3 Servicing CRUs That Do Not Require System Power Off
Perform tasks for servicing hot plug components in the Oracle Database Appliance.
Hot-pluggable components can be replaced with the system powered on.
Hot-pluggable components can also be replaced with the system powered off. If you choose this method, first power off the system as described in Preparing Oracle Database Appliance for Service.
- Oracle Database Appliance X10 Server Hot Pluggable Components
 Provides instructions on how to perform hot plug tasks on an Oracle Database Appliance server.
- Oracle Database Appliance X10-HA Storage Shelf Hot Pluggable Components
 Perform hot plug tasks on an Oracle Database Appliance storage shelf.
Replacing hot plug components does not require you to power off the Oracle Database Appliance X10-S/X10-L server or an Oracle Database Appliance X10-HA server node.
In certain storage expansion scenarios (explained in the following procedures), adding optional storage might require that the appliance be powered off.
If you are servicing storage shelf hot plug components, see Oracle Database Appliance Storage Shelf Hot-Pluggable Components.
Hot-pluggable components are those that can be removed and installed while the system is running. These are designated as Customer Replaceable Units (CRUs).
After a physical insertion or removal action of a storage component (such as a disk or SAS cable), you should wait before performing the next action to allow the system software to fully process the event. This could take up to 3 minutes to complete.
For instructions on servicing NVMe front-mounted storage devices, see Servicing NVMe Storage Drives. Note that front mounted storage drives are not supported in the Oracle Database Appliance X10-HA server nodes.
Caution: An NVMe drive must first be powered off before removal. If you do not power off the NVMe drive before removal you can crash the operating system. Oracle Database Appliance uses special commands to remove or add NVMe storage.
- Servicing NVMe Storage Drives (CRU)
 Perform tasks for servicing front-mounted NVMe drives in an Oracle Database Appliance X10-S/X10-L system. The Oracle Database Appliance X10-HA does not support front-mounted drives in server nodes.
- Servicing Fan Modules (CRU)
 Perform tasks for servicing the fan modules and the fan tray.
- Servicing Power Supply Modules (CRU)
 Perform tasks for servicing system chassis fan modules in an Oracle Database Appliance.
Parent topic: Servicing CRUs That Do Not Require System Power Off
- Replacing an NVMe Storage Drive
 Replace a front-mounted NVMe drive in an Oracle Database Appliance X10-S/X10-L system.
- Adding NVMe Expansion Storage
 Add NVMe storage to an Oracle Database Appliance X10-L. Note that the Oracle Database Appliance X10-S does not support additional storage.
Before removing an NVMe drive it must be powered off. After installing an NVMe drive it must be powered on. Failed drives are automatically powered off after 5 minutes.
Caution:
If you remove an NVMe drive without first powering it off, you can crash the operating system. Oracle Database Appliance uses special commands to add or remove NVMe storage.
The instructions describe how to replace an NVMe drive using the odaadmcli power on/off commands for an Oracle Database Appliance server.
The odaadmcli commands listed here must be run as the root user.
Parent topic: Servicing NVMe Storage Drives (CRU)
                                 The Oracle Database Appliance X10-L supports two expansion slots for NVMe drives. These are slots labeled 2 through 3 as seen from the front of the system. Storage drives can be added in sets of two. For information about supported optional storage drives, refer to the Owner's Guide.
                                 When expanding storage, populate slots starting with the lowest numbered available slot (for example, slot 2 as seen on the front panel).
                                 The drive power-up and storage expansion odaadmclicommands listed here should only be run after all new disk drives have been physically installed. Once you expand storage, you cannot revert to a previous storage configuration (for example, the default installation with only two NVMe drives).
Fan modules are located inside the server chassis near the front of the server. They do not require you to power off the server before servicing.
Remove a Fan Module
You do not have to power off the server to service fan modules.
Caution:
When replacing a fan module, you must complete the entire procedure within 60 seconds (including top cover replacement) to maintain adequate cooling in the system. Otherwise, the system might shutdown due to over-temperature which could potentially damage components. Remove and replace only one fan module at a time. Ensure that you have obtained the replacement fan module and that is it is ready for installation before starting the replacement procedure.
Parent topic: Servicing Fan Modules (CRU)
Power supplies are are located at the back of the server and do not require you to power off the server before servicing.
