9 TAP and EDR Field Mappings
This chapter describes the mapping of fields from TAP file to the EDR container that Oracle Communications Billing and Revenue Management (BRM) uses when processing TAP input files and the mapping of fields from EDR container to TAP file used for generating TAP output files.
TAP-to-EDR Mapping
When processing incoming TAP files, BRM copies input data from TAP fields into EDR container fields. The table below lists the TAP fields and the corresponding EDR field(s) where the data from the TAP field is stored.
Some of the fields in the TAP file can map to multiple fields in the EDR container description file. For example, both the ACTUAL_DELIVERY_TIMESTAMP and ACT_DELIVERY_UTC_TIME_OFFSET fields in the Associated Content Extension Record of the EDR container description file store the data from the Actual Delivery Timestamp field in the TAP file.
For some other TAP fields, placement of the field within the TAP file determines where to copy the field's data in the EDR container description file. For example, depending on the context within the TAP file, Location Identifier can be mapped to the LOCATION_LIST.IDENTIFIER field in either Associated Location Extension Record or Associated Content Extension Record of the EDR container description file as shown in Table 9-1.
Table 9-1 TAP-to-EDR Mapping
| TAP Field | EDR Field | Comments |
Access Point Name NI |
GPRS Destination Camel Group:
GPRS Destination, other cases:
Access Point Name NI and Access Point Name OI are mapped to a single EDR field as concatenated and comma-separated items. |
Access Point Name OI |
Action Code |
DETAIL.ASS_GSMW_EXT.SS_PACKET.ACTION_CODE |
No comment. |
Actual Delivery Timestamp |
DETAIL.ASS_CONT_EXT.ACTUAL_DELIVERY_TIMESTAMP and DETAIL.ASS_CONT_EXT.ACT_DELIVERY_UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.ASS_CONT_EXT.ACTUAL_DELIVERY_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_CONT_EXT.ACT_DELIVERY_UTC_TIME_OFFSET. |
Advised Charge |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.ADVISED_CHARGE |
No comment. |
Advised Charge Currency |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.ADVISED_CHARGE_CURRENCY |
No comment. |
Age Of Location |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.AGE_OF_LOCATION |
No comment. |
Air Interface User Rate Requested |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.AIUR and DETAIL.ASS_GSMW_EXT.BS_PACKET.AIUR_REQUESTED |
No comment. |
Basic HSCSD Parameters |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST |
This is a block. |
Basic Service Used |
DETAIL.ASS_GSMW_EXT.BS_PACKET |
This is a block. |
Bearer Service Code |
DETAIL.BASIC_SERVICE |
No comment. |
Call Event Details Count |
TRAILER.TAP_TOTAL_NUMBER_OF_RECORDS |
No comment. |
Call Event Start Timestamp |
DETAIL.CHARGING_START_TIMESTAMP and DETAIL.UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.CHARGING_ START_TIMESTAMP and the UTC offset part is mapped to DETAIL.UTC_ TIME_OFFSET. |
Call Reference |
DETAIL.ASS_LOCN_EXT.CALL_REFERENCE |
For Location Services group, Call Reference is saved in the EDR field. |
Call Type Level 1 |
DETAIL.CONNECT_TYPE |
Call Type Level 1 and Call Type Level 2 are mapped to the EDR field as concatenated comma-separated items. |
Call Type Level 2 |
Call Type Level 3 |
DETAIL.CONNECT_SUB_TYPE |
No comment. |
Called Country Code |
DETAIL.CALLED_COUNTRY_CODE |
No comment. |
Called Number |
DETAIL.B_NUMBER & DETAIL.INTERN_B_NUMBER_ZONE & DETAIL.ASS_GSMW_EXT.DIALED_DIGITS |
The called number is the representation of the number dialled by the subscriber. |
Called Place |
DETAIL.DESCRIPTION |
Destination Group. The TAP fields Called Place and Called Region are mapped to the EDR field as concatenated comma-separated items. |
Called Region |
Camel Call Reference |
