Inserting a Dimension Reference into a Rule
To insert a dimension reference into a rule:
  1. Select Start, and then Programs, and then PeopleTools 8.5x, and then Application Designer to access PeopleSoft Application Designer.
  2. After signing in to the PeopleSoft Application Designer, open an analytic model definition.
  3. Select the data cube whose formula you want to define or edit.
  4. Place the cursor at the location of the rule into which you want to insert the dimension reference.
  5. Perform one of these actions:
    1. In the part browser, click the dimension to which you want to refer.
    2. Enter the name of the dimension.
      If you enter a dimension reference for a dimension that does not exist, the analytic calculation engine returns an error when validating the analytic model.
    3. Select Edit, and then Paste Dimension and click on the dimension to which you want to refer.
