Running the Work Risk Report for Brazil
This section discusses how to run the Work Risk report for Brazil.
Page Used to Run the Work Risk Report for Brazil
| Page Name | Definition Name | Usage |
CATRC_INCIDENT_BRA |
Monitor work risks by establishment ID, department ID, employee, and incident ID. |
CAT Report BRA Page
Use the CAT Report BRA page (CATRC_INCIDENT_BRA) to monitor work risks by establishment ID, department ID, employee, and incident ID.
Navigation:
This example illustrates the fields and controls on the CAT Report BRA page. You can find definitions for the fields and controls later on this page.
Create CAT reports using the PeopleSoft Global Payroll for Brazil: CAT Form Page if you use the S-2210 event in eSocial to submit work accident data to the Government.
Select the appropriate values for the fields that appear on the page. The system displays a different set of fields at the bottom of the page for each of the options that you select in the Selection Criteria group box.
