4 Configuring the Operating System
This chapter describes how to configure operating systems supported by Oracle Communications ASAP.
About Configuring the Operating System
ASAP can be installed on Oracle Solaris, Oracle Linux, or HP-UX Itanium. This section describes procedures relating to configuring each operating system and other required applications for use with the ASAP server software.
Before proceeding, the appropriate version of the UNIX operating system must be installed on any machines that will be running ASAP server software, and the machines must be configured to be part of your network. See ASAP Compatibility Matrix for a list of supported operating systems.
In order to install and configure the UNIX environment for ASAP as described in this section, you must be familiar with the UNIX operating system. You should know how to configure users and groups, understand shells, and be able to manipulate file and directory permissions. You also need to understand a number of other UNIX system administration concepts.
Configuring a UNIX ASAP Group and User
To support installation and running of ASAP, each ASAP environment that you create must have at least one dedicated UNIX ASAP group and one dedicated ASAP user account within that group. You may choose to have additional ASAP users in the ASAP group, depending on your specific implementation.
Prior to installing ASAP, you must create a UNIX ASAP group and an ASAP user. The ASAP group must be the primary group of the ASAP user.
Creating the UNIX ASAP Group
This group is required to coordinate access to files that are needed to develop and test ASAP. All UNIX users of ASAP must belong to this group.
Oracle recommends that you use UNIX groups to coordinate the read/write access required for ASAP. You can use any other name for the group that is appropriate for the project, as long as the ASAP and environment users belong to that group.
Create a group for ASAP with the following members:
ASAP user account
root
Creating the UNIX ASAP User Account
Each ASAP environment must have a dedicated UNIX user account. For development purposes, you may have multiple ASAP environments. In this case, you must define multiple users. In a production environment, you generally have only one environment and therefore only one group and user.
Oracle recommends for configuration if you set the home directory of the ASAP user to be the same directory where you plan to install the ASAP software. Take this into account when you set up the home directory.
Create the ASAP user and password, and make the user's primary group the newly created ASAP group. Additional ASAP user accounts may be needed depending on your implementation.
You must use this ASAP user account to create the directory where ASAP will be installed. The installer uses the ASAP user account to access the UNIX system and must have write privileges on the destination install directory.
Checking /tmp and /var/tmp Directory Status
You must ensure that the directories /tmp and /var/tmp have their permissions set so that they are writable by all ASAP users. To do this:
Check the permissions on the /tmp directory:
cd / ls -l | grep tmp
Check that the permissions string has the appropriate settings for the ASAP group. Use chmod to update the permissions if needed. For example:
chmod a+rwx tmp
Check the permissions on the /var/tmp directory.
cd /var ls -l | grep tmp
Configuring HP-UX Itanium User Space Memory Allocator
Make sure that you install the libmallocng.so library in the default location provided by the MallocNextGen installer: /usr/lib/hpux32/. The ASAP installer uses this default path when it creates the Environment_Profile during ASAP installation, as shown in the following example:
if [ -a "/usr/lib/hpux32/libmallocng.so" ]; then export LD_PRELOAD="/usr/lib/hpux32/libmallocng.so"
Configuring the Kernel
There are certain UNIX kernel configuration parameters that require tuning so that both the database and ASAP function correctly. The most important aspect of UNIX kernel configuration is to provide an environment in which the database server can handle hundreds of concurrent connections.
The following are the principal areas that require tuning:
Shared memory
Oracle Database requires the ability to share large amounts of memory. Typically, the potential shared memory size should be 100 MB or greater.
Open files per process
The RDBMS server is expected to manage a large number of concurrent connections. These connections constitute open file descriptors to the RDBMS Server. The maximum number of file descriptors dictates the maximum number of concurrent connections that can be managed by the RDBMS Server. To support multiple ASAP environments, the UNIX kernel should be configured to support an appropriately large number of open files per process.
Consult with your operating system administrator to determine a value.
In addition, some operating systems use the concept of soft and hard file limits. Ensure that both limits are set appropriately.
Asynchronous I/O
Asynchronous I/O is required for Solaris platforms.
Inter process communication
Inter Process Communication (IPC) modules are implemented as dynamically loadable modules on the Oracle Solaris system. By default, the Solaris operating system loads the IPC subsystem into memory on demand. Separate loadable UNIX kernel modules are available for shared memory, message queues, and semaphores. These modules must be loaded with the kernel at boot time.
