CREATE INDEX
The CREATE
INDEX
statement creates an index on one or more columns of a table or a materialized view.
Required Privilege
- If the owner, no privilege is required.
- If not the owner, the
CREATE
ANY
INDEX
system privilege or theINDEX
object privilege is required.
Usage with TimesTen Scaleout
This statement is supported with TimesTen Scaleout. You can create a global or a local index.
SQL Syntax
The syntax to create a range index follows. Use the GLOBAL
keyword, the optional INCLUDE
clause, and the optional IndexDistributionClause
clause to create a global index. A global index is supported only in TimesTen Scaleout:
CREATE [GLOBAL][UNIQUE] INDEX [Owner.]IndexName ON [Owner.]TableName (ColumnName [ASC | DESC][,... ]) [INCLUDE (ColumnName[,…])] [IndexDistributionClause]
The syntax to create a hash index follows. Use the GLOBAL
keyword to create a global index. The optional INCLUDE
clause can only be used with a global index. A global index is supported only in TimesTen Scaleout:
CREATE [GLOBAL][UNIQUE] HASH INDEX [Owner.]IndexName ON [Owner.]TableName (ColumnName [ASC | DESC][,... ] ) [INCLUDE (ColumnName [,…])] [ PAGES = RowPages | CURRENT ] [IndexDistributionClause]
The syntax for IndexDistributionClause
can only be used for a global index (supported in TimesTen Scaleout):
IndexDistributionClause::= DISTRIBUTE BY HASH [(ColumnName [,…])]
Parameters
Parameter | Description |
The In TimesTen Scaleout:
You can specify |
Specify |
Name to be assigned to the new index. A table cannot have two indexes with the same name. If the owner is specified, it must be the same as the owner of the table. |
Designates the table or materialized view for which an index is to be created. |
Name of a column to be used as an index key. You can specify up to 32 columns in order from major index key to minor index key. |
Specifies the order of the index to be either ascending (the default) or descending. In TimesTen, this clause is currently ignored. |
The |
The If you specify The value for Do not specify |
You can specify the If you do not specify this clause, the column(s) defined in the global index definition form the distribution key. If you do specify this clause, you can optionally specify the
ColumnName clause:
Indexes in TimesTen Scaleout
- Global index: Maps all rows in the table to a hash distribution scheme. When you create a global index, TimesTen Scaleout creates a materialized view with a local index and a hash distribution scheme to the index key columns. The local index that is created on the materialized view further optimizes query performance.
- Local index: Is created in each database element. The index in this database element maps to rows in the table in this database element. Queries on index columns that do not include the distribution key columns on the table require communication with an element in every replica set.
See Understanding Indexes in the Oracle TimesTen In-Memory Database Scaleout User's Guide for information on using indexes in TimesTen Scaleout.
Choosing a Global or a Local index in TimesTen Scaleout
Use a global index for:
- Unique columns: A global unique index optimizes query execution by performing unique constraint checks more efficiently. TimesTen Scaleout uses the distribution key columns for uniqueness verification instead of accessing all replica sets. However, if the distribution key is a subset of the index key, create a local index.
- Queries that have an equality predicate that do not include all of the columns in the distribution key of the table.
- A group of columns that are frequently joined in queries with primary key columns.
- Non-index columns that are frequently used in queries: Define a global index with the
INCLUDE
clause to include those non-index columns. In such a case, the table does not need to be accessed to satisfy the query. - An index where the index key is a prefix of the distribution key of the table.
- Use a local index for:
- Non-unique columns: If the index key consists of only non-unique columns, create a local non-unique index.
- An index key that has the same columns as the distribution key for the table.
- The situation where the distribution key of the table is a prefix of the index key.
- Queries that have an equality predicate that includes all columns in the distribution key of the table.
See Understanding Indexes in the Oracle TimesTen In-Memory Database Scaleout User's Guide for more information.
