting from "UnRAR source code" words, is included in license, or in documentation if license is not available, and in source code comments of resulting package. 3. The UnRAR utility may be freely distributed. It is allowed to distribute UnRAR inside of other software packages. 4. THE RAR ARCHIVER AND THE UnRAR UTILITY ARE DISTRIBUTED "AS IS". NO WARRANTY OF ANY KIND IS EXPRESSED OR IMPLIED. YOU USE AT YOUR OWN RISK. THE AUTHOR WILL NOT BE LIABLE FOR DATA LOSS, DAMAGES, LOSS OF PROFITS OR ANY OTHER KIND OF LOSS WHILE USING OR MISUSING THIS SOFTWARE. 5. Installing and using the UnRAR utility signifies acceptance of these terms and conditions of the license. 6. If you don't agree with terms of the license you must remove UnRAR files from your storage devices and cease to use the utility. |
Apache |
PDFBox |
-------------------------- PdfBox License: EXTERNAL COMPONENTS Apache PDFBox includes a number of components with separate copyright notices and license terms. Your use of these components is subject to the terms and conditions of the following licenses. Contributions made to the original PDFBox and FontBox projects: Copyright (c) 2002-2007, www.pdfbox.org All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. 2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. 3. Neither the name of pdfbox; nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Adobe Font Metrics (AFM) for PDF Core 14 Fonts This file and the 14 PostScript(R) AFM files it accompanies may be used, copied, and distributed for any purpose and without charge, with or without modification, provided that all copyright notices are retained; that the AFM files are not distributed without this file; that all modifications to this file or any of the AFM files are prominently noted in the modified file(s); and that this paragraph is not modified. Adobe Systems has no responsibility or obligation to support the use of the AFM files. CMaps for PDF Fonts (http://opensource.adobe.com/wiki/display /cmap/Downloads) Copyright 1990-2009 Adobe Systems Incorporated. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. Neither the name of Adobe Systems Incorporated nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. PaDaF PDF/A preflight (http://sourceforge.net/projects/padaf) Copyright 2010 Atos Worldline SAS Licensed by Atos Worldline SAS under one or more contributor license agreements. See the NOTICE file distributed with this work for additional information regarding copyright ownership. Atos Worldline SAS licenses this file to You under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0 Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. OSXAdapter Version: 2.0 Disclaimer: IMPORTANT: This Apple software is supplied to you by Apple Inc. ("Apple") in consideration of your agreement to the following terms, and your use, installation, modification or redistribution of this Apple software constitutes acceptance of these terms. If you do not agree with these terms, please do not use, install, modify or redistribute this Apple software. In consideration of your agreement to abide by the following terms, and subject to these terms, Apple grants you a personal, non-exclusive license, under Apple's copyrights in this original Apple software (the "Apple Software"), to use, reproduce, modify and redistribute the Apple Software, with or without modifications, in source and/or binary forms; provided that if you redistribute the Apple Software in its entirety and without modifications, you must retain this notice and the following text and disclaimers in all such redistributions of the Apple Software. Neither the name, trademarks, service marks or logos of Apple Inc. may be used to endorse or promote products derived from the Apple Software without specific prior written permission from Apple. Except as expressly stated in this notice, no other rights or licenses, express or implied, are granted by Apple herein, including but not limited to any patent rights that may be infringed by your derivative works or by other works in which the Apple Software may be incorporated. The Apple Software is provided by Apple on an "AS IS" basis. APPLE MAKES NO WARRANTIES, EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION THE IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, REGARDING THE APPLE SOFTWARE OR ITS USE AND OPERATION ALONE OR IN COMBINATION WITH YOUR PRODUCTS. IN NO EVENT SHALL APPLE BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) ARISING IN ANY WAY OUT OF THE USE, REPRODUCTION, MODIFICATION AND/OR DISTRIBUTION OF THE APPLE SOFTWARE, HOWEVER CAUSED AND WHETHER UNDER THEORY OF CONTRACT, TORT (INCLUDING NEGLIGENCE), STRICT LIABILITY OR OTHERWISE, EVEN IF APPLE HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Copyright (C) 2003-2007 Apple, Inc., All Rights Reserved PdfBox Notice: Based on source code contributed to the original PDFBox project. Copyright (c) 2002-2007, www.pdfbox.org Includes the Adobe Glyph List Copyright 1997, 1998, 2002, 2007,
2010 Adobe Systems Incorporated.
Includes the Zapf Dingbats Glyph List Copyright 2002, 2010 Adobe Systems
Incorporated.
