6.3.1.2 Monitoring Exadata Smart Flash Cache Using Database Statistics and Wait Events
The following table describes various database statistics that are useful for
monitoring Exadata Smart Flash Cache. The statistics
are available in various dynamic performance views, including
V$SYSSTAT, and may be displayed in the Global Activity Statistics or
Instance Activity Statistics section of an AWR report.
| Statistic | Description |
cell flash cache read hits |
The number of read requests that were satisfied by the cache |
cell flash cache read hits for partner reads |
The number of read requests that were satisfied by a partner storage server using mirrored data in the flash cache on the partner storage server. These reads are also included in the count of cell flash cache read hits on the primary storage server.
cell xrmem cache read hits for partner reads |
The number of read requests that were satisfied by a partner storage server using mirrored data in the XRMEM cache on the partner storage server. These reads are also included in the count of cell flash cache read hits on the primary storage server.
cell flash cache read hits for smart IO |
The number of read requests for smart IO that were satisfied by the cache |
cell flash cache read hits for temp IO |
The number of read requests for temp IO that were satisfied by the cache |
cell flash read hits for controlfile reads |
The number of read requests for a database control file that were satisfied by the cache |
cell overwrites in flash |
Total number of write requests that overwrote an existing cacheline in Exadata Smart Flash Cache that had not been written to disk. In effect, this is the amount of disk I/O saved by using Write-Back mode. This statistic is incremented once per mirror write. |
cell partial writes in flash |
Total number of write requests written to both Exadata Smart Flash Cache and disk. Part of the data was written to flash, and the rest was written to disk. This statistic is incremented once per mirror write. |
cell writes to flash cache |
Total number of write requests written entirely to Exadata Smart Flash Cache. This statistic is incremented once per mirror write. |
cell writes to flash cache for temp IO |
The number of write requests for temporary segments that were absorbed by Exadata Smart Flash Cache |
physical read IO requests |
Number of physical read requests issued by the database. |
physical read requests optimized |
Total number of read requests satisfied by using Exadata Smart Flash Cache, and read requests avoided by using storage index or columnar cache. |
physical read total bytes |
Total amount of I/O bytes for reads issued by the database, whether or not the read was offloaded to the storage servers. |
physical read total bytes optimized |
Total number of bytes read from Exadata Smart Flash Cache, and bytes avoided by using storage index or columnar cache. |
physical read total IO requests |
Total number of read requests issued by the database for all activity including application, backup, recovery, and other utilities. |
physical write IO requests |
Number of physical write requests issued by the database. |
physical write total bytes |
Total number of IO bytes for writes issued by the database for all activity. |
physical write total bytes optimized |
Total number of bytes written to Exadata Smart Flash Cache. These writes are synchronized to disk in a lazy manner. |
physical write total IO requests |
Total number of write requests issued by the database for all activity, including application, backup, recovery and other utilities. |
The following table describes database wait events that are useful for
monitoring Exadata Smart Flash Cache. The wait events
are visible in various dynamic performance views, including V$SESSION,
V$SYSTEM_EVENT and V$SESSION_EVENT, and may be
displayed in the Wait Event sections of the AWR report.
The latency of the cell single block physical read event typically
indicates if the read is satisfied from Exadata Smart Flash Cache. The higher the latency, the higher the likelihood that the request was
not satisfied from Exadata Smart Flash Cache.
| Wait Event | Description |
cell list of blocks physical
read |
This wait event occurs during recovery or during buffer pre-fetching (rather than performing multiple single-block reads). It is used to monitor database blocks that must be changed as part of recovery and are read in parallel for the database. In
This wait event is equivalent to |
cell list of blocks read request |
This is a placeholder wait event associated with
cell multiblock physical read |
This wait event represents the time taken to perform all the I/Os for a multi-block database read. In
cell multiblock read request |
cell single block physical read |
This wait event represents the time taken to perform a single block database I/O. In
This wait event is equivalent to Commencing with the May 2022 Oracle Database release updates (versions 19.15.0.0.220419, 21.6.0.0.220419, and later), this wait event no longer includes I/O from Exadata Smart Flash Cache or database I/O using a Remote Direct Memory Access (RDMA) read. |
cell single block physical read: flash
cache |
This wait event represents the time taken to perform a single block database I/O from Exadata Smart Flash Cache. In
This wait event was introduced in the May 2022 Oracle
Database release updates and is present in Oracle Database versions
19.15.0.0.220419, 21.6.0.0.220419, and later. Previously,
cell single block physical read: partner flash cache |
This wait event represents the time taken to perform a single block database I/O satisfied by a partner storage server using mirrored data in the flash cache on the partner storage server. |
cell single block physical read: partner xrmem cache |
This wait event represents the time taken to perform a single block database I/O satisfied by a partner storage server using mirrored data in the XRMEM cache on the partner storage server. |
cell single block read request |
This is a placeholder wait event associated with a single
block database I/O that is visible only during the wait period.
After the wait event ends, the placeholder is converted to the
appropriate wait event, which is typically one of the |
cell interconnect retransmit during physical
read |
This wait event appears during retransmission for an I/O
of a single-block or multiblock read. The cell hash number in the
The availability of a specific statistic or wait event is subject to the version of Oracle Database being used.
Parent topic: Monitoring Exadata Smart Flash Cache
