Defining Activity Guide System Options
Use the Activity Guide System Options page to define integration with Approval Workflow Engine (AWE).
Navigation:
PeopleTools, and then Activity Guides, and then Activity Guide System Options
This example illustrates the fields and controls on the Activity Guide System Options page. You can find definitions for the fields and controls later on this page.
Classic Approval Chain
Field or Control Description
Menu Name
Enter the menu name that contains the classic AWE component—for example, EOAW_APPROVAL_WORKFLOW.
Component Name
Enter the name of the classic AWE component—for example, EOAW_APPCHAIN_VIEW.
Fluid Approval Chain
Fluid Menu
Enter the menu name that contains the fluid AWE component—for example, EOAWMA_MAIN_FL.
Fluid Component
Enter the name of the fluid AWE component—for example, EOAWMA_MAIN_FL.
