Cables and Cable Accessories for Recovery Appliance
Table 26-9 lists the replacement cables and cable accessories for Recovery Appliance.
Note: All replacement parts listed in the following table are FRUs when covered under Premier Support of Systems warranty.
Table 26-9 Replacement Cables for Recovery Appliance
| Part Number | Description | Repair Category | Repair |
| 350-1287 | Slim rail, CMA, 1U-2U for a storage server | EBO |
| 350-1546 | Cable management arm (CMA) 1U, RoHS:Y for compute server | DBO |
| 350-1519 | Serial cable kit, RoHS:Y with the following:
HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 350-1640 | Label assembly EV2, 5-way, service upgrade, label | HS | See In-Rack Cabling Tables for Recovery Appliance X8, X7, X6, and X5 |
| 350-1641 | Label assembly EV2, 6-way, service upgrade, label | HS | See In-Rack Cabling Tables for Recovery Appliance X8, X7, X6, and X5 |
| 350-1642 | Label assembly EV2, 7-way, service upgrade, label | HS | See In-Rack Cabling Tables for Recovery Appliance X8, X7, X6, and X5 |
| 350-1643 | Label assembly EV2, 8-way, service upgrade, label | HS | See In-Rack Cabling Tables for Recovery Appliance X8, X7, X6, and X5 |
| 530-4445 | QSFP InfiniBand passive copper cable, 10 GbE, 3 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html Note: There is a loss of redundancy when replacing cables. |
| 530-4446 | QSFP InfiniBand passive copper cable, 10 GbE, 5 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html Note: There is a loss of redundancy when replacing cables. |
| 530-4403 | 4x QSFP copper QDR InfiniBand cable, 2 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html Note: There is a loss of redundancy when replacing cables. |
| 530-4404 | 4x QSFP copper QDR InfiniBand cable, 3 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 530-4415 | 4x QSFP copper QDR InfiniBand cable, 5 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 530-4432 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 7 foot, blue, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4433 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 10 foot, red, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4434 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 7 foot, red, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4435 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 10 foot, black, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4436 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 7 foot, black, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4437 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 7 foot, orange, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4438 | Ethernet cable, Cat 5/5E, RJ45 to RJ45, 10 foot, black, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 530-4444 | QSFP to QSFP Passive Copper Cable, 1 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 530-4445 | QSFP passive copper cable, 10 GE, 3 m | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 530-4502-01 | Ethernet cable, Cat 5/5E, 10 foot, blue, RoHS:Y | HS | See Catalyst 4948E and Catalyst 4948E-F Switch Installation Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins.html |
| 7015400 | Power cable, jumper, SR2, 2m C14RA, 10A, C13 | HS | See “Replacing a Power Distribution Unit” of this guide. |
| 7042273 | Slim rail, cable management arm, 1U-2U for a storage server | EBO | If the server is currently running, then shut it down. See Shutting Down Recovery Appliance. |
| 7102869 | Passive fiber InfiniBand cable, 10 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html Note: Purchase two QSFP SR Transceivers (Part Number X2124A-N) for each passive fiber cable. |
| 7102870 | Passive fiber InfiniBand cable, 20 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html Note: Purchase two QSFP SR Transceivers (Part Number X2124A-N) for each passive fiber cable. |
| 7102871 | Passive fiber InfiniBand cable, 50 m, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at https://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html Note: Purchase two QSFP SR Transceivers (Part Number X2124A-N) for each passive fiber cable. |
