Large-Scale Update to a New External System from Oracle Fusion Cloud Product Lifecycle Management
In this use case you might authorize a new external system and populate it by quickly extracting a large volume of items that are eligible for E-commerce.
An example of an E-commerce system might be Shopify.
| Description | Integration Type | Integration Options | Notes |
This use-case scenario usually demands:
Outbound |
Item web services aren't recommended for this use case. |
