Setting Up and Using the Work Management Framework
This topic provides an overview of the framework and setup steps and discusses how to enable Work Management Framework for transactions that appear in the My Work section of a Fluid WorkCenter. The framework is designed for application-specific use.
Some transaction categories that appear in the My Work section of a WorkCenter may not be a candidate for the Work Management framework and therefore are not delivered. However, you can enable this framework for transaction categories as well as related actions for delivered or custom transactions as needed. To do this, use the setup pages below.
The Enterprise Components Work Management Framework is introduced with FSCM Update Image 53 and HCM Update Image 52.
Pages Used to Enable Work Management in Enterprise Components
Use these pages to enable Work Management for PeopleSoft applications.
Work Management Link ID's Page
EOXC_SETUP_SRCH_FL
Select Link ID's and access the Work Management page.
Enable Work Mgmt Exception Page
EOXC_SETUP_FL
Enable the Work Management feature, determine follow-up days, and enable comments.
Work Mgmt Product Default Page
EOXC_PRDGRP_FL
View or modify the pillar product ID with their default record groups and corresponding record and comments record. Additional rows can be added.
Work Mgmt Record Group Default Page
EOXC_RECGRP_FL
View or modify a pillar record group, the status of the record group, and the corresponding record and comments record.
Exception Comments Window
EOXC_CMTS_POP_SCF
Adjust the defaulted follow-up date and enter comments.
Exception History Window
EOXC_HISTLOG_SCF
View all actions that have been taken on a transaction.
Understanding the Work Management Framework
The purpose of the Work Management Framework is to view and manage transaction errors or warnings when they appear in My Work sections of a PeopleSoft WorkCenter. Some transaction errors or warnings may fall off of this list when a system resolution is available, but others may not.
Transaction errors or warnings appear in a WorkCenter to bring attention to a potential issue with the transaction. These transactions typically require some action to resolve them, such as notifying an employee or manager, or running a pending process. When Work Management is enabled for a transaction, and you act on the transaction, the system automatically populates the history table with as much information as possible. This information can be displayed using the All History view.
The Work Management Framework adds functionality to track transactions identified in My Work. This optional framework provides additional actions, in addition to existing application-delivered actions, to track and clear transactions when no system-based resolution exists. The transactions are placed into one of five different views: Unassigned, All Assigned, All History, Assigned to Me, and Inactive.
When addressing transactions that are in the Unassigned view, you can determine a follow-up date and add a comment. The follow-up date temporarily removes the transaction from the Unassigned view while external activities are carried out such as making a phone call. The comment is saved in history for reference. When the follow-up date is reached, the transaction reappears in Unassigned view for further attention.
Examples of transactions that may not have a system resolution are:
  • Overdue Purchase Order Shipments not yet received.
  • Corporate credit card expenses that violate reimbursement policies.
  • Invalid exceptions that need to be removed from the query results.
To manage these situations, Work Management can be enabled to track the actions taken to resolve issues. The system tracks both system-generated actions, such as notifications or tasks, and manual actions, such as a phone call to a supplier. The follow-up date and a complete action history is visible, along with the ability to view actions taken by all users.
When a transaction does not need additional action to be taken, has been resolved, or is no longer valid, you can change the status to Inactive. An Inactive status indicates that the transaction will not be resolved, such as those that need to be removed from query results, or a cash advance that was sent to an employee who is no longer with the company. When you inactivate a transaction, you can add a comment to explain why the status is applied.
Field or Control Description
View
Select a view. Options are:
  • Unassigned - displays all transactions that need attention.
  • All Assigned - displays all transactions that are assigned to someone, including yourself. These transactions need follow-up or some type of action on a deferred time frame. This view can be used if you have more than one administrator who can act on a transaction.
  • All History - displays all transactions where someone has taken at least one action. This view also displays the Action Status column. Use this view to download the transactions to spreadsheet. There are no actions that can be taking in this view.
  • Assigned to Me - displays all transactions that you have acted on. These transactions need follow-up or some type of action on a deferred time frame.
  • Inactive - displays all transactions that no longer need attention.