Includes the Bidi Mirroring Glyph Property (BidiMirroring-8.0.0.txt) Copyright 1991-2015 Unicode, Inc. Includes parts of TwelveMonkeys ImageIO Copyright 2008-2016 Harald Kuhr Includes the CMYK ICC-profile (CGATS001Compat-v2-micro.icc) https://github.com/saucecontrol/Compact-ICC-Profiles Released to the public domain under the Creative Commons CC0 license by Clinton Ingram, saucecontrol -------------------------- FontBox License: CONTRIBUTIONS TO THE ORIGINAL CODEBASE Apache FontBox is based on contributions made to the original FontBox project: Copyright (c) 2006-2007, www.fontbox.org All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. 2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. 3. Neither the name of fontbox; nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Lohit-Bengali, Lohit-Devangari, Lohit-Gujarati fonts (https://pagure.io/lohit): Copyright 2011-15 Lohit Fonts Project contributors This Font Software is licensed under the SIL Open Font License, Version 1.1. This license is copied below, and is also available with a FAQ at: http://scripts.sil.org/OFL ----------------------------------- SIL OPEN FONT LICENSE Version 1.1 - 26 February 2007 ---------------------------------- FontBox Notice: Based on source code contributed to the original FontBox project. Copyright (c) 2006-2007, www.fontbox.org Includes the Script Property (Scripts-10.0.0.txt) Copyright 2017 Unicode, Inc. ---------separator--------- FOURTH-PARTY DEPENDENCY #1 NAME: Commons Logging FOURTH-PARTY DEPENDENCY #1 COPYRIGHT NOTICES: Apache Commons Logging Copyright 2001-2024 The Apache Software Foundation This product includes software developed at The Apache Software Foundation (https://www.apache.org/). FOURTH-PARTY DEPENDENCY #1 LICENSE: Apache 2.0 FOURTH-PARTY DEPENDENCY #2 NAME: PDFBox IO FOURTH-PARTY DEPENDENCY #2 COPYRIGHT NOTICES: Apache PDFBox IO Copyright 2003-2014 The Apache Software Foundation This product includes software developed at The Apache Software Foundation (http://www.apache.org/). FOURTH-PARTY DEPENDENCY #2 LICENSE: Apache 2.0 FOURTH-PARTY DEPENDENCY #3 NAME: FontBox FOURTH-PARTY DEPENDENCY #3 COPYRIGHT NOTICES: Apache FontBox Based on source code contributed to the original FontBox project. Copyright (c) 2006-2007, www.fontbox.org Includes the Script Property (Scripts-10.0.0.txt) Copyright 2017 Unicode, Inc. FOURTH-PARTY DEPENDENCY #3 LICENSE: Apache 2.0 |
Expat Maintainers |
Expat XML Parser |
Copyright (c) 1998-2000 Thai Open Source Software Center Ltd and Clark Cooper Copyright (c) 2001-2024 Expat maintainers |
Google Protocol Buffer |
Protocol Buffers - Google's data interchange format Copyright 2008 Google Inc. All rights reserved. https://developers.google.com/protocol-buffers/ |
Snappy Compression |
Copyright 2011, Google Inc.
