Using the Explain Plan Feature
Follow these steps to use the EXPLAIN PLAN functionality:
About EXPLAIN PLAN Result Tab
The result of the EXPLAIN PLAN for a SQL statement is a tree structure, with nodes that can be expanded, if applicable.
The Operation column is and always appears. Settings in the Query Window Options Page determine what other columns appear. You can see different columns by changing the EXPLAIN PLAN options.
When you locate the mouse in the Operation column, a tooltip appears displaying the full details of the Operation in that row. In the above example, when you locate the mouse in the row (SELECT statement), you can see the complete SQL statement for the Explain Plan result that you have selected in the Query Editor.
When you click on any column, the whole row is selected.
An error message appears here if there is any error in retrieving the EXPLAIN PLAN.
The columns in the result tab are described in the next section, EXPLAIN PLAN Columns Table.
This table lists and describes the columns that can be viewed in the EXPLAIN PLAN result tab. Which columns appear depends on the settings of the EXPLAIN PLAN Options page, described in the next section, Query Window Options Page.
| Column | Description |
Operation |
The operation in the execution plan. To view the complete SQL statement of the explain plan, locate the cursor in the top level row of a SQL statement section under the Operation column. The SQL text can then be viewed in a Tooltip control. This column always appears, regardless of settings. |
Optimizer |
Current mode of the optimizer. Default is checked. |
Cost |
Cost of the operation as estimated by the optimization approach. Cost is not determined for table access operations. The value of this column is a function of the |
Cardinality |
Number of rows accessed by the operation, as estimated by the optimization approach. Default is checked. |
Bytes |
Number of bytes accessed by the operation, as estimated by the optimization approach. Default is checked. |
Partition Start |
Start partition of a range of accessed partitions. It can be one of the following values:
Partition Stop |
Step that has computed the pair of values of the |
CPU Cost |
CPU cost of the operation, as estimated by the optimization approach. The value of this column is proportional to the number of cycles required for the operation. For statements that use the rule-based approach, this column is null. Default is checked. |
IO Cost |
I/O cost of the operation, as estimated by the optimization approach. The value of this column is proportional to the number of data blocks read by the operation. For statements that use the rule-based approach, this column is null. Default is checked. |
Access Predicates |
Predicates used to locate rows in an access structure. For example, start or stop predicates for an index range scan. Default is unchecked. |
Filter Predicates |
Predicates used to filter rows before producing them. Default is unchecked. |
Time |
Elapsed time in seconds of the operation, as estimated by optimization approach. For statements that use the rule-based approach, this column is null. Default is checked. |