The server supports model A271 and A271A 1400 watt power supplies. The system requires high line 200 - 240 volts AC (VAC) line input. The power supply (PS) converts AC power to lower DC voltages used by internal system components. The power supplies are hot-pluggable and provide “1+1” redundancy, allowing the system to suffer the loss of a power supply or an AC line with no loss to system availability.
Install a Power Supply
Caution:
Always replace the failed power supply with the same model of power supply. For this product, note that both the A271 and A271A power supplies are supported and are considered interchangeable.Parent topic: Servicing Power Supply Modules (CRU)
Under most circumstances, Oracle Database Appliance X10-HA storage shelf components can all be replaced while the storage shelf is powered-on and running. Any exceptions will be described in the following procedures.
- Adding Optional Storage Shelf Drives (CRU)
 Add disk storage in an Oracle Database Appliance X10-HA storage shelf.
- Replace a Storage Shelf HDD or SSD (CRU)
 Replace a storage disk in an Oracle Database Appliance storage shelf.
- Replace a Storage Shelf Power Supply (CRU)
 Replace a power supply in an Oracle Database Appliance storage shelf.
- Replace a Storage Shelf I/O Module (CRU)
 Replace an IO module in an Oracle Database Appliance storage shelf.
The Oracle Database Appliance X10-HA storage shelf partially-populated base configuration supports storage expansion with either 7.68 TB SSDs (available in six-packs) or 22 TB HDDs (available in an eighteen-pack). Depending on your initial base storage shelf configuration, there can be up to eighteen expansion slots. These slots are labeled 6-23 as seen from the front of the system (callouts 6 through 23 in the following illustration).
                              Upgrade options: -
                                    For a high performance shelf, you can add up to eighteen 7.68 TB SSDs (available in six-packs). You can add storage with the system running and use the appliance CLI software commands to expand the storage configuration.
                                    For a high capacity shelf, you can add eighteen 22 TB HDDs (available in an eighteen-pack). You must power off the appliance, add storage, then re-image and redeploy the appliance software. This is required to reconfigure the appliance from the default high performance mode to high capacity mode.
                              Expanding the base configuration storage shelf with 7.68 TB SSDs for high performance. The base configuration has slots 0-5 with 7.68 TB drives for DATA/RECO. Expansion SSDs are available in six-packs and are populated in shelf storage slots from the bottom up to also be used for DATA/RECO, as follows: - The first six expansion drives go into slots 6-11.
- The second six expansion drives go into slots 12-17.
- The third six expansion drives go into slots 18-23.
 The following illustration shows the expanded drive configuration for 7.68 TB SSDs.
                              Expanding the base configuration storage shelf with 22 TB HDDs for high capacity. When expanding the storage shelf with HDDs, the base configurations SSDs will be used for FLASH and the HDDs will be used for DATA/RECO. Expansion HDDs are available in an eighteen-pack and populate the empty shelf storage slots (slots 6-23). The following illustration shows the expanded drive configuration for 22 TB HDDs.
                              Once you expand storage to support additional disks, you cannot revert to the base configuration (no drives in slots 6-23).
                              If you plan on adding another storage shelf, it must be populated identically to your first storage shelf.
                              The odaadmclicommands listed here must be run as the root user.
After a physical insertion or removal action of a storage component (such as a disk or SAS cable), you should wait before performing the next action to allow the system software to fully process the event. This could take several minutes to complete.
The storage shelf and the storage expansion shelf each have two power supplies. Indicators (LEDs) on the power supplies indicate their operation state.
The power supplies are redundant and one can be replaced while the appliance is running.
Example figure showing a DE3-24C power supply:
| Callout | Description |
| 1 | AC power fail indicator |
| 2 | Fan fail indicator |
| 3 | Power supply status indicator |
| 4 | DC power fail indicator |
| 5 | Release lever |
| 6 | AC connector |
| 7 | This switch is non-functional in this product. The AC power cord is used to apply or disconnect power to the power supply. |
If any of the indicators are amber, or if the power supply status indicator does not light, replace the power supply.
Caution:
Equipment damage. Do not remove a power supply unless you have an immediate replacement.
Storage Shelf SAS I/O modules are fully redundant and can be replaced while the appliance is running.
Example figure showing the DE3-24C:
| 1 | I/O module locking levers |
| 2 | I/O module 1 (top) |
| 3 | I/O module 0 (bottom) |
Caution:
Equipment damage. Do not remove an I/O module unless you have an immediate replacement.