DETAIL.ASS_CAMEL_EXT.CAMEL_REFERENCE_NUMBER |
No comment. |
CAMEL Destination Number |
DETAIL.ASS_CAMEL_EXT.DEST_GSMW_NUMBER_ORIGINAL |
No comment. |
Camel Invocation Fee |
DETAIL.ASS_CAMEL_EXT.SERVER_TYPE_OF_NUMBER |
The charge for the CAMEL invocation after discounts have been deducted. |
Camel Initiated CF Indicator |
DETAIL.ASS_CAMEL_EXT.CAMEL_INITIATED_CF_INDICATOR |
No comment. |
Camel Modification |
DETAIL.ASS_CAMEL_EXT.CAMEL_MODIFICATION_LIST |
All Camel Modification fields present in Camel Modification List are mapped to the EDR field as concatenated comma-separated items. |
Camel Server Address |
DETAIL.ASS_CAMEL_EXT.SERVER_ADDRESS |
No comment. |
CAMEL Service Key |
DETAIL.ASS_CAMEL_EXT.SERVICE_KEY |
No comment. |
CAMEL Service Level |
DETAIL.ASS_CAMEL_EXT.SERVICE_LEVEL |
No comment. |
CAMEL Service Used |
DETAIL.ASS_CAMEL_EXT |
This is a block. |
Cause For Termination |
DETAIL.CALL_COMPLETION_INDICATOR |
If the TAP field value is less than 10, it is prefixed with 0. |
Cell Identity |
GPRS Network Location:
Network Location:
Present within groups:
Channel Coding Acceptable |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.CHANNEL_CODING_OK_LIST |
All channel coding fields present in Channel Coding Acceptable List are mapped to the EDR field as concatenated comma-separated items. |
Channel Coding Used |
HSCSD Parameter Modification:
Basic HSCSD Parameters:
Channel Coding Acceptable List:
No comment. |
Charge |
DETAIL.ASS_CBD.CP.CHARGED_AMOUNT_VALUE |
No comment. |
Charge Refund Indicator |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CHARGE_REFUND_INDICATOR |
No comment. |
Charge Type |
Taxation:
Charge Detail:
Chargeable Units |
DETAIL.ASS_CBD.CP.CHARGEABLE_QUANTITY_VALUE |
No comment. |
Charged Party Equipment |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.EQUIPMENT |
This is a block. |
Charged Party Home Identification |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.HOMEID_LIST |
This is a block. |
Charged Party ID Type |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.ID_LIST.TYPE |
No comment. |
Charged Party Identification |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.ID_LIST |
This is a block. |
Charged Party Identifier |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.ID_LIST.IDENTIFIER |
No comment. |
Charged Party Information |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO |
This is a block. |
Charged Party Location |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.LOCATION_LIST |
This is a block. |
Charged Party Status |
DETAIL.USAGE_DIRECTION |
No comment. |
Charged Units |
DETAIL.ASS_CBD.CP.ROUNDED_QUANTITY_VALUE |
No comment. |
Charging Characteristics |
DETAIL.USAGE_CLASS |
No comment. |
Charging ID |
DETAIL.ASS_GPRS_EXT.CHARGING_ID |
No comment. |
Charging Timestamp |
Supplementary Service Used:
Location Service Usage
Basic Service Used:
GPRS Call (Record type MSS, SCU, and VAS):
GPRS Service Usage Block:
GPRS Service Used Block:
CLIR Status Indicator |
Call Originator and SCU Basic Information:
Third Party Information:
Commission |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.COMMISSION |
No comment. |
Completion Timestamp |
DETAIL.CHARGING_END_TIMESTAMP |
No comment. |
Content Charging Point |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CONTENT_CHARGING_POINT |
No comment. |
Content Provider |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_LIST |
This is a block. |
Content Provider ID Type |
LCS SP Identification:
Content Provider:
Mandatory within groups:
Content Provider Identifier |
Content Provider:
Content Provider Name |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_NAME |
No comment. |
Content Service Used |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST |
This is a block. |
