Understanding Analytic Calculation Engine
Analytic Calculation Engine comprises a calculation engine plus several PeopleTools features that enable application developers to define both the calculation rules and the display of calculated data within PeopleSoft applications for the purposes of multidimensional reporting, data editing, and analysis.
Specifically, application developers create analytic models to define the rules that are used to calculate data. Application developers also create PeopleSoft Pure Internet Architecture pages with analytic grids to display the data within PeopleSoft applications. Within the application, a PeopleSoft Pure Internet Architecture page with an analytic grid may be referred to as an interactive report. End users view, analyze, and make changes to analytic model data. When end users save their changes, Analytic Calculation Engine recalculates the data and sends the calculated data to the application database.
Common Elements Used in This Document
Term Definition
New Cube Collection icon
Click the New Cube Collection icon to create a new cube collection.
New Cube icon
Click the New Cube icon to create a new data cube.
Attach Cubes icon
Click the Attach Cubes icon to add existing data cubes to the selected cube collection.
New Dimension icon
Click the New Dimension icon to create a new dimension.
Attach Dimension icon
Click the Attach Dimension icon to attach one or more dimensions to the selected data cube.
Detach Dimension icon
Click the Detach Dimension icon to detach one or more dimensions from the selected data cube.
Validate Model icon
Click the Validate Model icon to validate the analytic model.
Find Part icon
Click the Find Part icon to find all of the locations of the selected part in the analytic model.
Causes and Effects Tool icon
Click the Causes and Effects Tool icon to browse through the cube collections and data cubes of your analytic model to view the causes, effects, and inputs of data cubes.
Direct Causes icon
Click the Direct Causes icon to display the direct causes of the selected data cube.
Direct Effects icon
Click the Direct Effects icon to display the direct effects of the selected data cube.
Validate Model icon
Click the Accept Changes icon to accept the changes you made to the rule.
Cancel Changes icon
Click the Cancel Changes icon to cancel the changes you made to the rule.