BSD 3-Clause License (With Google Inc Reference) === Some of the benchmark data in testdata/ is licensed differently: - fireworks.jpeg is Copyright 2013 Steinar H. Gunderson, and is licensed under the Creative Commons Attribution 3.0 license (CC-BY-3.0). See https://creativecommons.org/licenses/by/3.0/ for more information. - kppkn.gtb is taken from the Gaviota chess tablebase set, and is licensed under the MIT License. See https://sites.google.com/site/gaviotachessengine/Home/endgame-tablebases-1 for more information. - paper-100k.pdf is an excerpt (bytes 92160 to 194560) from the paper “Combinatorial Modeling of Chromatin Features Quantitatively Predicts DNA Replication Timing in _Drosophila_” by Federico Comoglio and Renato Paro, which is licensed under the CC-BY license. See http://www.ploscompbiol.org/static/license for more ifnormation. - alice29.txt, asyoulik.txt, plrabn12.txt and lcet10.txt are from Project Gutenberg. The first three have expired copyrights and are in the public domain; the latter does not have expired copyright, but is still in the public domain according to the license information (http://www.gutenberg.org/ebooks/53). |
Jean-loup Gailly and Mark Adler |
Zlib Data Compression |
Copyright notice: (C) 1995-2024 Jean-loup Gailly and Mark Adler |
Freetype.org |
Freetype |
The FreeType Project LICENSE GNU GENERAL PUBLIC LICENSE GNU General Public License, Version 2 ### Additional Freetype Attributions ``` --------------------------------- The below license applies to the following files: libfreetype/src/psaux/psarrst.c libfreetype/src/psaux/psarrst.h libfreetype/src/psaux/psblues.c libfreetype/src/psaux/psblues.h libfreetype/src/psaux/pserror.c libfreetype/src/psaux/pserror.h libfreetype/src/psaux/psfixed.h libfreetype/src/psaux/psfont.c libfreetype/src/psaux/psfont.h libfreetype/src/psaux/psft.c libfreetype/src/psaux/psft.h libfreetype/src/psaux/psglue.h libfreetype/src/psaux/pshints.c libfreetype/src/psaux/pshints.h libfreetype/src/psaux/psintrp.c libfreetype/src/psaux/psintrp.h libfreetype/src/psaux/psread.c libfreetype/src/psaux/psread.h libfreetype/src/psaux/psstack.c libfreetype/src/psaux/psstack.h libfreetype/src/psaux/pstypes.h Copyright 2006-2014 Adobe Systems Incorporated. This software, and all works of authorship, whether in source or object code form as indicated by the copyright notice(s) included herein (collectively, the "Work") is made available, and may only be used, modified, and distributed under the FreeType Project License, LICENSE.TXT. Additionally, subject to the terms and conditions of the FreeType Project License, each contributor to the Work hereby grants to any individual or legal entity exercising permissions granted by the FreeType Project License and this section (hereafter, "You" or "Your") a perpetual, worldwide, non-exclusive, no-charge, royalty-free, irrevocable (except as stated in this section) patent license to make, have made, use, offer to sell, sell, import, and otherwise transfer the Work, where such license applies only to those patent claims licensable by such contributor that are necessarily infringed by their contribution(s) alone or by combination of their contribution(s) with the Work to which such contribution(s) was submitted. If You institute patent litigation against any entity (including a cross-claim or counterclaim in a lawsuit) alleging that the Work or a contribution incorporated within the Work constitutes direct or contributory patent infringement, then any patent licenses granted to You under this License for that Work shall terminate as of the date such litigation is filed. By using, modifying, or distributing the Work you indicate that you have read and understood the terms and conditions of the FreeType Project License as well as those provided in this section, and you accept them fully. ``` ### MIT License ``` --------------------------------- The below license applies to the following files: libfreetype/include/freetype/internal/fthash.h libfreetype/src/base/fthash.c Copyright 2000 Computing Research Labs, New Mexico State University Copyright 2001-2015 Francesco Zappa Nardelli |
Igor Pavlov |
LZMA SDK |
Copyright (c) 1999-2018 Igor Pavlov LZMA SDK is placed in the public domain.Anyone is free to copy, modify, publish, use, compile, sell, or distribute the original LZMA SDK code, either in source code form or as a compiled binary, for any purpose, commercial or non-commercial, and by any means. |
OpenJpeg Software maintainer |
OpenJpeg |
For a copy of the licenses used by OpenJpeg, see OpenJpeg Licenses. |
Apache Santuario |
XML Security for Java |