Content Transaction Code |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CONTENT_TRANSACTION_CODE |
No comment. |
Content Transaction Type |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CONTENT_TRANSACTION_TYPE |
No comment. |
CSE Information |
DETAIL.ASS_CAMEL_EXT.CSE_INFORMATION |
No comment. |
Customer ID Type |
Tracking Customer Identification:
Tracked Customer Identification:
Customer Identifier |
Data Volume Incoming |
GPRS Service Used:
Content Service Used:
Data Volume Outgoing |
GPRS Service Used:
Day Category |
DETAIL.ASS_CBD.CP.DAY_CODE |
No comment. |
Default Call Handling Indicator |
DETAIL.ASS_CAMEL_EXT.DEFAULT_CALL_HANDLING_INDICATOR |
No comment. |
Deposit Timestamp |
DETAIL.CHARGING_START_TIMESTAMP DETAIL.UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.CHARGING_START_TIMESTAMP and the UTC offset part is mapped to DETAIL.UTC_TIME_OFFSET. |
Destination Network |
DETAIL.DESTINATION_NETWORK |
No comment. |
Dialled Digits |
No comment. |
Discountable Amount |
DETAIL.ASS_ROAMING_EXT.DISCOUNTABLE_AMOUNT |
The actual part of the Charge/Tax/CAMEL Invocation Fee to which the Discount Value and Discount Rate (Code) relate. |
Discount Code |
DETAIL.ASS_CBD.CP.GRANTED_DISCOUNT_AMOUNT_VALUE |
No comment. |
Discount Value |
No comment. |
Distance Charge Band Code |
DETAIL.ZONE_DESCRIPTION |
No comment. |
Dual Bearer Service Code |
DETAIL.ASS_GSMW_EXT.BASIC_DUAL_SERVICE |
The TAP field is prefixed with 1 and stored in the EDR field. |
Dual Teleservice Code |
The TAP field is prefixed with 0 and stored in the EDR field. |
Earliest Call Timestamp |
TRAILER.FIRST_START_TIMESTAMP TRAILER.FIRST_CHARGING_UTC_TIME_OFFSET |
The timestamp part of this item is mapped to TRAILER.FIRST_START_TIMESTAMP and the UTC offset part is mapped to TRAILER.FIRST_CHARGING_UTC_TIME_OFFSET. |
Equipment ID |
Charged Party Equipment:
Tracking Customer Equipment:
Tracked Customer Equipment:
Equipment ID Type |
ESN |
DETAIL.ASS_GSMW_EXT.DEVICE_NUMBER |
No comment. |
Exchange Rate Code |
DETAIL.ASS_CBD.CP.EXCHANGE_RATE |
No comment. |
File Available Timestamp |
HEADER.TRANSMISSION_DATE |
No comment. |
File Creation Timestamp |
HEADER.CREATION_TIMESTAMP HEADER.UTC_TIME_OFFSET |
The timestamp part of this item is mapped to HEADER.CREATION_TIMESTAMP and the UTC offset part is mapped to HEADER.UTC_TIME_OFFSET. |
File Sequence Number |
HEADER.SEQUENCE_NUMBER HEADER.ORIGIN_SEQUENCE_NUMBER |
No comment. |
File Type Indicator |
HEADER.DATA_TYPE_INDICATOR |
No comment. |
Fixed Network User Rate |
DETAIL.ASS_GSMW_EXT.BS_PACKET.FNUR |
No comment. |
Fnur |
No comment. |
Fraud Monitor Indicator |
DETAIL.FRAUD_MONITOR_INDICATOR |
No comment. |
Geographical Location |
DETAIL.GEOGRAPHICAL_LOCATION |
The EDR field contains comma-separated tag-value pairs that indicate the geographical location of the serving network, serving BID, serving location description, longitude, and latitude. The tag values of the corresponding fields are as follows:
Example 1: If the TAP field values are as follows:
The value of DETAIL.GEOGRAPHICAL _LOCATION would be: 1,AIRTEL, 2,AIRBID, 3,Bangalore, 4,111,5,103 Example 2: If the TAP field values are as follows:
The value of DETAIL.GEOGRAPHICAL _LOCATION would be: 1,AIRTEL, 2,AIRBID, 5,103 |
Guaranteed Bit Rate |
DETAIL.ASS_ROAMING_EXT.GUARANTEED_BIT_RATE |
Describes the bitrate the UMTS bearer service must guarantee to the user or application for circuit switched UMTS. |
GPRS Destination |
GPRS Basic Call Information:
CAMEL Service Used:
Home Bid |
DETAIL.ASS_ROAMING_EXT.HOME_BID |
The Home BID (Billing Identifier) is a code identifying the home market area of the Chargeable Subscriber. |
Home ID Type |
Charged Party Home Identification:
Tracking Customer Home ID:
Tracked Customer Home ID:
Home Identifier |
Home Location Description |
