4 Configuring the Operating System
This chapter describes how to configure operating systems supported by Oracle Communications ASAP.
About Configuring the Operating System
ASAP can be installed on Oracle Linux. This section describes procedure relating to configuring operating system and other required applications for use with the ASAP server software.
Before proceeding, the appropriate version of the Linux operating system must be installed on any machines that will be running ASAP server software, and the machines must be configured to be part of your network. See ASAP Compatibility Matrix for a list of supported operating systems.
In order to install and configure the Linux environment for ASAP as described in this section, you must be familiar with the Linux operating system. You should know how to configure users and groups, understand shells, and be able to manipulate file and directory permissions. You also need to understand a number of other Linux system administration concepts.
Configuring a Linux ASAP Group and User
To support installation and running of ASAP, each ASAP environment that you create must have at least one dedicated Linux ASAP group and one dedicated ASAP user account within that group. You may choose to have additional ASAP users in the ASAP group, depending on your specific implementation.
Prior to installing ASAP, you must create a Linux ASAP group and an ASAP user. The ASAP group must be the primary group of the ASAP user.
Creating the Linux ASAP Group
This group is required to coordinate access to files that are needed to develop and test ASAP. All Linux users of ASAP must belong to this group.
Oracle recommends that you use Linux groups to coordinate the read/write access required for ASAP. You can use any other name for the group that is appropriate for the project, as long as the ASAP and environment users belong to that group.
Create a group for ASAP with the following members:
  • ASAP user account
  • root
Creating the Linux ASAP User Account
Each ASAP environment must have a dedicated Linux user account. For development purposes, you may have multiple ASAP environments. In this case, you must define multiple users. In a production environment, you generally have only one environment and therefore only one group and user.
Oracle recommends for configuration if you set the home directory of the ASAP user to be the same directory where you plan to install the ASAP software. Take this into account when you set up the home directory.
Create the ASAP user and password, and make the user's primary group the newly created ASAP group. Additional ASAP user accounts may be needed depending on your implementation.
You must use this ASAP user account to create the directory where ASAP will be installed. The installer uses the ASAP user account to access the Linux system and must have write privileges on the destination install directory.
Checking /tmp and /var/tmp Directory Status
You must ensure that the directories /tmp and /var/tmp have their permissions set so that they are writable by all ASAP users. To do this:
  1. Check the permissions on the /tmp directory:
    cd /
    ls -l | grep tmp
    Check that the permissions string has the appropriate settings for the ASAP group. Use chmod to update the permissions if needed. For example:
    chmod a+rwx tmp
  2. Check the permissions on the /var/tmp directory.
    cd /var
    ls -l | grep tmp
Configuring the Kernel
There are certain Linux kernel configuration parameters that require tuning so that both the database and ASAP function correctly. The most important aspect of Linux kernel configuration is to provide an environment in which the database server can handle hundreds of concurrent connections.
The following are the principal areas that require tuning:
  • Shared memory
    Oracle Database requires the ability to share large amounts of memory. Typically, the potential shared memory size should be 100 MB or greater.
  • Open files per process
    The RDBMS server is expected to manage a large number of concurrent connections. These connections constitute open file descriptors to the RDBMS Server. The maximum number of file descriptors dictates the maximum number of concurrent connections that can be managed by the RDBMS Server. To support multiple ASAP environments, the Linux kernel should be configured to support an appropriately large number of open files per process.
    Consult with your operating system administrator to determine a value.
    In addition, some operating systems use the concept of soft and hard file limits. Ensure that both limits are set appropriately.
To update the Linux kernel configuration:
  1. Using the information below and in "Configuring the Kernel" update the Linux kernel parameters.
  2. Reboot the machine after you have made the changes.
For more information, see the ASAP System Administrator's Guide.
When ASAP is deployed on the same platform as the Oracle Database or WebLogic Server instance, use the highest kernel value recommended in either ASAP, Oracle Database, or WebLogic Server documentation.
Setting Linux Kernel Parameters
Oracle recommends that the kernel parameters shown in Table 4-1 are set to values greater than or equal to the value shown.
The procedure following the table describes how to verify and set the values manually.
The kernel parameter and shell limit values shown in the following section are recommended values, and should be modified after installing Oracle 19c Client for Linux and before installing ASAP.
Table 4-1 lists and describes the recommended kernel parameter settings for supported Linux systems.
Table 4-1 Kernel Parameter Configuration
Parameter Recommended Value File and Description
semmsl
semmns
semopm
semmni
250
3200
32
128
/proc/sys/kernel/sem
This file contains the four numbers that define the limits of the System V IPC semaphores. These fields are:
  • semmsl: The maximum number of semaphores per semaphore set.
  • semmns: The system-wide limit on the number of semaphores in all semaphore sets.
  • semopm: The maximum number of operations that may be specified in a semop(2) call.
