GV$ and V$TTSTATS System Views
These views contain data based on information in the ttStats utility. These views exist in TimesTen Classic, but contain no data.
Table 1-5 shows the ttStats GV$ and V$ views. The GV$ views are listed first in the name column of the table.
Table 1-5 GV$ and V$TTSTATS system views
| Name | Description |
Contains the metadata to determine when to do |
Contains alerts for system resources Supported, but contains 0 rows |
Contains data about the critical checkpoint metric history |
Contains data about the CPU metric history |
Contains data about the critical disk IO metric history |
Contains data about aggregated metrics |
Contains data about raw and non-aggregated metric values |
Contains data about metrics that can be represented in generic format |
Contains data about the history of transaction log holds |
Contains data about the critical network metric history |
Contains data about the optional user annotations for snapshots |
Contains data about the SQL text for the most common SQL commands |
Contains data about the SQL command cache metadata history |
Contains data about the transaction log write metric history |
Contains data about the history of virtual memory usage |