DETAIL.ASS_ROAMING_EXT.HOMELOCATION_DESCRIPTION |
A text description giving the home market area of the Chargeable Subscriber. |
Horizontal Accuracy Delivered |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.H_ACCURACY_DELIVERED |
No comment. |
Horizontal Accuracy Requested |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.H_ACCURACY_REQUESTED |
No comment. |
HSCSD Indicator |
DETAIL.ASS_ROAMING_EXT.HSCSD_INDICATOR |
This indicator, set by the VPMN and passed to the Recipient, indicates that HSCSD has been used. |
HSCSD Parameter Modification |
This is a block. |
IMEI |
GPRS:
Present within the group:
IMSI |
GPRS:
Initiating Party |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.INITIATING_PARTY |
No comment. |
Internet Service Provider |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.ISP_LIST |
This is a block. |
ISP ID Type |
LCS SP Information:
Serving Parties Information:
No comment. |
ISP Identifier |
LCS SP Information:
No comment. |
Latest Call Timestamp |
TRAILER.LAST_START_TIMESTAMP TRAILER.LAST_CHARGING_UTC_TIME_OFFSET |
The timestamp part of this item is mapped to TRAILER.LAST_START_TIMESTAMP and the UTC offset part is mapped to TRAILER.LAST_CHARGING_UTC_TIME_OFFSET. |
LCS Request Timestamp |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQUEST_TIMESTAMP DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQ_UTC_OFFSET |
The timestamp part of this item is mapped to DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQUEST_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQ_UTC_OFFSET. |
LCS SP Identification |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ID_LIST |
This is a block. |
LCS SP Information |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO |
This is a block. |
LCS Transaction Status |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_TRANS_STATUS |
No comment. |
Local Currency |
DETAIL.WHOLESALE_CHARGED_AMOUNT_CURRENCY |
No comment. |
Location Area Code |
Network Location:
except where not supported by the network or the call does not terminate at the equipment. |
Location ID Type |
Charged Party Location:
Tracked Customer Location:
Tracking Customer Location:
Location Identifier |
Location Service Usage |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE |
This is a block. |
Maximum Bit Rate |
DETAIL.ASS_ROAMING_EXT.MAXIMUM_BIT_RATE |
The maximum bit rate available for circuit switched UMTS. |
Mdn |
DETAIL.ASS_ROAMING_EXT.MOBILE_DIR_NUMBER |
Mobile Directory Number. |
Message Description Code |
Message Description Code is not mapped to any EDR field. The DETAIL.DESCRIPTION field in the SCU Charge Type group contains description text with Message Description Code. |
Message Status |
Message Type |
DETAIL.QOS_USED |
No comment. |
Min |
DETAIL.ASS_ROAMING_EXT.MOBILE_ID_NUMBER |
Mobile Identification Number is an item which uniquely identifies the subscriber who has used the network. |
Modification Timestamp |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MODIFICATION_TIMESTAMP and DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MODIFICATION_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.UTC_TIME_OFFSET. |
MSISDN |
The TAP field is mapped to the following fields:
GPRS:
SCU:
MTC:
The EDR field is always prefixed with International Access Code. Present within groups:
Network Access Identifier |
DETAIL.ASS_ROAMING_EXT.NETWORKACCESS_IDENTIFIER |
The Network Access Identifier (NAI) is a username identifying a unique customer when generating WLAN CDRs. |
Network ID Type |
LCS SP Information:
No comment. |
Network Identifier |
LCS SP Information:
No comment. |
Network Init. PDP Context |
DETAIL.ASS_GPRS_EXT.NETWORK_INITIATED_PDP |
No comment. |
Network Type |
DETAIL.SOURCE_NETWORK_TYPE |
No comment. |
Number Of Channels |
No comment. |