  • semmni: The system-wide limit on the maximum number of semaphore identifiers.
shmall
268435456
/proc/sys/kernel/shmall
This file contains the system-wide limits on the total number of pages of System V IPC shared memory.
shmmax
4294967295
/proc/sys/kernel/shmmax
This file can be used to query and set the run-time limit on the maximum System V IPC shared memory segment size that can be created. Oracle recommends 4 GB for optimum system performance.
msgmax
65536
/proc/sys/kernel/msgmax
The msgmax tunable specifies the maximum allowable size of any single message in a System V IPC message queue, in bytes. msgmax must be no larger than msgmnb (the size of the queue).
msgmnb
65536
/proc/sys/kernel/msgmnb
The msgmnb tunable specifies the maximum allowable total combined size of all messages queued in a single System V IPC message queue at one time, in bytes.
The default is 16384.
msgmni
2878
/proc/sys/kernel/msgmni
The msgmni tunable specifies the maximum number of system-wide System IPC message queue identifiers (one per queue). The default is 16.
threads_max
131072
/proc/sys/kernel/threads-max
Gets and sets the limit on the maximum number of running threads system-wide.
file-max
327679
/proc/sys/fs/file-max
This file defines a system-wide limit on the number of open files for all processes.
queues_max
256
/proc/sys/fs/mqueue
The queues_max is a read/write file for setting and getting the maximum number of message queues allowed on the system.
msgsize_max
8192
/proc/sys/fs/mqueue
The msgsize_max is a read/write file for setting and getting the maximum message size value. This message queue attribute is used when creating any message.
msg_max
32767
/proc/sys/fs/mqueue
The msg_max is a read/write file for setting and getting the maximum number of messages in queue value.
Table 4-2 provides the commands to display the current values of the kernel parameters. Make a note of these values and identify any values that you must change.
Table 4-2 Commands to Display Kernel Parameters
Parameter Command
semms1, semmns, semopm, and semmni
# /sbin/sysctl -a | grep sem
Displays the value of the semaphore parameters in the order listed.
shmall, shmmax, and shmmni
# /sbin/sysctl -a | grep shm
Displays the details of the shared memory segment sizes.
msgmnb, msgmni, and msgmax
# /sbin/sysctl -a | grep msgm
Displays the details of the System V IPC message queue parameters.
threads-max
# /sbin/sysctl -a | grep threads-max
Displays the maximum number of threads possible system-wide.
file-max
# /sbin/sysctl -a | grep file-max
Displays the maximum number of open files throughout the system.
queues_max
# /sbin/sysctl -a | grep queues_max
Displays the maximum number of message queues allowed on the system.
msgsize_max
# /sbin/sysctl -a | grep msgsize_max
Displays the maximum message size value.
msg_max
# /sbin/sysctl -a | grep msg_max
Displays the maximum number of messages in a queue value.
If the value of any kernel parameter is different from the recommended value, perform the following:
  1. Using any text editor, create or edit the /etc/sysctl.conf file, and add or edit lines similar to the following:
    Include lines for kernel parameters values that you want to change. For the semaphore (kernel.sem) parameter, you must specify all values. However, if any of the current values are larger than the recommended values, then specify the larger value.
    kernel.sem = 250 32000 32 128
    kernel.shmall = 268435456
    kernel.shmmax = 4294967295
    kernel.msgmax = 65536
    kernel.msgmnb = 65536
    kernel.msgmni = 2878
    kernel.threads-max = 131072
    fs.file-max = 327679
    fs.mqueue.queues_max = 256
    fs.mqueue.msgsize_max = 256
    fs.mqueue.msg_max = 32767
    By specifying the values in the /etc/sysctl.conf file, these values persist when you restart the system.
  2. Enter the following command to change the current values of the kernel parameters:
    # /sbin/sysctl -p
    Review the output from the command to verify that the values are correct. If the values are incorrect, edit the /etc/sysctl.conf file, then enter this command again.
  3. Enter the command /sbin/sysctl -a to confirm the values are set correctly.
  4. After updating the values of the kernel parameters in the /etc/sysctl.conf file, either restart the computer, or run the command sysctl -p to make the changes in the /etc/sysctl.conf file available in the active kernel memory.
Required Linux Packages for ASAP on Linux 8 and Linux 9
You must install the following Linux 64-bit packages before you install database client, WebLogic server, and ASAP. The ASAP installer fails to start if there are any missing packages.
The required Linux packages are:
  • bc
  • binutils
  • elfutils-libelf
  • fontconfig
  • glibc
  • glibc-devel
  • csh
  • ksh
  • libaio
  • libasan
  • liblsan
  • libX11
  • libXau
  • libXi
  • libXrender
  • libXtst
  • libgcc
  • libibverbs
  • libnsl
  • librdmacm
  • libstdc++
  • libxcb
  • libvirt-libs
  • make
  • policycoreutils
  • policycoreutils-python-utils
  • smartmontools
  • sysstat
