Accessing the SQL Editor from Application Engine Programs
You can access the SQL Editor from the following action types:
  • Do Select
  • Do Until
  • Do When
  • Do While
  • SQL
The following example shows an Application Engine SQL code in the SQL Editor:
Example of an Application Engine program in the SQL Editor window
To access the SQL Editor from an Application Engine program:
  1. Open the Application Engine program.
  2. Select the action.
  3. Either right-click and select View SQL, or select View, SQL.
    Select the database type and effective date for this SQL in the section, not in the SQL Editor.
