Inserting a Data Cube Reference into a Rule
To insert a data cube reference into a rule:
Select to access PeopleSoft Application Designer.
After signing in to the PeopleSoft Application Designer, open an analytic model definition.
Select the data cube whose formula you want to define or edit.
Place the cursor at the location of the rule into which you want to insert the data cube reference.
Perform one of these actions:
In the part browser, click on the data cube to which you want to refer.
Enter the name of the data cube.
If you enter a data cube reference for a data cube that does not exist, the analytic calculation engine returns an error when validating the analytic model.
Select and click on the data cube to which you want to refer.