Actions by View
The action that can be taken on a transaction depends on two things:
  • The delivered options of what actions are allowed from the WorkCenter and the Work Management setup.
    These product-enabled actions are always listed at the top.
  • The Work Management Framework listing of what actions are allowed from the WorkCenter.
    These Work Management-enabled actions are always listed at the bottom.
View Description and Actions
Unassigned
Displays all transactions that are waiting for an action.
Action options are:
  • Assign to Me - select to move the transaction to the Assigned to Me view. If you are using the comment feature in Work Management, an Exception Comments window appears where you can view or edit the follow-up date, and enter a comment.
  • Mark as Inactive - Select to move the transaction to the Inactive view. These should be transactions that no longer need additional actions to be taken but have not fallen off of your list.
  • Exception History - Select to display all actions taken for this transaction.
Whenever you want to act on a transaction, it must be in the Unassigned view. You may need to move a transaction from Assigned to Me back to Unassigned. To do this, go to the Assigned to Me view, select the Action icon, and select Unassign.
All Assigned
Displays all transactions that are being worked on (at least one action has been taken) by yourself or someone else. These transactions need follow-up or some type of action on a deferred time frame.
Action options are:
  • Mark as Inactive - select to move the transaction to Inactive status.
  • Exception History - select to access the Exception History page for the transaction.
  • Unassign - select to unassign the transaction and move it to Unassigned status.
All History
Displays the status of all transactions, which includes Unassigned, Inactive, Assigned to Me, All Assigned, and history. You can download all transactions to an excel spreadsheet. No other actions are allowed in this view.
Assigned to Me
Displays all transactions that you are working on (at least one action has been taken). These transactions need follow-up or some type of action on a deferred time frame. Transactions being worked on by others are not displayed.
Action options are:
  • Exception History - select to access the Exception History Window for the transaction.
Inactive
Displays all transactions where the transaction has been addressed, is no longer an issue, or is resolved.
Action options are:
  • Mark as Valid Exception - select to move to Active status.
  • Exception History - Select to access the Exception History Window for the transaction.
Setting Up Work Management for My Work Transactions
To setup the Work Management feature for a WorkCenter - My Work errors or warnings:
  1. Use the EOXC_USER role to access the Work Management setup pages.
  2. Use the Enable Work Mgmt Exception Page to enable the desired transaction, determine the default follow-up day, track history, and track comments.
Optionally:
  • Use the Work Mgmt Product Default Page to view or modify the pillar product ID with their default record groups and corresponding record and comments record.
  • Use the Work Mgmt Record Group Default Page to view or modify a pillar record group, the status of the record group, and the corresponding record and comments record.
Use the Work Management Link ID's page (EOXC_SETUP_SRCH_FL) to select link ID's and access the Work Management page.
Navigation:
Enterprise Components, and then Work Management, and then Work Management
This example illustrates the fields and controls on the Work Management Link ID's page.
Work Management Link IDs
As mentioned previously, some transaction categories (known as Link ID's on this page) that appear in the My Work section of a WorkCenter may not be a candidate for the Work Management framework and therefore are not delivered.
Filter options
Use these fields to filter data by product, link ID, or if Work Management is enabled or not. Use the Search button to refresh your search results to display those items that meet your search criteria.
Product
Select a product to view only those link IDs that belong to that product.
Link ID
Enter or search for a link ID to easily access a specific item.
Work Management Enabled
Select Yes to show link IDs that have Work Management enabled and meet the other filter criteria, if applicable.
Select No to show link IDs that do not have Work Management enabled and meet the other filter criteria, if applicable.
Clear All button
Select to remove all search criteria and show all link IDs.
Work Management Setup
View button
Select to access the Enable Work Mgmt Exception Page for the transaction.
Use the Enable Work Mgmt (Management) Exception page (EOXC_SETUP_FL) to enable the Work Management feature, determine follow-up days, and enable comments.
Navigation:
Enterprise Components, and then Work Management, and then Work Management. Select the View button for the link ID.
This example illustrates the fields and controls on the Enable Work Mgmt Exceptions page.
