Setting General Properties
Access the Program Properties dialog box and select the General tab. You can specify identification values for your Application Engine program.
Field or Control Description
Owner ID
(Optional) Enter the owner ID for the program. The owner ID is a way to identify which definitions are owned by which PeopleSoft applications, such as PeopleSoft General Ledger, Accounts Receivables, and so on. The values in the drop-down list are Translate table values associated with the OBJECTOWNERID field.
