Using PeopleCode in Application Engine Programs
This section provides an overview of PeopleCode and Application Engine programs and discusses how to:
  • Decide when to use PeopleCode.
  • Consider the program environment.
  • Access state records with PeopleCode.
  • Use If/Then logic.
  • Use PeopleCode in loops.
  • Use the AESection class.
  • Make synchronous online calls to Application Engine programs.
  • Use the file class.
  • Call COBOL modules.
  • Call PeopleTools application programming interfaces (APIs).
  • Use the CommitWork function.
  • Call WINWORD Mail Merge
  • Use PeopleCode examples.