Work Management
Default Follow Up Days
Enter a number that is used to determine the Follow Up Date field on the Exception Comments Window for the transaction.
Enable
Select to enable the Work Management feature for the transaction.
Enable Comments
Select to indicate that you want the Exception Comments Window to appear for this transaction after selecting Assign to Me or Mark as Inactive.
Note: This option does not REQUIRE comments. When selecting this option, comments are optional.
When this option is NOT selected, the Exception Comments Window does not appear after selecting Assign to Me or Mark as Inactive.
Action Settings Section
Action Name and Description
Displays the application-delivered actions that are mapped to leverage Work Management functionality for the transaction. These actions are delivered by PeopleSoft applications. For example, Notify Employee and Notify Manager, and can be configured to participate in the Work Management Framework.
Enable
Select to allow the action to leverage Work Management functionality. When enabled, users can use the action to manage and track transactions through the Work Management Framework.
Track Action History
Select to have the system log this action in the history table for the transaction. This allows you to see the action history when using the All History view. Actions are written to the table defined in the Exception Record field of the Work Mgmt Product Default Page.
Enable Comments
Select to have the system display the Exception Comments Window and log the comment for the transaction. This option allows you to see comments when using the All History view. Comments are written to the table defined in the Exception Comments Record of the Work Mgmt Product Default Page.
When this option is selected and you select the following action, the system displays:
Follow Up Days
Enter the follow up days for the action. The value in this field defaults from the Follow Up Days value at the top of the page. You can change it for each action listed.
Use the Work Mgmt (Management) Product Default page (EOXC_PRDGRP_FL) view or modify the pillar product ID with their default record groups and corresponding record and comments record.
Navigation:
Enterprise Components, and then Work Management, and then Work Management Prod Default.
This example illustrates the fields and controls on the Work Mgmt Product Default page.
Work Management Product Default
The Exception Record and the Exception Comments Record is defined on the Work Mgmt Record Group Default Page.
Use the Work Mgmt (Management) Record Group Default page (EOXC_RECGRP_FL) to view or modify a pillar record group, the status of the record group, and the corresponding record and comments record.
Navigation:
Enterprise Components, and then Work Management, and then Work Mgmt Record Group Default.
This example illustrates the fields and controls on the Work Mgmt Record Group Default page.
Work Management Record Group Default
Several record groups are predefined by PeopleSoft and divided by product group. The Unused<#> rows are available for you to create your own record groups for Work Management.
If a row is display only, then the system has added activity to the Exception Record and the Exception Comments Record. Therefore, they cannot be changed.
For each Exception Record there can be multiple comments that are held in the Exception Comments Record.
Exception Record and Exception Comments Record
Select the record where you want to store transaction details and comments. This information is used when viewing history.
Use the Exception Comments window (EOXC_CMTS_POP_SCF) to adjust the defaulted follow-up date and enter comments.
Navigation:
  • Select Assign to Me from an Unassigned transaction.
  • Select Inactive from an Unassigned transaction.
    The follow up date field does not appear when inactivating a transaction.
This example illustrates the fields and controls on the Exception Comments window.
Exception Comments
Follow Up Date
Defaults to a follow-up date, which is determined on the Enable Work Mgmt Exception Page. This date can be overridden.
The transaction is removed from the Unassigned view until the follow-up date is reached and adds it to the Assigned to Me view. When the date is reached, the system adds it back to the Unassigned view.
Note: The date format follows user preferences.
Comments
Enter comments to track the action you have taken for the transaction. Entering a comment is optional, but recommended to track what has been performed and what may need to happen next.
Use the Exception History window (EOXC_HISTLOG_SCF) to view all actions that have been taken to a transaction.
Navigation:
Select Exception History from a transaction related action.
This example illustrates the fields and controls on the Exception History window.
Exception History
User Name
Displays the name of the user who acted on the transaction.
Source
Displays:
  • System - indicates that the action was performed using an delivered system related action option, such as notifying the employee.
  • Manual - indicates that the action was performed using a Work Management option, such changing the status from Unassigned to Assign to Me because you are waiting for the payroll department to run a process that clears the employee's outstanding items before making them inactive.
