6.3.7.2 Monitoring Smart I/O Using Database Statistics and Wait Events
The following table describes various database statistics that are useful for monitoring smart I/O operations. The statistics are available in various dynamic performance views, including V$SYSSTAT, and may be displayed in the Global Activity Statistics or Instance Activity Statistics section of an AWR report.
Statistic Description
cell IO uncompressed bytes
The total size of uncompressed data that is processed on the cell.
For operations on segments compressed using Exadata Hybrid Columnar Compression, this statistic is the size of the data after decompression.
cell num bytes in block IO during predicate offload The number of bytes that were not offloaded because the client was in block I/O mode.
cell num bytes in filter passthru due to low mem The number of bytes that were not offloaded and sent back to the database for processing due to low memory on the cell.
cell num bytes in filter passthru due to subheap size limit exc The number of bytes that were not offloaded and sent back to the database for processing due to a memory limit on the cell.
cell num bytes in passthru due to quarantine The number of bytes that were not offloaded and sent back to the database for processing due to a quarantine on the cell.
cell num bytes in passthru during predicate offload The number of bytes that were not offloaded and sent back to the database for processing.
cell num smart IO sessions in rdbms block IO due to big payload The number of sessions in block I/O mode (not offloaded) due to excessively large metadata.
cell num smart IO sessions in rdbms block IO due to no cell mem The number of sessions in block I/O mode (not offloaded) due to memory shortage on the storage servers.
cell num smart IO sessions in rdbms block IO due to online encr The number of sessions in block I/O mode (not offloaded) due to an ongoing online encryption operation.
cell num smart IO sessions in rdbms block IO due to open fail
The number of sessions in block I/O mode (not offloaded) due to a failure in opening a connection to a cell.
cell num smart IO sessions in rdbms block IO due to user
The number of sessions in block I/O mode (not offloaded) due to a user setting.
cell num smart IO sessions using passthru mode due to cellsrv The number of sessions in passthru mode (not offloaded) due to an issue with CELLSRV.
cell num smart IO sessions using passthru mode due to timezone
The number of sessions in passthru mode (not offloaded) due to an ongoing database timezone upgrade operation.
cell num smart IO sessions using passthru mode due to user The number of sessions in passthru mode (not offloaded) due to a user setting.
cell physical IO bytes added to storage index The number of bytes added to the storage index during a Smart Scan. This is an indication that the storage index is being built.
cell physical IO bytes eligible for predicate offload The number of bytes on-disk eligible for predicate offload.
cell physical IO bytes eligible for smart IOs
The number of actual bytes eligible for predicate offload.
For example, when using columnar cache, this is the size of columnar cache instead of the on-disk size.
cell physical IO bytes processed for IM capacity The number of bytes read from the columnar cache in memcompress for capacity format.
cell physical IO bytes processed for IM query The number of bytes read from the columnar cache in memcompress for query format.
cell physical IO bytes processed for no memcompress The number of bytes read from the columnar cache in no memcompress format.
cell physical IO bytes processed for XrCC The number of bytes read from the columnar cache on Exadata RDMA Memory (XRMEM).
cell physical IO bytes saved by columnar cache The number of bytes saved by columnar cache; that is, the number of bytes of reading that was avoided.
cell physical IO bytes saved by storage index The number of bytes saved by storage index.
cell physical IO bytes saved during optimized file creation The number of I/O bytes saved by the database host by offloading the file creation operation to the cells. This statistic shows the benefit of optimized file creation operations.
cell physical IO bytes saved during optimized RMAN restore The number of I/O bytes saved by the database host by offloading the RMAN file restore operation to the cells. This statistic shows the benefit of optimized RMAN file restore operations.
cell physical IO bytes sent directly to DB node to balance CPU usage The number of I/O bytes sent back to the database server for processing due to high storage server CPU usage.
cell physical IO interconnect bytes The number of I/O bytes exchanged over the interconnect between the database host and the cells.
cell physical IO interconnect bytes returned by smart scan The number of I/O bytes that are returned by the cell for Smart Scan operations. It does not include bytes for other database I/O.
The following table describes database wait events that are useful for monitoring smart I/O operations. The wait events are visible in various dynamic performance views, including V$SESSION, V$SYSTEM_EVENT and V$SESSION_EVENT, and may be displayed in the Wait Event sections of the AWR report.
Wait Event Description
cell external table smart scan
This wait event appears when the database is waiting for an external table scan on a cell.
The cell hash number in the P1 column in V$SESSION can help to identify a slow cell compared to the rest of the cells.
cell smart file creation
This wait event appears when the database is waiting for the completion of a file creation on a cell.
cell smart incremental backup
This wait event appears when the database is waiting for the completion of an incremental backup on a cell.
cell smart index scan
This wait event appears when the database is waiting for an index fast full scan.
The cell hash number in the P1 column in V$SESSION can help to identify a slow cell when compared to the rest of the cells.
cell smart index scan: db timezone upgrade The wait event appears when the cells are unable to offload because a database timezone upgrade is in progress.
cell smart index scan: disabled by user The wait event appears when the cells are unable to offload due to a user setting.
cell smart index scan: pass through The wait event appears when the cells are unable to offload the Smart Scan.
cell smart index scan request
This is a placeholder wait event associated with cell smart index scan, which is only visible during the wait period.
After the wait event ends, the placeholder is typically converted to cell smart index scan. However, to better describe the wait outcome, the placeholder may be converted to cell smart index scan: db timezone upgrade, cell smart index scan: disabled by user, or cell smart index scan: pass through.
cell smart restore from backup
This wait event appears when the database is waiting for the completion of a file initialization for restore from backup on a cell.
cell smart table scan
This wait event appears when the database is waiting for smart scans to complete on a cell.
cell smart table scan: db timezone upgrade The wait event appears when the cells are unable to offload because a database timezone upgrade is in progress.
cell smart table scan: disabled by user The wait event appears when the cells are unable to offload due to a user setting.
cell smart table scan: pass through The wait event appears when the cells are unable to offload the Smart Scan.
cell smart table scan request
This is a placeholder wait event associated with cell smart table scan, which is only visible during the wait period.
After the wait event ends, the placeholder is typically converted to cell smart table scan. However, to better describe the wait outcome, the placeholder may be converted to cell smart table scan: db timezone upgrade, cell smart table scan: disabled by user, or cell smart table scan: pass through.
The availability of a specific statistic or wait event is subject to the version of Oracle Database being used.