Number Of Channels Used |
No comment. |
Object Type |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.OBJECT_TYPE |
No comment. |
Operator Spec Information |
DETAIL.OPERATOR_SPECIFIC_INFO [if Record type is record_GPRS] HEADER.OPERATOR_SPECIFIC_INFO [record_Header] TRAILER.OPERATOR_SPECIFIC_INFO [record_Trailer] |
This is an optional repeating field which contains operator specific information. |
Order Placed Timestamp |
DETAIL.ASS_CONT_EXT.ORDER_PLACED_TIMESTAMP DETAIL.ASS_CONT_EXT.ORDER_PLACED_UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.ASS_CONT_EXT.ORDER_PLACED_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_CONT_EXT.ORDER_PLACED_UTC_TIME_OFFSET. |
Originating Network |
DETAIL.SOURCE_NETWORK |
No comment. |
Paid Indicator |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.PAID_INDICATOR |
A flag which shows that the Charged Party has paid for the service. |
Partial Type Indicator |
DETAIL.LONG_DURATION_INDICATOR |
No comment. |
Payment Method |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.PAYMENT_METHOD |
No comment. |
PDP Address |
DETAIL.ASS_GPRS_EXT.PDP_ADDRESS |
No comment. |
PDP Context Start Timestamp |
DETAIL.ASS_GPRS_EXT.PDP_CONTEXT_START_TIMESTAMP DETAIL.ASS_GPRS_EXT.PDP_UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.ASS_GPRS_EXT.PDP_CONTEXT_START_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_GPRS_EXT.PDP_UTC_TIME_OFFSET. |
Positioning Method |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.POSITIONING_METHOD |
No comment. |
Priority Code |
DETAIL.QOS_REQUESTED |
No comment. |
QoS Delay |
QoS Requested:
QoS Used:
No comment. |
QoS Mean Throughput |
QoS Requested:
QoS Used:
No comment. |
QoS Peak Throughput |
QoS Requested:
QoS Used:
No comment. |
QoS Precedence |
QoS Requested:
QoS Used:
No comment. |
QoS Reliability |
QoS Requested:
QoS Used:
No comment. |
Radio Channel Requested |
No comment. |
Radio Channel Used |
No comment. |
RAP File Sequence Number |
Call Event Details:
Batch Control Information and Notification:
Must be present within groups:
Recipient |
HEADER.RECIPIENT |
No comment. |
Recording Entity Code |
Service Center Usage:
Location Service:
In the case of GPRS network usage, two or more occurrences must be present within GPRS Network Location. One occurrence must be of type 'GGSN' (see Recording Entity Type) and all other occurrences must be of type 'SGSN'. In the case of WLAN network usage, one occurrence must be present identifying the WLAN billing information recording entity. Network Location: Recording Entity Code is used to get corresponding Recording Entity ID. Recording Entity Code is not stored in any EDR field. Rec Entity Code Information: Recording Entity Code is used to get corresponding Recording Entity ID. Recording Entity Code is not stored in any EDR field. |
Release Version Number |
HEADER.RELEASE_VERSION |
No comment. |
Requested Delivery Timestamp |
DETAIL.ASS_CONT_EXT.REQUESTED_DELIVERY_TIMESTAMP DETAIL.ASS_CONT_EXT.REQ_DELIVERY_UTC_TIME_OFFSET |
The timestamp part of this item is mapped to DETAIL.ASS_CONT_EXT.REQUESTED_DELIVERY_TIMESTAMP, and the UTC offset part is mapped to DETAIL.ASS_CONT_EXT.REQ_DELIVERY_UTC_TIME_OFFSET. |
Requested Destination |
Requested Number:
Requested Public User ID:
The original destination to which the customer requested to be connected. |
Response Time |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.RESPONSE_TIME |
No comment. |
Response Time Category |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.RESPONSE_TIME_CATEGORY |
No comment. |
Sender |
HEADER.SENDER |
No comment. |
Serving Bid |
The Serving BID (Billing Identifier) is a code associated with a geographical area. |
Serving Location Description |
A text description giving the geographical location of the terminal equipment. |
