Implicit Data Type Conversion
TimesTen converts a value from one data type to another when such a conversion is sensible.
Table 1-6 and Table 1-7 use a matrix to illustrate TimesTen implicit data type conversions. YES in the cell indicates the conversion is supported. NO in the cell indicates the conversion is not supported. The rules for implicit conversion follow the table.
Table 1-6 Implicit data type conversion
| Blank | CHAR | VARCHAR2 | NCHAR | NVARCHAR2 | DATE | TT_DATE | TIMESTAMP | TT_TIMESTAMP |
CHAR |
n/a |
YES |
YES |
YES |
YES |
YES |
YES |
YES |
VARCHAR2 |
YES |
n/a |
YES |
YES |
YES |
YES |
YES |
YES |
NCHAR |
YES |
YES |
n/a |
YES |
YES |
YES |
YES |
YES |
NVARCHAR2 |
YES |
YES |
YES |
n/a |
YES |
YES |
YES |
YES |
DATE |
YES |
YES |
YES |
YES |
n/a |
YES |
YES |
YES |
TT_DATE |
YES |
YES |
YES |
YES |
YES |
n/a |
YES |
YES |
TIMESTAMP |
YES |
YES |
YES |
YES |
YES |
YES |
n/a |
YES |
TT_TIMESTAMP |
YES |
YES |
YES |
YES |
YES |
YES |
YES |
n/a |
NUMERIC |
YES |
YES |
YES |
YES |
NO |
NO |
NO |
NO |
BLOB |
NO |
NO |
NO |
NO |
NO |
NO |
NO |
NO |
CLOB |
YES |
YES |
YES |
YES |
NO |
NO |
NO |
NO |
NCLOB |
YES |
YES |
YES |
YES |
NO |
NO |
NO |
NO |
BINARY/ VARBINARY |
YES |
YES |
YES |
YES |
NO |
NO |
NO |
NO |
ROWID |
YES |
YES |
YES |
YES |
NO |
NO |
NO |
NO |
Table 1-7 Implicit data type conversion (continuation of preceding table)
| Blank | NUMERIC | BLOB | CLOB | NCLOB | BINARY/ VARBINARY | ROWID |
CHAR |
YES |
YES |
YES |
YES |
YES |
YES |
VARCHAR2 |
YES |
YES |
YES |
YES |
YES |
YES |
NCHAR |
YES |
YES |
YES |
YES |
YES |
YES |
NVARCHAR2 |
YES |
YES |
YES |
YES |
YES |
YES |
DATE |
NO |
NO |
NO |
NO |
NO |
NO |
TT_DATE |
NO |
NO |
NO |
NO |
NO |
NO |
TIMESTAMP |
NO |
NO |
NO |
NO |
NO |
NO |
TT_TIMESTAMP |
NO |
NO |
NO |
NO |
NO |
NO |
NUMERIC |
n/a |
NO |
NO |
NO |
NO |
NO |
BLOB |
NO |
n/a |
NO |
NO |
YES |
NO |
CLOB |
NO |
NO |
n/a |
YES |
NO |
NO |
NCLOB |
NO |
NO |
YES |
n/a |
NO |
NO |
BINARY/ VARBINARY |
NO |
YES |
YES |
YES |
n/a |
NO |
ROWID |
NO |
NO |
NO |
NO |
NO |
n/a |
The following rules apply:
During arithmetic operations on and comparisons between character and non-character data types, TimesTen converts from any character data type to a numeric or datetime data type as appropriate. In arithmetic operations between
CHAR/VARCHAR2andNCHAR/NVARCHAR2, TimesTen converts to aNUMBER. -
During arithmetic operations, floating point values
INFandNANare not supported when converting character values to numeric values. -
During concatenation operations, TimesTen converts non-character data types to
CHAR,NCHAR,VARCHAR2, orNVARCHAR2depending on the other operand. -
When comparing a character value with a numeric value, TimesTen converts the character data to a numeric value.
When comparing a character value with a datetime value, TimesTen converts the character data to a datetime value.
During conversion from a timestamp value to a
DATEvalue, the fractional seconds portion of the timestamp value is truncated. -
Conversions from
BINARY_FLOATtoBINARY_DOUBLEare exact. -
Conversions from
BINARY_DOUBLEtoBINARY_FLOATare inexact if theBINARY_DOUBLEvalue uses more bits of precision that supported by theBINARY_FLOAT. -
Conversions between either character values or exact numeric values (
TT_TINYINT,TT_SMALLINT,TT_INTEGER,TT_BIGINT,NUMBER) and floating-point values (BINARY_FLOAT,BINARY_DOUBLE) can be inexact because the character values and the exact numeric values use decimal precision whereas the floating-point numbers use binary precision. -
When manipulating numeric values, TimesTen usually adjusts precision and scale to allow for maximum capacity. In such cases, the numeric data type resulting from such operations can differ from the numeric data type found in the underlying tables.
When making assignments, TimesTen converts the value on the right side of the equal sign (=) to the data type of the target of the assignment on the left side.
When you use a SQL function or operator with an argument of a data type other than the one it accepts, TimesTen converts the argument to the accepted data type as long as TimesTen supports the implicit conversion.
During
INSERT,INSERT... SELECT, andUPDATEoperations, TimesTen converts the value to the data type of the affected column. -
Implicit and explicit
CHAR/VARCHAR2<->NCHAR/NVARCHAR2 conversions are supported. An example of implicit conversion:Command> CREATE TABLE convdemo (c1 CHAR (10), x1 TT_INTEGER); Command> CREATE TABLE convdemo2 (c1 NCHAR (10), x2 TT_INTEGER); Command> INSERT INTO convdemo VALUES ('ABC', 10); 1 row inserted. Command> INSERT INTO convdemo VALUES ('def', 100); 1 row inserted. Command> INSERT INTO convdemo2 SELECT * FROM convdemo; 2 rows inserted. Command> SELECT x1,x2,convdemo.c1, convdemo2.c1 FROM convdemo, convdemo2 WHERE Convdemo.c1 = convdemo2.c1; X1, X2, C1, C1 < 10, 10, ABC , ABC > < 100, 100, def , def > 2 rows found.