Description of Global Indexes
- You must specify the
GLOBAL
keyword to create a global index. An index is local by default. - Global indexes by default are distributed by hash and can only be distributed by hash. Local indexes are not distributed.
- When you create a global index, TimesTen Scaleout internally creates its own materialized view and its own local index on that materialized view.
- Global indexes result in more efficient query execution with joins. However DML operations are slower due to the maintenance of the internal materialized view (that is created when you define a global index).
- When a new element is added in the grid, the schema is replicated on the new element. In addition, the rows are redistributed, and the indexes are rebuilt. This includes the global indexes. Similarly, when an element is removed from the grid, the rows are redistributed and the indexes are rebuilt.
- You can define a global index on a table distributed by hash and on a table distributed by reference. Global indexes on parent and child (first-level reference) tables are supported. However, you cannot define a global index on grandchild tables or any tables that are not first-level reference tables.
- You cannot define a global index on a table distributed by duplicate.
Restrictions on global indexes:
- The column list for the distribution key cannot contain the
ROWID
pseudocolumn or a column of typeROWID
. - Not supported on a global temporary table.
- Not supported on readonly cache groups.
- Not supported on a materialized view.
Syntax and Semantic Rules for Global Indexes
You must specify the GLOBAL
keyword to create a global index. If you do not specify the GLOBAL
keyword, a local index is created. Global indexes are distributed by hash on index key columns.
GLOBAL
keyword, you can optionally specify these clauses that are specific to global indexes:
INCLUDE
clause: Optional clause that enables you to include non-key columns in the index. If such columns are frequently accessed by queries that use the index, this may improve performance.-
: Optional clause that enables you to specify what columns to use for the hash distribution. If you do not specify this clause, then the index columns form the distribution key. The distribution key of the index cannot be the same as the distribution key of the table. -
Examples:
Global range index:
Command> CREATE GLOBAL INDEX globalindex1 ON mytab (a) INCLUDE (b,c) DISTRIBUTE BY HASH (a); Command> indexes mytab; Indexes on table SAMPLEUSER.MYTAB: MYTAB: unique range index on columns: C B GLOBALINDEX1: global non-unique range index on columns: A Included columns: B C 2 indexes found. 2 indexes found on 1 table. Command> drop table mytab;
Global hash index:
Command> CREATE TABLE mytab (c TT_INTEGER NOT NULL, b TT_INTEGER NOT NULL, a TT_INTEGER NOT NULL, PRIMARY KEY (c,b)) DISTRIBUTE BY HASH (a,b); Command> CREATE GLOBAL HASH INDEX globalhashindex1 ON mytab(a) INCLUDE (b,c) PAGES=200 DISTRIBUTE BY HASH (a); Command> indexes MYTAB; Indexes on table SAMPLEUSER.MYTAB: MYTAB: unique range index on columns: C B GLOBALHASHINDEX1: global non-unique hash index on columns: A Included columns: B C 2 indexes found. 2 indexes found on 1 table.
See Examples: TimesTen Scaleout for additional examples.
General Description of Indexes in TimesTen Scaleout
TimesTen creates a nonunique range index by default. Specify
CREATE
UNIQUE INDEX
to create a unique range index. -
To create a nonunique hash index, specify
CREATE
HASH
INDEX
. To create a unique hash index, specifyCREATE
UNIQUE
HASH
INDEX
If
UNIQUE
is specified, all existing rows must have unique values in the indexed column(s). -
The new index is maintained automatically until the index is deleted by a
DROP INDEX
statement or until the table associated with it is dropped. -
Any prepared statements that reference the table with the new index are automatically prepared again the next time they are executed. Then the statements can take advantage, if possible, of the new index.
An index on a temporary table cannot be created by a connection if any other connection has a non-empty instance of the table.
If you are using linguistic comparisons, you can create a linguistic index. A linguistic index uses sort key values and storage is required for these values. Only one unique value for
NLS_SORT
is allowed for an index. For more information on linguistic indexes and linguistic comparisons, see Using Linguistic Indexes in Oracle TimesTen In-Memory Database Operations Guide. -
If you create indexes that are redundant, TimesTen generates warnings or errors. Call
ttRedundantIndexCheck
to see the list of redundant indexes for your tables. -
To change the size or type of a hash index, drop the hash index and create a new index.
