AC Power
The auto-sensing AC power supply is rated at 110-240 VAC, 50-60 Hz, and is supplied with
an IEC connector. The handle on the front panel of the power supply is used to remove
the power supply from the chassis. The gray locking handle, when moved from right to
left, unlocks the power supply from the chassis when removing the power supply.
AC Power Cords
All AC-powered systems ship with two 2.5m power cords. Each power cord connects to the IEC-320 C14 receptacle on the power supply.
