4.6.1.2 Backing Up Settings on a Switch with 1.1.3-2 Firmware
The following procedure describes how to back up a switch with 1.1.3-2 firmware. The backup only needs to be done once after the switch has been initially configured with the right settings.
  1. Navigate to the switch ILOM URL in a browser. For example: http://dbm002-i1.us.example.com.
  2. Log in as the ilom-admin user.
  3. Select the Maintenance tab.
  4. Select the Backup/Restore tab.
  5. Select the Backup operation and the Browser method.
  6. Enter a passphrase. This is used to encrypt sensitive information, such as user passwords, in the backup.
  7. Click Run, and save the resulting XML file in a secure location.
  8. Log in to the Sun Datacenter InfiniBand Switch 36 switch as the root user.
  9. Use the scp command to copy the following files:
    • Network configuration: /etc/sysconfig/network-scripts/ifcfg-eth0
    • DNS information: /etc/resolv.conf
    • NTP information: /etc/ntp.conf
    • Time zone information: /etc/localtime
    • openSM settings: /etc/opensm/opensm.conf
    • Host name: /etc/sysconfig/network
    • root SSH keys: /root/.ssh/authorized_keys
    • nm2user SSH keys (if it exists): /home/nm2user/.ssh/authorized_keys
  10. Run the hostname command, and then save the output. This is done in case the host name is not set in the /etc/sysconfig/network file.
  11. Save the passwords for the root and nm2user accounts.
  12. Run the nm2version command, and then save the output.