A hash index is created with a fixed size that remains constant for the life of the table. To resize the hash index, drop and recreate the index. If the hash index has insufficient pages it results in hash collisions which slows down the index look-up. Hash key comparison is a fast operation, so a small number of hash collisions should not cause a performance problem for TimesTen.
To ensure that your hash index is sized correctly, your application must indicate the expected size of your table with the value of the
RowPages
parameter of theSET
PAGES
clause. Compute this value by dividing the number of expected rows in your table by 256. For example, if your table has 256,000 rows, specify 1000 for the value of RowPages (256000/256=1000). -
The maximum number of columns that can be specified for an index is 32.
Using Indexes in Query Processing
Proper indexes can improve query performance. Some queries can benefit from the use of indexes and some queries do not benefit from the use of indexes. Additionally, the choice of indexes for your queries is important.
A range index is ideal for processing range searches and exact matches, especially if most of the values in the index columns are unique. For example, if a range index is defined on columns (C1,C2)
, the index can be used to process the following types of predicates. ConstantOrParam
refers to a constant value or dynamic parameter and range
refers to the operators >,<,>=, or <=:
C1
=ConstantOrParam
AND
C2
=ConstantOrParam
C1
=ConstantOrParam
AND
C2
range
ConstantOrParam
C1
=ConstantOrParam
C1
range
ConstantOrParam
A range index efficiently processes equality and range predicates and efficiently processes sort and group operations. Use range indexes on index columns with many unique values. The order of columns you specify in a range index is relevant. The order of expressions in the predicate of a query that uses the range index is not relevant. When your query is processed, only one range index is used for each scan of your table even if you have defined multiple range indexes on your table.
A hash index efficiently processes equality predicates. You must size your hash index correctly for optimal performance. Use the PAGES
parameter to size your hash index. If you specify a PAGES
value that is too small, a large number of hash collisions may result, leading to performance degradation for statements that access the hash index. The order of columns specified in the hash index is not relevant and the order of expressions in the predicate of the query that uses the hash index is not relevant. If either a hash index or a range index can be used to process a particular equality predicate, the hash index is chosen because a lookup in a hash index is faster than a scan of a range index.
You can influence the indexes used by the optimizer by setting statement level or transaction level optimizer hints. see Statement Level Optimizer Hints for information on statement level optimizer hints. For more information on transaction level optimizer hints, see ttOptSetFlag, ttOptSetOrder, or ttOptUseIndex in the Oracle TimesTen In-Memory Database Reference.
These examples illustrate the syntax requirements for creating a global index. You must specify the GLOBAL
Illustrate Global Index Syntax
This example illustrates the supported syntax for a global index.
Create a table with three columns (c,b,a
) and define a primary key on two of those columns (c,b)
. Distribute the table by hash on columns (a,b)
(c,b)
. Command> CREATE TABLE mytab1 (c TT_INTEGER NOT NULL, b TT_INTEGER NOT NULL, a TT_INTEGER NOT NULL,
Command> CREATE GLOBAL UNIQUE INDEX mygix1 ON mytab1 (c,b);
Command> indexes mytab1;
Indexes on table SAMPLEUSER.MYTAB1:
MYGIX1: global unique range index on columns:
C
B
MYTAB1: unique range index on columns:
C
B
2 indexes found.
INCLUDE
clause.
Command> CREATE GLOBAL INDEX mygix2 ON MYTAB1(b) include (a);
C
B
C
B
MYGIX2: global non-unique range index on columns:
B
Included columns:
A
3 indexes found.
3 indexes found on 1 table.
b
. Command> DROP INDEX mygix2;
Command> CREATE GLOBAL INDEX mygix2 ON MYTAB1(b) INCLUDE (a) DISTRIBUTE BY HASH(b);
Command> INDEXES mytab1
C
B
C
B
B
Included columns:
A
3 indexes found.