Serving Network |
Serving Network:
Geographical Location:
Serving Network is stored in DETAIL.GEOGRAPHICAL_LOCATION along with other concatenated comma-separated tag-value pairs from Geographical Location. |
Serving Parties Information |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO |
This is a block. |
SIM Toolkit Indicator |
DETAIL.DISCOUNT_KEY |
No comment. |
SMS Destination Number |
DETAIL.ASS_ROAMING_EXT.SMS_DESTINATION_NUMBER |
The SMS Destination Number item contains the actual destination (intended recipient) of the SMS text message. |
SMS Originator |
DETAIL.ASS_ROAMING_EXT.SMS_ORIGINATOR |
The SMS Originator holds the identification of the actual sender of the SMS |
Specification Version Number |
HEADER.SPECIFICATION_VERSION_NUMBER |
No comment. |
Speech Version Requested |
DETAIL.ASS_GSMW_EXT.BS_PACKET.SPEECH_VERSION_REQUESTED |
No comment. |
Speech Version Used |
DETAIL.ASS_GSMW_EXT.BS_PACKET.SPEECH_VERSION_USED |
No comment. |
Supplementary Service Code |
DETAIL.ASS_GSMW_EXT.SS_PACKET.SS_EVENT |
No comment. |
Supplementary Service Parameters |
DETAIL.ASS_GSMW_EXT.SS_PACKET.SS_PARAMETERS |
No comment. |
Supplementary Service Used |
DETAIL.ASS_GSMW_EXT.SS_PACKET |
This is a block. |
TAP Decimal Places |
HEADER.TAP_DECIMAL_PLACES |
No comment. |
Tax Information |
DETAIL.ASS_CBD.TP |
This is a block. |
Tax Rate Code |
DETAIL.ASS_CBD.TP.TAX_CODE |
Tax Value |
DETAIL.WHOLESALE_CHARGED_TAX_VALUE DETAIL.ASS_CBD.TP.TAX_VALUE |
No comment. |
Taxable Amount |
DETAIL.ASS_CBD.TP.TAXABLE_AMOUNT |
No comment. |
TeleService Code |
DETAIL.BASIC_SERVICE DETAIL.ASS_GSMW_EXT.BS_PACKET.BASIC_SERVICE |
The EDR fields are prefixed with 0. |
Third Party Number |
DETAIL.C_NUMBER DETAIL.ASS_GSMW_EXT.SS_PACKET.THIRD_PARTY_NUMBER |
Present within the Third Party Information group where available. |
Time Band |
DETAIL.ASS_CBD.CP.TIME_INTERVAL_CODE |
No comment. |
Total Advised Charge |
TRAILER.ASS_ROAMING_EXT.TOTAL_ADVISEDCHARGE |
The sum of all the advised charges associated with the corresponding currency excluding those representing a refund. |
Total Advised Charge Refund |
TRAILER.ASS_ROAMING_EXT.TOTAL_ADVISEDCHARGE_REFUND |
The sum of all the advised charges associated with the corresponding currency representing a refund. |
Total Commission |
TRAILER.ASS_ROAMING_EXT.TOTAL_COMMISSION |
The sum of all the commissions associated with the corresponding currency excluding those representing a refund. |
Total Commission Refund |
TRAILER.ASS_ROAMING_EXT.TOTAL_COMMISSION_REFUND |
The sum of all the commissions associated with the corresponding currency representing a refund. |
Total Discount Refund |
TRAILER.ASS_ROAMING_EXT.TOTAL_DISCOUNT_REFUND |
The sum of the Discount Values plus each application of a Fixed Discount Value contained in the batch representing a refund. |
Total Tax Refund |
TRAILER.ASS_ROAMING_EXT.TOTAL_TAX_REFUND |
The sum of the Tax Values contained in the batch representing a refund. |
Total Transaction Duration |
Total Transaction Duration:
Total Call Event Duration:
No comment. |
Total Call Event Duration |
No comment. |
Total Charge |
TRAILER.TOTAL_CHARGE_VALUE_LIST |
This is a block. |
Total Charge Refund |
TRAILER.TOTAL_CHARGE_VALUE_LIST.TOTAL_CHARGE_REFUND |
No comment. |
Total Data Volume |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TOTAL_DATA_VOLUME |
No comment. |
Total Discount Value |
TRAILER.TAP_TOTAL_DISCOUNT_VALUE |
No comment. |
Total Tax Value |
TRAILER.TAP_TOTAL_TAX_VALUE |
No comment. |
Tracked Customer Equipment |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.EQUIPMENT |
This is a block. |
Tracked Customer Home Id |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.HOME_ID_LIST |
This is a block. |
Tracked Customer Identification |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.ID_LIST |
