Import Manufacturer Parts
After creating or importing manufacturers, you can import manufacturer parts (MPN). Use the EGP_TRADING_PARTNER_ITEMS_INTF tab to enter MPN data.
The following table defines the key data columns for MPNs:
Column Type Data Description
Trading Partner Item Number Manufacturer Part Number
Trading Partner Number Manufacturer Registry ID; obtained from Product Development
Trading Partner Type MANUFACTURER
Start Date The date when this part was added to Product Development; must be earlier than the AML Effectivity Date
End Date The date when this part is no longer active or usable
Example MPN Data:
Trading Partner Item Number Trading Partner Number (Registry ID) Trading Partner Type Start Date End Date
FC123 1000009 MANUFACTURER 2010/01/01 12:00:00 AM
L123 1000015 MANUFACTURER 2016/01/01 12:00:00 AM
S123 1000023 MANUFACTURER 2012/01/01 12:00:00 AM