Create a global hash index.
Command> CREATE GLOBAL HASH INDEX mygix3 ON mytab1(a) PAGES =200;
C
B
C
B
MYGIX3: global non-unique hash index on columns:
A
B
Included columns:
A
4 indexes found.
4 indexes found on 1 table.
Distribution Key of Global Index is Same as Distribution Key of Table
This example illustrates that you cannot create a global index whose distribution key is the same as the distribution key of the table. In this example, the mytab1
table is distributed by hash on columns (a,b)
. An attempt to create a global index, with columns (a,b)
as the distribution key, results in an error.
Command> CREATE TABLE mytab1 (a TT_INTEGER NOT NULL, b TT_INTEGER NOT NULL, c TT_INTEGER NOT NULL) DISTRIBUTE BY HASH (a,b); Command> CREATE GLOBAL INDEX gix1 ON mytab1(a,b,c) DISTRIBUTE BY HASH (a,b); 2253: Distribution key for global index cannot be same as that of the table or other global index. Consider creating a local index. The command failed.
Global Index Creates Its Own Materialized View and its Own Local Index
This example illustrates that when you create a global index, TimesTen Scaleout creates its own internal materialized view and its own local index. Create the mytab2
table distributed by hash on columns (a,b)
. Create a global non-unique range index distributed by hash on columns (b,a)
. Run the ttIsql
indexes
command to show the gix2
global index is created as well as an internal local index on the internal materialized view. Then, run the ttIsql
views
command to show an internal materialized view is also created as a result of creating the global index. Run the ttIsql
describe
command to show the internal materialized view. Note that you cannot explicitly drop the internal materialized view or the internal local index.
Command> CREATE TABLE mytab2 (a TT_INTEGER NOT NULL, b TT_INTEGER NOT NULL, c TT_INTEGER NOT NULL) DISTRIBUTE BY HASH (a,b); Command> CREATE GLOBAL INDEX gix2 ON mytab2(a,b,c) DISTRIBUTE BY HASH (b,a); Command> indexes; Indexes on materialized view SAMPLEUSER.$GV9B55D3955D52: $GVI9B55D3955D52: non-unique range index on columns: A B C 1 index found. Indexes on table SAMPLEUSER.MYTAB2: GIX2: global non-unique range index on columns: A B C 1 index found. 2 indexes found on 2 tables. Command> views; SAMPLEUSER.$GV9B55D3955D52 1 view found. Command> describe SAMPLEUSER.$GV9B55D3955D52; Materialized view SAMPLEUSER.$GV9B55D3955D52: Global index: GIX2 (table: MYTAB2) Columns: A TT_INTEGER NOT NULL B TT_INTEGER NOT NULL C TT_INTEGER NOT NULL DISTRIBUTE BY HASH (B, A) 1 view found.
Examples: TimesTen Classic
Create a table and then create a unique hash index on col2
. Do not specify the PAGES
clause. If PAGES
is not specified, the current table page count is used for the size of the hash table. Use INDEXES
to verify the index was created. Insert a row in the table, set SHOWPLAN
to 1 and then verify the optimizer uses the hash index.
Command> CREATE TABLE tab (col1 NUMBER PRIMARY KEY NOT NULL, col2 VARCHAR2 (30)); Command> CREATE UNIQUE HASH INDEX hash1 ON tab (col2); Command> INDEXES; Indexes on table TESTUSER.TAB: HASH1: unique hash index on columns: COL2 TAB: unique range index on columns: COL1 2 indexes found. 2 indexes found on 1 table. Command> INSERT INTO tab VALUES (10, 'ABC'); Command> SHOWPLAN 1; Command> SELECT * FROM tab where col2 = 'ABC'; Query Optimizer Plan: STEP: 1 LEVEL: 1 OPERATION: RowLkHashScan TBLNAME: TAB IXNAME: HASH1 INDEXED CONDITION: TAB.COL2 = 'ABC' NOT INDEXED: <NULL> < 10, ABC > 1 row found.