This is a block. |
Tracked Customer Information |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO |
This is a block. |
Tracked Customer Location |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.LOCATION_LIST |
This is a block. |
Tracking Customer Equipment |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.EQUIPMENT |
This is a block. |
Tracking Customer Home Id |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.HOME_ID_LIST |
This is a block. |
Tracking Customer Identification |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.ID_LIST |
This is a block. |
Tracking Customer Information |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO |
This is a block. |
Tracking Customer Location |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.LOCATION_LIST |
This is a block. |
Tracking Frequency |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.REQ_TRACKING_FREQUENCY DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.DEL_TRACKING_FREQUENCY |
No comment. |
Tracking Period |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.TRACKING_PERIOD DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.DEL_TRACKING_PERIOD |
No comment. |
Transaction Authorization Code |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_AUTH_CODE |
No comment. |
Transaction Description Suppression |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_DESCRIPTION_SUPP |
No comment. |
Transaction Detail Description |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_DETAIL_DESCRIPTION |
No comment. |
Transaction Identifier |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_IDENTIFIER |
No comment. |
Transaction Short Description |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_SHORT_DESCRIPTION |
No comment. |
DETAIL.ASS_CONT_EXT.TRANSACTION_STATUS |
No comment. |
Transfer Cut Off Timestamp |
HEADER.TRANSFER_CUTOFF_TIMESTAMP |
No comment. |
Transparency Indicator |
DETAIL.ASS_GSMW_EXT.BS_PACKET.TRANSPARENCY_INDICATOR |
No comment. |
UMTS Quality Of Service Requested |
DETAIL.ASS_GPRS_EXT.GS_PACKET.UMTS_QOS_REQUESTED |
The EDR field contains comma-separated tag-value pairs mapped from UMTS Quality Of Service Requested. The tag values of the corresponding fields are as follows:
UMTS Quality Of Service Used |
DETAIL.ASS_GPRS_EXT.GS_PACKET.UMTS_QOS_USED |
The EDR field contains comma-separated tag-value pairs mapped from UMTS Quality Of Service Used. The tag values of the corresponding fields are as follows:
User Protocol Indicator |
DETAIL.ASS_GSMW_EXT.BS_PACKET.USER_PROTOCOL_INDICATOR |
No comment. |
UTC Time Offset |
File Creation Timestamp:
Earliest Call Timestamp:
Mandatory within items:
Mandatory within UTC Time Offset Information. |
UTC Time Offset Code |
Actual Delivery Timestamp:
Order Placed Timestamp:
Requested Delivery Time Stamp:
LCS Request Timestamp:
Mandatory within UTC Time Offset Information. Mandatory within items:
In Date Time group, UTC Time Offset Code is only used to get corresponding UTC Time Offset, but is not mapped to any EDR field. |
Value Added Service Used |
DETAIL.ASS_VAS_EXT |
This is a block. |
VAS Code |
DETAIL.ASS_VAS_EXT.VAS_CODE DETAIL.ASS_GSMW_EXT.VAS_PRODUCT_CODE |
No comment. |
Vertical Accuracy Delivered |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.V_ACCURACY_DELIVERED |
No comment. |
Vertical Accuracy Requested |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.V_ACCURACY_REQUESTED |
No comment. |
EDR-to-TAP Mapping
When generating output TAP files, BRM maps EDR container fields to the fields in TAP output files. Table 9-2 lists the EDR and TAP field mappings that BRM uses when producing the output files.
Some of the fields in the EDR container file, such as DETAIL.UTC_TIME_OFFSET, can provide data to different fields in the output TAP file.
