Analytic Calculation Engine Implementation
The functionality to create your own analytic models is delivered as part of standard PeopleSoft PeopleTools that are provided with all PeopleSoft products. However, you must complete these activities before you can create analytic models:
Step Reference
Use the PeopleSoft DPKs to deploy a full PeopleSoft application environment, including database, application server, Process Scheduler, and web server (PIA).
See PeopleSoft 9.2 Application Installation for your database platform.
Enable the appropriate number of analytic server instances.
See Configuring and Starting Analytic Servers.
Establish a user profile that gives you access to PeopleSoft Application Designer and any other processes that you will use.
See Security Administration: Security Basics.
Configure the application for which you are creating or changing an analytic model.
The appropriate product documentation for your application.