Copyright: The Apache Software Foundation === Source URL: https://dlcdn.apache.org/santuario/java-library/3_0_5/xmlsec-3.0.5-source-release.zip License: Apache 2.0 ./LICENSE ------------------------- ./NOTICE Apache Santuario - XML Security for Java Copyright 1999-2024 The Apache Software Foundation This product includes software developed at The Apache Software Foundation (http://www.apache.org/). It was originally based on software copyright (c) 2001, Institute for Data Communications Systems, http://www.nue.et-inf.uni-siegen.de/. The development of this software was partly funded by the European Commission in the <WebSig> project in the ISIS Programme. This product contains software that is copyright (c) 2021, 2023, Oracle and/or its affiliates. --------------------------- 4th party as listed in the DEPENDENCIES file From: 'Eclipse Foundation' (https://www.eclipse.org) - Jakarta XML Binding API (=== Source URL:https://github.com/jakartaee/jaxb-api/tree/3.0.1) jakarta.xml.bind:jakarta.xml.bind-api:jar:3.0.1 License: Eclipse Distribution License - v 1.0 (http://www.eclipse.org/org/documents/edl-v10.php) ./LICENSE.md Copyright (c) 2017, 2018 Oracle and/or its affiliates. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: - Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. - Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. - Neither the name of the Eclipse Foundation, Inc. nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ------------------------ ./NOTICE.md Notices for Jakarta XML Binding This content is produced and maintained by the Jakarta XML Binding project. Project home: https://projects.eclipse.org/projects/ee4j.jaxb Trademarks Jakarta XML Binding is a trademark of the Eclipse Foundation. Copyright All content is the property of the respective authors or their employers. For more information regarding authorship of content, please consult the listed source code repository logs. Declared Project Licenses This program and the accompanying materials are made available under the terms of the Eclipse Distribution License v. 1.0 which is available at http://www.eclipse.org/org/documents/edl-v10.php. SPDX-License-Identifier: BSD-3-Clause Source Code The project maintains the following source code repositories: https://github.com/eclipse-ee4j/jaxb-api https://github.com/eclipse-ee4j/jaxb-tck Third-party Content This project leverages the following third party content. Apache River (3.0.0) License: Apache-2.0 AND BSD-3-Clause ASM 7 (n/a) License: BSD-3-Clause Project: https://asm.ow2.io/ Source: https://repository.ow2.org/nexus/#nexus-search;gav~org.ow2.asm~asm-commons~~~~kw,versionexpand JTHarness (5.0) License: (GPL-2.0 OR GPL-2.0 WITH Classpath-exception-2.0) Project: https://wiki.openjdk.java.net/display/CodeTools/JT+Harness Source: http://hg.openjdk.java.net/code-tools/jtharness/ normalize.css (3.0.2) License: MIT SigTest (n/a) License: GPL-2.0 OR GPL-2.0 WITH Classpath-exception-2.0 Cryptography Content may contain encryption software. The country in which you are currently may have restrictions on the import, possession, and use, and/or re-export to another country, of encryption software. BEFORE using any encryption software, please check the country's laws, regulations and policies concerning the import, possession, or use, and re-export of encryption software, to see if this is permitted. -------------------------- 5th Dependency: com.sun.activation:jakarta.activation (Source URL: https://github.com/jakartaee/jaf-api/tree/2.0.1) Copyright: Eclipse Foundation ./LICENSE.md Copyright (c) 2018 Oracle and/or its affiliates. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: - Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. - Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. - Neither the name of the Eclipse Foundation, Inc. nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. -------------------------- ./NOTICE.md Notices for Jakarta Activation This content is produced and maintained by Jakarta Activation project. Project home: https://projects.eclipse.org/projects/ee4j.jaf Copyright All content is the property of the respective authors or their employers. For more information regarding authorship of content, please consult the listed source code repository logs. Declared Project Licenses This program and the accompanying materials are made available under the terms of the Eclipse Distribution License v. 1.0, which is available at http://www.eclipse.org/org/documents/edl-v10.php. SPDX-License-Identifier: BSD-3-Clause Source Code The project maintains the following source code repositories: https://github.com/eclipse-ee4j/jaf ------------------------- From: 'FasterXML' (http://fasterxml.com) - Woodstox (https://github.com/FasterXML/woodstox/tree/woodstox-core-6.5.1) com.fasterxml.woodstox:woodstox-core:bundle:6.5.1 