Create a table and create a nonunique hash index on col1
. Use PAGES = CURRENT
to use the current table page count to size the hash index. Use INDEXES
to verify the nonunique hash index is created.
Command> CREATE TABLE tab2 (col1 NUMBER); Command> CREATE HASH INDEX hash_index ON tab2 (col1) PAGES = CURRENT; Command> INDEXES; Indexes on table TESTUSER.TAB2: HASH_INDEX: non-unique hash index on columns: COL1 1 index found. 1 index found on 1 table.
Create table and create unique hash index on col3
. Use PAGES = 100
to specify a page count of 100 for the size of the hash table. Use INDEXES
to verify the unique hash index is created.
Command> CREATE TABLE tab3 (col1 NUMBER, col2 NUMBER, col3 TT_INTEGER); Command> CREATE UNIQUE HASH INDEX unique_hash1 on tab3 (col3) PAGES = 100; Command> INDEXES; Indexes on table TESTUSER.TAB3: UNIQUE_HASH1: unique hash index on columns: COL3 1 index found. 1 index found on 1 table.
The regions
table in the HR
schema creates a unique index on region_id
. Issue the ttIsql
INDEXES
command on table regions
. You see the unique range index regions
Command> INDEXES REGIONS; Indexes on table SAMPLEUSER.REGIONS: REGIONS: unique range index on columns: REGION_ID (referenced by foreign key index COUNTR_REG_FK on table SAMPLEUSER.COUNTRIES) 1 index found. 1 index found on 1 table.
Attempt to create a unique index i
on table regions
indexing on column region_id
. You see a warning message.
Command> CREATE UNIQUE INDEX i ON regions (region_id); Warning 2232: New index I is identical to existing index REGIONS; consider dropping index I
Call ttRedundantIndexCheck
to see warning message for this index:
Command> CALL ttRedundantIndexCheck ('regions'); < Index SAMPLEUSER.REGIONS.I is identical to index SAMPLEUSER.REGIONS.REGIONS; consider dropping index SAMPLEUSER.REGIONS.I > 1 row found.
Create table redundancy
and define columns co11
and col2
. Create two user indexes on col1
and col2
. You see an error message when you attempt to create the second index r2
. Index r1
is created. Index r2
is not created.
Command> CREATE TABLE redundancy (col1 CHAR (30), col2 VARCHAR2 (30)); Command> CREATE INDEX r1 ON redundancy (col1, col2); Command> CREATE INDEX r2 ON redundancy (col1, col2); 2231: New index R2 would be identical to existing index R1 The command failed.
Issue the ttIsql
command INDEXES
on table redundancy
to show that only index r1
is created:
Command> INDEXES redundancy; Indexes on table SAMPLEUSER.REDUNDANCY: R1: non-unique range index on columns: COL1 COL2 1 index found. 1 index found on 1 table.
This unique index ensures that all part numbers are unique.
CREATE UNIQUE INDEX purchasing.partnumindex ON purchasing.parts (partnumber);
Create a linguistic index named german_index
on table employees1
. To have more than one linguistic sort, create a second linguistic index.
Command> CREATE TABLE employees1 (id CHARACTER (21), id2 character (21)); Command> CREATE INDEX german_index ON employees1 (NLSSORT(id, 'NLS_SORT=GERMAN')); Command> CREATE INDEX german_index2 ON employees1 (NLSSORT(id2, 'nls_sort=german_ci')); Command> indexes employees1; Indexes on table SAMPLEUSER.EMPLOYEES1: GERMAN_INDEX: non-unique range index on columns: NLSSORT(ID,'NLS_SORT=GERMAN') GERMAN_INDEX2: non-unique range index on columns: NLSSORT(ID2,'nls_sort=german_ci') 2 indexes found. 1 table found.
See Also