To update the UNIX kernel configuration:
Using the information below and in "Configuring the Kernel" update the UNIX kernel parameters.
Reboot the machine after you have made the changes.
For more information, see the ASAP Administrator's Guide.
When ASAP is deployed on the same platform as the Oracle Database or WebLogic Server instance, use the highest kernel value recommended in either ASAP, Oracle Database, or WebLogic Server documentation.
Setting Oracle Solaris Kernel Parameters
This section lists the Oracle Solaris Kernel parameters.
Oracle Solaris 10: /etc/system File:
set pt_cnt=254 set rstchown=0 set maxuprc=1024 set pcie:pcie_aer_ce_mask=0x1 set segkmem_lpsize=0x400000 set rlim_fd_cur=8192 set rlim_fd_max=8192
The following resource control values should be set:
Set process.max-sem-nsems to 1024
Set project.max-shm-ids to 300
Set project.max-sem-ids to 512
Refer to the Solaris 10 documentation for details about how to use resource control to set kernel parameters.
Setting Linux Kernel Parameters
Oracle recommends that the kernel parameters shown in Table 4-1 are set to values greater than or equal to the value shown.
The procedure following the table describes how to verify and set the values manually.
The kernel parameter and shell limit values shown in the following section are recommended values, and should be modified after installing Oracle 19c Client for Linux and before installing ASAP.
Table 4-1 lists and describes the recommended kernel parameter settings for supported Linux systems.
Table 4-1 Kernel Parameter Configuration
| Parameter | Recommended Value | File and Description |
250 3200 32 128 |
/proc/sys/kernel/sem This file contains the four numbers that define the limits of the System V IPC semaphores. These fields are:
268435456 |
/proc/sys/kernel/shmall This file contains the system-wide limits on the total number of pages of System V IPC shared memory. |
4294967295 |
/proc/sys/kernel/shmmax This file can be used to query and set the run-time limit on the maximum System V IPC shared memory segment size that can be created. Oracle recommends 4 GB for optimum system performance. |
65536 |
/proc/sys/kernel/msgmax The |
65536 |
/proc/sys/kernel/msgmnb The The default is 16384. |
2878 |
/proc/sys/kernel/msgmni The |
131072 |
/proc/sys/kernel/threads-max Gets and sets the limit on the maximum number of running threads system-wide. |
327679 |
/proc/sys/fs/file-max This file defines a system-wide limit on the number of open files for all processes. |
256 |
/proc/sys/fs/mqueue The |
8192 |
32767 |
Table 4-2 provides the commands to display the current values of the kernel parameters. Make a note of these values and identify any values that you must change.
Table 4-2 Commands to Display Kernel Parameters
| Parameter | Command |
Displays the value of the semaphore parameters in the order listed. |
Displays the details of the shared memory segment sizes. |
Displays the details of the System V IPC message queue parameters. |
Displays the maximum number of threads possible system-wide. |
Displays the maximum number of open files throughout the system. |
# /sbin/sysctl -a | grep queues_max Displays the maximum number of message queues allowed on the system. |
Displays the maximum message size value. |
Displays the maximum number of messages in a queue value. |
If the value of any kernel parameter is different from the recommended value, perform the following:
Using any text editor, create or edit the /etc/sysctl.conf file, and add or edit lines similar to the following:
Include lines for kernel parameters values that you want to change. For the semaphore (
kernel.sem) parameter, you must specify all values. However, if any of the current values are larger than the recommended values, then specify the larger value.kernel.sem = 250 32000 32 128 kernel.shmall = 268435456 kernel.shmmax = 4294967295 kernel.msgmax = 65536 kernel.msgmnb = 65536 kernel.msgmni = 2878 kernel.threads-max = 131072 fs.file-max = 327679 fs.mqueue.queues_max = 256 fs.mqueue.msgsize_max = 256 fs.mqueue.msg_max = 32767
By specifying the values in the /etc/sysctl.conf file, these values persist when you restart the system.
Enter the following command to change the current values of the kernel parameters:
# /sbin/sysctl -p
Review the output from the command to verify that the values are correct. If the values are incorrect, edit the /etc/sysctl.conf file, then enter this command again.
Enter the command
/sbin/sysctl -ato confirm the values are set correctly. -
After updating the values of the kernel parameters in the /etc/sysctl.conf file, either restart the computer, or run the command
sysctl -pto make the changes in the /etc/sysctl.conf file available in the active kernel memory.
