Using the POSTRPT_DMN Application Engine Daemon Program
Using the PostReport PeopleCode class object implies that a PeopleCode function has been written using this class and is invoked either from an Application Engine or an Application Server.
Sending a single request through an Application Engine can incur a large overhead; therefore, we recommend running the program from PSDAEMON using the POSTRPT_DMN Application Engine program.
The POSTRPT_DMN program monitors for any requests to post by searching for new XML files in a designated directory. The XML file contains all the parameters required by the PostReport PeopleCode class object to post the request to the Report Repository. The program reads the parameters using the POST_REPORT_XML file layout. The following table shows a listing of these parameters:
XML Attribute Tag Corresponding PostReport Attribute Description Data Type Required Notes
PRCSINSTANCE
ProcessInstance
Process instance
Integer
No
If no process instance is specified, the system assigns a new instance.
CONTENTID
ReportId
Content ID
Integer
No
A unique content ID is assigned for each valid request.
PRCSNAME
PrcsName
Process name
Character (12)
Yes
The process name must be defined in the Process Definition table.
PRCSTYPE
PrcsType
Process type
Character (30)
Yes
The process type must be defined in the Process Type Definition table.
REPORTPATH
SourceReportPath
Report directory
Character (254)
Yes
The full absolute path where files and reports are retrieved.
Note: After the Distribution Agent has transferred the files to the Report Repository, this directory is deleted.
CONTENT_DESCR
ReportDescr
Report description
Character (254)
Yes
The description that appears in Report Manager.
EXPIRATION_DATE
ExpirationDate
Expiration date
Date
No
In YYYYMMDD format. If not specified, the system uses the Retention Days value from System Settings.
FOLDER
ReportFolder
Folder name
Character (18)
No
If not specified, the system uses the default from the Report Folder Administration.
SERVER
ServerName
Process Scheduler server name
Character (8)
Yes
You must define the server name specified in the Server Definition table.
OUTDESTFORMAT
OutDestFormat
Output destination format
Character (3)
No
See the following tablefor valid values.
DISTIDTYPE
Passed as the first parameter of the AddDistributionOption method of the PostReport class
Identifier specified if the DISTID value is either User or Role.
Character (30)
Yes
The value is either USER, which indicates a user ID, or ROLE, which indicates a role ID.
DISTID
Passed as the second parameter of the AddDistributionOption method of the PostReport class
User or Role authorized to view the report
Character (30)
Yes
For the POSTRPT_DMN program to process a request using the PostReport PeopleCode class example above, you must create an XML file using the following content:
<?xml version="1.0"?>
<CONTENTINFO>
   <PRCSNAME>XRFWIN</PRCSNAME>
   <PRCSTYPE>SQR REPORT</PRCSTYPE>
   <CONTENT_DESCR>New SQR Report</CONTENT_DESCR>
   <REPORTPATH>\\server9000\report\sqr_xrfwin</REPORTPATH>
   <OUTDESTFORMAT>PDF</OUTDESTFORMAT>
   <FOLDER>SQR Reports</FOLDER>
   <SERVER>PSNT</SERVER>
   <AUTHORIZED_LIST>
       <DISTID>VP1</DISTID>
       <DISTIDTYPE>USER</DISTIDTYPE>
		</AUTHORIZED_LIST>
		<AUTHORIZED_LIST>
       <DISTID>Managers</DISTID>
       <DISTIDTYPE>ROLE</DISTIDTYPE>
   </AUTHORIZED_LIST>
</CONTENTINFO>
Output Destination Format Values
The OUTDESTFORMAT attribute can contain either the value of the file extension or the numeric value of the format, as shown in the following table:
Format Format Extension Numeric Value
Acrobat PDF
PDF
2
Delimited Files
CSV
3
HP Format
HP
4
HTML
HTM
5
Line Printer
LP
6
MS Excel Spreadsheet
XLS
8
MS WinWord Document
DOC
9
PostScript
PS
10
Rich Text Format
RTF
12
SQR Format
SPF
13
Text
TXT
14
XML
XML
17
DataMover Data File
DAT
18
Other
OTHER
14
