PL/SQL General Connection Attributes
Use these attributes to control and specify options for PL/SQL compilation, processing, and the number of session cursors to cache.
You can use the ALTER SESSION statement, described in Oracle TimesTen In-Memory Database SQL Reference, to change the PL/SQL parameters to override the values assigned to the PL/SQL general connection attributes at connection time.
The PL/SQL general connection attributes are described in detail next.