Setting HP-UX Itanium Kernel Parameters
This section lists the Hewlett Packard HP-UX kernel parameters.
Table 4-3 HP-UX for Itanium Kernel Parameters
| Name | Recommended Value | Description |
STRMSGSZ |
65535 |
aio_listio_max |
512 |
aio_physmem_pct |
20 |
aio_max_ops |
4096 |
create_fastlinks |
1 |
cmc_plat_poll |
15 |
dbc_max_pct |
5 |
dbc_min_pct |
2 |
dnlc_hash_locks |
512 |
fs_async |
1 |
max_async_ports |
8192 |
max_thread_proc |
2048 |
Maximum number of threads allowed in each process. |
maxdsiz |
0XC0000000 |
Maximum size (in bytes) of the data segment for any user process. |
maxdsiz_64bit |
0X400000000 |
Maximum size (in bytes) of the data segment for 64-bit processes. |
maxfiles |
4098 |
The soft limit for the number of files a process is allowed to have open simultaneously. |
maxfiles_lim |
4098 |
Hard limit for the number of files that a process is allowed to have open simultaneously. |
dbc_min_pct |
5 |
The percentage of physical memory to be used for the buffer cache. Together with setting nbuf and bufpages to 0, these values activate dynamic buffer cache allocation. |
dbc_max_pct |
10 |
maxssiz |
0X8000000 |
Maximum size (in bytes) of the stack for any user process. |
maxssiz_64bit |
0X10000000 |
Maximum size (in bytes) of the stack for 64-bit processes. |
maxswapchunks |
4096 |
Maximum number of swap chunks. |
maxtsiz |
0X40000000 |
Maximum size (in bytes) of the text segment for any user process. |
maxuprc |
1024 |
Limits the maximum number of concurrent user processes per user. |
mesg |
1 |
Enables Sys V messages at boot time. |
msgmap |
(2+msgtql) |
Number of entries in the System V IPC message space resource map. |
msgmax |
8192 |
Maximum System V IPC message size in bytes. |
msgmnb |
65536 |
Maximum number of bytes on a single System V IPC message queue. |
msgmni |
(NPROC) |
Maximum number of permitted system-wide System V IPC message queues (IDs). |
msgseg |
32767 |
Number of system V IPC message segments in the system. |
msgssz |
128 |
Number of bytes in a System V IPC message segment. |
msgtql |
(NPROC) |
Maximum number of System V IPC messages in the system at any time. |
ncallout |
(NPROC + 16) |
Maximum number of pending timeouts. Calculated as nkthread + the number of I/O devices connected to the machine. |
nfile |
(15 * NPROC + 2048) |
Maximum number of files that can be open simultaneously on the system at any given time. Calculate as follows: ((16*(4200+16+maxusers)/10)+32+2*(npty+nstrpty+nstrtel) |
nflocks |
NPROC (at least 4096) |
Maximum combined total number of file locks that are available system-wide to all processes at any given time. |
ninode |
(8 * NPROC + 2048) |
Maximum number of open inodes that can be in memory. Calculate as follows: 4200+48+maxusers+(2*npty) |
nkthread |
2 * NPROC |
Limits the number of threads allowed to run simultaneously. |
nproc |
8192 |
Limits the number of processes allowed to exist simultaneously. |
npty |
2000 |
nstrpty |
2000 |
nstrtel |
2000 |
semmni |
512 |
Number of system V IPC system-wide semaphore identifiers. |
semmsl |
1043 |
Maximum number of Semaphores Per ID. |
semmni |
512 |
semmns |
4096 |
Number of system V IPC system-wide semaphores. |
semmnu |
(NPROC - 4) |
Maximum number of System V IPC undo structures for processes. |
semmsl |
1024 |
Number of semaphores in a semaphore set |
semvmx |
32767 |
Maximum value of any single System V IPC semaphore. |
shmem |
1 |
Enable or disable System V shared memory. |
shmmax |
0X100000000 (or up to physical memory size) |
Maximum size for a System V shared memory segment. |
shmmni |
300 |
Number of System V shared memory segment identifiers in the system. |
shmseg |
120 |
Maximum number of System V shared memory segments per process. |
swapmem_on |
1 |
Allows physical memory size to exceed the available swap space. |
vps_ceiling |
64 |
