Unload and Load Vectors Using Oracle Data Pump
Starting with Oracle Database 26ai, Oracle Data Pump enables you to use multiple components to load and unload vectors to databases.
Oracle Data Pump technology enables very high-speed movement of data and metadata from one database to another. Oracle Data Pump is made up of three distinct components: Command-line clients, expdp and impdp; the DBMS_DATAPUMP PL/SQL package (also known as the Data Pump API); and the DBMS_METADATA PL/SQL package (also known as the Metadata API).
Unloading and Loading a table with vector datatype columns is supported in all modes (FULL, SCHEMA, TABLES) using all the available access methods (DIRECT_PATH, EXTERNAL_TABLE, AUTOMATIC, INSERT_AS_SELECT).
Examples of Vector Export and Import Syntax
expdp <username>/<password>@<Database-instance-TNS-alias>  dumpfile=<dumpfile-name>.dmp directory=<directory-name> full=y metrics=y access_method=direct_path
expdp <username>/<password>@<Database-instance-TNS-alias>  dumpfile=<dumpfile-name>.dmp directory=<directory-name> schemas=<schema-name> metrics=y access_method=external_table
expdp <username>/<password>@<Database-instance-TNS-alias>  dumpfile=<dumpfile-name>.dmp directory=<directory-name> tables=<schema-name>.<table-name> metrics=y access_method=direct_path
impdp <username>/<password>@<Database-instance-TNS-alias>  dumpfile=<dumpfile-name>.dmp directory=<directory-name> metrics=y access_method=direct_path
See Also:
