2 Diameter Credit-Control Application Protocol
Learn how Oracle Communications Billing and Revenue Management Elastic Charging Engine (ECE) Diameter Gateway maps the diameter messages for Diameter Credit-Control Application Protocol defined in RFC-4006.
Topics in this document:
Section Compliance
Table 2-1 lists the compliance information for Diameter Credit-Control Application protocol sections.
Table 2-1 Diameter Credit-Control Application Protocol Section Compliance
Section Number Section Status Notes
1
Introduction
No requirement
1.1
Requirements language
No requirement
1.2
Terminology
No requirement
1.3
Advertising application support
Supported
2
Architecture models
Supported
3
Credit-Control messages
Supported
3.1
Credit-Control-Request (CCR) command
Supported
3.2
Credit-Control-Answer (CCA) command
Supported
4
Credit-Control Application overview
Supported
Support both reservation and direct debiting
4.1
Service-Specific rating input and interoperability
Supported
5
Session based Credit-Control
Supported
5.1
General principles
Supported
5.2
First interrogation
Supported
5.3
Intermediate interrogation
Supported
5.4
Final Interrogation
Supported
5.5
Server-Initiated credit Re-Authorization
Supported
5.6
Graceful service termination
Supported
5.7
Failure procedures
Supported
6
One time event
Supported
6.1
Service price enquiry
Supported
6.2
Balance check
Supported
6.3
Direct debiting
Supported
6.4
Refund
Supported
6.5
Failure procedure
Supported
7
Credit-Control Application state machine
Supported
8
Credit-Control attribute-value pairs (AVPs)
Supported
8.1
CC-Correlation-Id AVP
Supported
8.2
CC-Request-Number AVP
Supported
8.3
CC-Request-Type AVP
Supported
8.4
CC-Session-Failover AVP
Supported
8.5
CC-Sub-Session-Id AVP
Not supported
Not used by 3GPP
8.6
Check-Balance-Result AVP
Not supported
Not used by 3GPP
8.7
Cost-Information AVP
Supported
8.8
Unit-Value AVP
Supported
8.9
Exponent AVP
Supported
8.10
Value-Digits AVP
Supported
8.11
Currency-Code AVP
Supported
8.12
Cost-Unit AVP
Supported
8.13
Credit-Control AVP
Supported
8.14
Credit-Control-Failure-Handling AVP
Supported
8.15
Direct-Debiting-Failure-Handling AVP
Supported
8.16
Multiple-Services-Credit-Control AVP
Supported
8.17
Granted-Service-Unit AVP
Supported
8.18
Requested-Service-Unit AVP
Supported
8.19
Used-Service-Unit AVP
Supported
8.20
Tariff-Time-Change AVP
Supported
Supported for tariff changes during an active user session
8.21
CC-Time AVP
Supported
8.22
CC-Money AVP
Supported
8.23
CC-Total-Octets AVP
Supported
8.24
CC-Input-Octets AVP
Supported
8.25
CC-Output-Octets AVP
Supported
8.26
CC-Service-Specific-Units AVP
Supported
8.27
Tariff-Change-Usage AVP
Supported
8.28
Service-Identifier AVP
Supported
8.29
Rating-Group AVP
Supported
8.30
G-S-U-Pool-Reference AVP
Not supported
8.31
G-S-U-Pool-Identifier AVP
Supported
8.32
CC-Unit-Type AVP
Not supported
8.33
Validity-Time AVP
Supported
Not supported for tariff changes
8.34
Final-Unit-Indication AVP
Supported
8.35
Final-Unit-Action AVP
Supported
8.36
Restriction-Filter-Rule AVP
Supported
8.37
Redirect-Server AVP
Supported
8.38
Redirect-Address-Type AVP
Supported
8.39
Redirect-Server-Address AVP
Supported
8.40
Multiple-Services-Indicator AVP
Supported
8.41
Requested-Action AVP
Supported
8.42
Service-Context-Id AVP
Supported
8.43
Service-Parameter-Info AVP
Not supported
Not used by 3GPP
8.44
Service-Parameter-Type AVP
Not supported
Not used by 3GPP
8.45
Service-Parameter-Value AVP
Not supported
Not used by 3GPP
8.46
Subscription-Id AVP
Supported
8.47
Subscription-Id-Type AVP
Supported
8.48
Subscription-Id-Data AVP
Supported
8.49
User-Equipment-Info AVP
Supported
8.50
User-Equipment-Info-Type AVP
Supported
8.50
User-Equipment-Info-Value AVP
Supported
9
Result code AVP values
Supported
9.1
Transient failures
Supported
9.2
Permanent failures
Supported