License: The Apache License, Version 2.0 (http://www.apache.org/licenses/LICENSE-2.0.txt) ./LICENSE Apache 2.0 ( same as org.apache.santuario:xmlsec) -------------------------- From: 'fasterxml.com' (http://fasterxml.com) - Stax2 API (https://github.com/FasterXML/stax2-api/tree/stax2-api-4.2.1) org.codehaus.woodstox:stax2-api:bundle:4.2.1 License: The BSD License (http://www.opensource.org/licenses/bsd-license.php) ./src/main/resources/META-INF/LICENSE This copy of Stax2 API is licensed under the Simplified BSD License (also known as "2-clause BSD", or "FreeBSD License") See the License for details about distribution rights, and the specific rights regarding derivate works. You may obtain a copy of the License at: http://www.opensource.org/licenses/bsd-license.php with details of: <COPYRIGHT HOLDER> = FasterXML.com <YEAR> = 2010- ------------------------------ From: 'QOS.ch' (http://www.qos.ch) - SLF4J API Module (https://github.com/qos-ch/slf4j/tree/v_1.7.36/slf4j-api) org.slf4j:slf4j-api:jar:1.7.36 License: MIT License (http://www.opensource.org/licenses/mit-license.php) ./slf4j/slf4j-api/LICENSE.txt Copyright (c) 2004-2022 QOS.ch Sarl (Switzerland) All rights reserved. --------------------------- From: 'The Apache Software Foundation' (https://www.apache.org/) - Apache Commons Codec (https://github.com/apache/commons-codec/tree/rel/commons-codec-1.15) commons-codec:commons-codec:jar:1.15 License: Apache License, Version 2.0 (https://www.apache.org/licenses/LICENSE-2.0.txt) ./LICENSE.txt Apache 2.0 ( same as org.apache.santuario:xmlsec) ---------------------------- ./NOTICE.txt Apache Commons Codec Copyright 2002-2020 The Apache Software Foundation This product includes software developed at The Apache Software Foundation (https://www.apache.org/). src/test/org/apache/commons/codec /language/DoubleMetaphoneTest.java contains test data from http://aspell.net/test/orig/batch0.tab. Copyright (C) 2002 Kevin Atkinson (kevina@gnu.org) ============= The content of package org.apache.commons.codec.language.bm has been translated from the original php source code available at http://stevemorse.org/phoneticinfo.htm with permission from the original authors. Original source copyright: Copyright (c) 2008 Alexander Beider & Stephen P. Morse. |
Struktur AG |
High Efficiency Video Decoding (libde265) |
* The library `libheif` is distributed under the terms of the GNU Lesser General Public License. * The sample applications are distributed under the terms of the MIT License. License texts below and in the `COPYING` files of the corresponding subfolders. GNU Lesser General Public License, Version 3 GNU General Public License, Version 3 ----------------------------------- MIT License |
Struktur AG |
HEIF and AVIF (AV1 Image File Format) |
* The library `libheif` is distributed under the terms of the GNU Lesser General Public License. * The sample applications are distributed under the terms of the MIT License. License texts below and in the `COPYING` files of the corresponding subfolders. GNU Lesser General Public License, Version 3 GNU General Public License, Version 3 ---------------------------- MIT License |
Red Hat, Inc. |
Liberation fonts |
Digitized data copyright (c) 2010 Google Corporation with Reserved Font Arimo, Tinos and Cousine. Copyright (c) 2012 Red Hat, Inc. with Reserved Font Name Liberation. |
ODA Inc |
Open Design Libraries |
// Copyright (C) 2002-2024, Open Design Alliance (the “Alliance”). // All rights reserved. // // This software and its documentation and related materials are owned by // the Alliance. The software may only be incorporated into application // programs owned by members of the Alliance, subject to a signed // Membership Agreement and Supplemental Software License Agreement with the // Alliance. The structure and organization of this software are the valuable // trade secrets of the Alliance and its suppliers. The software is also // protected by copyright law and international treaty provisions. Application // programs incorporating this software must include the following statement // with their copyright notices: // // This application incorporates Open Design Alliance software pursuant to a license // agreement with Open Design Alliance. // Open Design Alliance Copyright (C) 2002-2024 by Open Design Alliance. // All rights reserved. // // By use of this software, its documentation or related materials, you // acknowledge and accept the above terms. |
libwebp |
For a copy of the licenses used by libwebp, see libwebp Licenses. |
slf4j-api |
Copyright (c) 2004-2023 QOS.ch All rights reserved. For a copy of the license, see MIT License. |
slf4j-simple |
