Automated Incremental Medium/High Volume Update to External Systems from Oracle Fusion Cloud Product Lifecycle Management
In this use case you might have an external system where you periodically need to cascade the changes made in Oracle Fusion Cloud Product Lifecycle Management (PLM).
An example of this use case might be the addition of a new accessory on Shopify.
| Description | Integration Type | Integration Options | Notes |
This use-case scenario usually demands:
Outbound |
Item web services aren't recommended for this use case. |
