CSP Issue in EDM 26.07.60: Problem and Solution
Problem
Customer Impact
Following the application of the EPM 26.07.60 monthly patch, the customer observed that Oracle Guided Learning (OGL) was no longer available within the EDMCS user interface. The customer attempted to reconfigure OGL; however, the integration did not reappear in the application.
Issue Pattern
This issue is associated with recent EPM monthly security updates that introduced stricter Content Security Policy (CSP) controls. As a result, the EDMCS–OGL integration failed due to CSP-related errors, causing OGL to become unavailable. The issue was reported to have affected some customers in the NAMER region following the recent patch deployment.
Solution
Product Fix
A product fix has been included in the EPM 26.07.60 release. The fix is already available on test pods and is scheduled for production deployment on July 17, 2026. Customers can resolve the issue by upgrading their environment to the EPM 26.07 release once it becomes available in production.
