Setting Project Options
Set processing options for all project operations in the Project Options dialog box:
This example illustrates the fields and controls on the Project options dialog box. You can find definitions for the fields and controls later on this page.
Options Dialog box: Project Tab
To set project options:
  1. Select Tools, and then Options.
    The Options dialog box appears.
  2. Select the Project tab in the Options dialog box.
    Define when and how definitions are added to the project and how the project appears in the project workspace.
    Field or Control Description
    When definition is opened
    Automatically inserts any definition that you open into the current project.
    When definition is modified and saved, or deleted
    Automatically inserts any definition that you save or delete into the current project.
    Manually
    Does not automatically insert any definition into the current project. This value is the default option. Use the Insert menu bar to insert a definition into the project.
    Do not insert related definitions with current definition
    Does not prompt you to include related definitions. Inserts only the specified definition, not related definitions.
    Prompt user to pick related definitions to insert
    After you select Insert, and then Current Definition into Project a dialog box appears, prompting you to pick which related definitions to insert.
    Reload last project at startup
    When starting PeopleSoft Application Designer, the project that was last opened in the previous session opens automatically.
    Show definitions in project
    Displays a black mark next to icons for definitions that are explicitly in a project (Development view) to indicate that they are in the project. Attribute definitions, which are not explicitly part of the project, are not marked.
    Prompt for properties when definition is saved
    Prompts you with a definition properties dialog box before you can save the definition.
    Suppress PeopleCode compile success messages
    Suppress the messages for successful PeopleCode program compiles and compile warnings displayed on the Validate tab if you are importing a project and have selected the option: Compile PeopleCode after import.
    Only errors will be displayed if selected.
    See Lifecycle Management Guide: Copying Projects.
