Performing the Initial Switch Configuration for the Cisco Nexus 93108-1G or 9348 Ethernet Switch
During the initial configuration, you reset the switch and use the Basic System Configuration Dialog to configure the switch.
Before configuring the switch, note the following:
The Cisco Ethernet switch should not be connected until the running configuration has been verified, and any necessary changes have been made by the network administrator.
The Cisco Ethernet switch should not be connected to the customer network until the IP addresses on all components have been configured in ZDLRA Rack. This is to prevent any duplicate IP address conflicts which are possible due to the default addresses set in the components when shipped.
Configuration should be done with the network administrator.
