Subprogram Parts
A subprogram begins with a subprogram heading, which specifies its name and (optionally) its parameter list.
Like an anonymous block, a subprogram has these parts:
Declarative part (optional)
This part declares and defines local types, cursors, constants, variables, exceptions, and nested subprograms. These items cease to exist when the subprogram completes execution.
This part can also specify pragmas.
The declarative part of a subprogram does not begin with the keyword
DECLARE, as the declarative part of an anonymous block does. -
Executable part (required)
This part contains one or more statements that assign values, control execution, and manipulate data. (Early in the application design process, this part might contain only a
NULLstatement, as in Example 4-35.) -
Exception-handling part (optional)
This part contains code that handles runtime errors.
Topics
See Also:
"Pragmas"
"Procedure Declaration and Definition" for the syntax of procedure declarations and definitions
"Subprogram Parameters" for more information about subprogram parameters
Example 8-1 Declaring, Defining, and Invoking a Simple PL/SQL Procedure
In this example, an anonymous block simultaneously declares and defines a procedure and invokes it three times. The third invocation raises the exception that the exception-handling part of the procedure handles.
DECLARE first_name employees.first_name%TYPE; last_name employees.last_name%TYPE; email employees.email%TYPE; employer VARCHAR2(8) := 'AcmeCorp'; -- Declare and define procedure PROCEDURE create_email ( -- Subprogram heading begins name1 VARCHAR2, name2 VARCHAR2, company VARCHAR2 ) -- Subprogram heading ends IS -- Declarative part begins error_message VARCHAR2(30) := 'Email address is too long.'; BEGIN -- Executable part begins email := name1 || '.' || name2 || '@' || company; EXCEPTION -- Exception-handling part begins WHEN VALUE_ERROR THEN DBMS_OUTPUT.PUT_LINE(error_message); END create_email; BEGIN first_name := 'John'; last_name := 'Doe'; create_email(first_name, last_name, employer); -- invocation DBMS_OUTPUT.PUT_LINE ('With first name first, email is: ' || email); create_email(last_name, first_name, employer); -- invocation DBMS_OUTPUT.PUT_LINE ('With last name first, email is: ' || email); first_name := 'Elizabeth'; last_name := 'MacDonald'; create_email(first_name, last_name, employer); -- invocation END; /
Result:
With first name first, email is: John.Doe@AcmeCorp With last name first, email is: Doe.John@AcmeCorp Email address is too long.
Additional Parts for Functions
A function has the same structure as a procedure, except that:
A function heading must include a
RETURNclause, which specifies the data type of the value that the function returns. (A procedure heading cannot have aRETURNclause.) -
In the executable part of a function, every execution path must lead to a
RETURNstatement. Otherwise, the PL/SQL compiler issues a compile-time warning. (In a procedure, theRETURNstatement is optional and not recommended. For details, see "RETURN Statement".) -
A function declaration can include these options:
| Option | Description |
Helps the optimizer avoid redundant function invocations. |
Enables the function for parallel execution, making it safe for use in concurrent sessions of parallel DML evaluations. |
Makes a table function pipelined, for use as a row source. |
Stores function results in the PL/SQL function result cache. |
See Also:
"Function Declaration and Definition" for the syntax of function declarations and definitions, including descriptions of the items in the preceding table
"PL/SQL Function Result Cache" for more information about the
RESULT_CACHEoption
Example 8-2 Declaring, Defining, and Invoking a Simple PL/SQL Function
In this example, an anonymous block simultaneously declares and defines a function and invokes it.
DECLARE -- Declare and define function FUNCTION square (original NUMBER) -- parameter list RETURN NUMBER -- RETURN clause AS -- Declarative part begins original_squared NUMBER; BEGIN -- Executable part begins original_squared := original * original; RETURN original_squared; -- RETURN statement END; BEGIN DBMS_OUTPUT.PUT_LINE(square(100)); -- invocation END; /
Result:
10000
RETURN Statement
The RETURN statement immediately ends the execution of the subprogram or anonymous block that contains it. A subprogram or anonymous block can contain multiple RETURN statements.
Topics
See Also:
"RETURN Statement" for the syntax of the RETURN statement
RETURN Statement in Function
In a function, every execution path must lead to a RETURN statement and every RETURN statement must specify an expression. The RETURN statement assigns the value of the expression to the function identifier and returns control to the invoker, where execution resumes immediately after the invocation.
In a pipelined table function, a RETURN statement need not specify an expression. For information about the parts of a pipelined table function, see "Creating Pipelined Table Functions".
In Example 8-3, the anonymous block invokes the same function twice. The first time, the RETURN statement returns control to the inside of the invoking statement. The second time, the RETURN statement returns control to the statement immediately after the invoking statement.
In Example 8-4, the function has multiple RETURN statements, but if the parameter is not 0 or 1, then no execution path leads to a RETURN statement. The function compiles with warning PLW-05005: subprogram F returns without value at line 11.
Example 8-5 is like Example 8-4, except for the addition of the ELSE clause. Every execution path leads to a RETURN statement, and the function compiles without warning PLW-05005.
Example 8-3 Execution Resumes After RETURN Statement in Function
DECLARE
x INTEGER;
FUNCTION f (n INTEGER)
RETURN INTEGER
IS
BEGIN
RETURN (n*n);
END;
BEGIN
'f returns ' || f(2) || '. Execution returns here (1).'
x := f(2);
DBMS_OUTPUT.PUT_LINE('Execution returns here (2).');
END;
Result:
f returns 4. Execution returns here (1).Execution returns here (2).
Example 8-4 Function Where Not Every Execution Path Leads to RETURN Statement
CREATE OR REPLACE FUNCTION f (n INTEGER) RETURN INTEGER AUTHID DEFINER IS BEGIN IF n = 0 THEN RETURN 1; ELSIF n = 1 THEN RETURN n; END IF; END; /
Example 8-5 Function Where Every Execution Path Leads to RETURN Statement
RETURN INTEGER
AUTHID DEFINER
IS
BEGIN
IF n = 0 THEN
RETURN 1;
ELSIF n = 1 THEN
RETURN n;
ELSE
RETURN n*n;
END IF;
END;
BEGIN
FOR i IN 0 .. 3 LOOP
DBMS_OUTPUT.PUT_LINE('f(' || i || ') = ' || f(i));
END LOOP;
END;
Result:
f(0) = 1 f(1) = 1 f(2) = 4 f(3) = 9
RETURN Statement in Procedure
In a procedure, the RETURN statement returns control to the invoker, where execution resumes immediately after the invocation. The RETURN statement cannot specify an expression.
In Example 8-6, the RETURN statement returns control to the statement immediately after the invoking statement.
Example 8-6 Execution Resumes After RETURN Statement in Procedure
DECLARE
PROCEDURE p IS
BEGIN
DBMS_OUTPUT.PUT_LINE('Inside p');
RETURN;
DBMS_OUTPUT.PUT_LINE('Unreachable statement.');
END;
BEGIN
p;
DBMS_OUTPUT.PUT_LINE('Control returns here.');
END;
Result:
Inside p Control returns here.
RETURN Statement in Anonymous Block
In an anonymous block, the RETURN statement exits its own block and all enclosing blocks. The RETURN statement cannot specify an expression.
In Example 8-7, the RETURN statement exits both the inner and outer block.
Example 8-7 Execution Resumes After RETURN Statement in Anonymous Block
BEGIN
BEGIN
DBMS_OUTPUT.PUT_LINE('Inside inner block.');
RETURN;
END;
DBMS_OUTPUT.PUT_LINE('Inside outer block. Unreachable statement.');
END;
Result:
Inside inner block.
