Parts for Power Distribution Units
Table 26-8 lists the replacement parts for the power distribution units (PDUs). Given the number of cables and connections, Oracle recommends that you shut down the Recovery Appliance rack when replacing power distribution unit parts.
Note: All replacement parts listed in the following table are FRUs when covered under Premier Support of Systems warranty.
Table 26-8 Replacement Parts for Power Distribution Units
| Part Number | Description | Repair Category | Repair |
| 180-2379 | 13A/250V 90 degree IEC 320 Sheet E to IEC 320 C13 cord, 1 meter, RoHS:Y | HS | Not applicable |
| 180-2380 | 13A/250V 90 degree IEC 320 Sheet E to IEC 320 C13 cord, 2 meter, RoHS:Y | HS | Not applicable |
| 371-4000 | Three-phase PDU: 15kV,5-Pin, IEC309 32A, 5 PIN 230/400V, 3ph IP44, International, RoHS:Y | IR | See “Replacing a Power Distribution Unit” of this guide. |
| 371-4199 | Single-phase PDU: 15kVA, with three 30A/250V 2-Pole/3-Wire NEMA L6-30P Plugs, North America, RoHS:Y | IR | See “Replacing a Power Distribution Unit” of this guide. |
| 371-4201 | Single-phase PDU: 15kVA, with three Blue 32A/240V Splash-proof 2-Pole/3-Wire IEC 60309 Plugs, International, RoHS:Y | IR | See “Replacing a Power Distribution Unit” of this guide. |
| 371-5039 | Single-phase PDU: 22k VA Hubbell CS8265C PlugNo X-Option | IR | See “Replacing a Power Distribution Unit” of this guide. |
| 371-5040 | Single-phase PDU: 22k VA Blue 32A IEC 60309 Plug No X-Option | IR | See “Replacing a Power Distribution Unit” of this guide. |
| 7051908 | Three-phase PDU: 15kVA, IEC309 60A, 4 PIN, 250VAC, 3ph IP67, North America, RoHS:Y | IR | See “Replacing a Power Distribution Unit” of this guide. |