Table 9-2 EDR-to-TAP Mapping
| EDR Field | TAP Field | Comments |
DETAIL.A_NUMBER |
MSISDN |
No comment. |
This is a block. |
No comment. |
Comma-separated list. |
No comment. |
CSE Information |
No comment. |
DETAIL.ASS_CAMELEXT.DEFAULT_CALL_HANDLING_INDICATOR |
No comment. |
DETAIL.ASS_CAMEL_EXT.DEST_GPRS_APN_ADDRESS |
GPRS Destination |
The EDR field contains concatenated and comma-separated values of Access Point Name NI and Access Point Name OI. |
DETAIL.ASS_CAMEL_EXT.DEST_GPRS_PDP_REMOTE_ADDRESS |
Remote Pdp Address List |
DETAIL.ASS_CAMEL_EXT.DEST_GSMW_NUMBER |
Camel Destination Number |
International Access Code prefixes the EDR field. |
DETAIL.ASS_CAMEL_EXT.RECORD_NUMBER |
Tax Information List |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_CAMEL_EXT.MSC_ADDRESS |
Camel Msc Address |
No comment. |
CAMEL Service Key |
No comment. |
No comment. |
Chargeable Units |
No comment. |
Charge |
No comment. |
DETAIL.ASS_CBD.CP.CHARGING_START_TIMESTAMP DETAIL.UTC_TIME_OFFSET |
No comment. |
Day Category |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_CBD.CP.IMPACT_CATEGORY |
Charge Type |
No comment. |
DETAIL.ASS_CBD.CP.PRODUCTCODE_USED |
VAS:
Camel:
In Charge Detail Group, values that are mapped to the EDR field depend on the service type: VAS or Camel. |
Charged Units |
No comment. |
Time Band |
No comment. |
DETAIL.ASS_CBD.TP |
Tax Information |
This is a block. |
DETAIL.ASS_CBD.TP.CHARGE_TYPE |
Charge Type |
No comment. |
Tax Rate Code |
No comment. |
Tax Value |
No comment. |
Taxable Amount |
No comment. |
DETAIL.ASS_CONT_EXT.ACTUAL_DELIVERY_TIMESTAMP DETAIL.ASS_CONT_EXT.ACT_DELIVERY_UTC_TIME_OFFSET |
No comment. |
This is a block. |
This is a block. |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.EQUIPMENT.IDENTIFIER |
No comment. |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.EQUIPMENT.TYPE |
No comment. |
This is a block. |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.HOMEID_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.HOMEID_LIST.TYPE |
No comment. |
This is a block. |
No comment. |
No comment. |
This is a block. |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.LOCATION_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.LOCATION_LIST.TYPE |
No comment. |
No comment. |
DETAIL.ASS_CONT_EXT.RECORD_NUMBER |
Keeps the number of records of content Transaction. |
No comment. |
DETAIL.ASS_CONT_EXT.REQUESTED_DELIVERY_TIMESTAMP DETAIL.UTC_TIME_OFFSET |
No comment. |
This is a block. |
Advised Charge |
No comment. |
No comment. |
No comment. |
Commission |
No comment. |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.DATA_VOLUME_INCOMING |
No comment. |
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.DATA_VOLUME_OUTGOING |
No comment. |
Object Type |
No comment. |
Paid Indicator |
No comment. |
Payment Method |
No comment. |
Total Data Volume |
No comment. |
No comment. |
No comment. |
No comment. |
No comment. |
No comment. |
This is a block. |
This is a block. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.ISP_LIST.IDENTIFIER |
ISP Identifier |
No comment. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.ISP_LIST.TYPE |
ISP ID Type |
No comment. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.NETWORK_LIST |
Network |
This is a block. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.NETWORK_LIST.IDENTIFIER |
Serving Parties Info Block:
No comment. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.NETWORK_LIST.TYPE |
No comment. |
Content Provider |
This is a block. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_LIST.IDENTIFIER |
Content Provider Block:
No comment. |
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_LIST.TYPE |
No comment. |
No comment. |
DETAIL.ASS_CONT_EXT.TOTAL_TRANSACTION_DURATION |
No comment. |
No comment. |
DETAIL.ASS_GPRS_EXT.A_NUMBER_USER |
MSISDN |
No comment. |
DETAIL.ASS_GPRS_EXT.APN_ADDRESS |
GPRS Destination Group:
DETAIL.ASS_GPRS_EXT.CELL_ID |
Cell Identity |
No comment. |
Charging ID |
No comment. |
DETAIL.ASS_GPRS_EXT.DEVICE_NUMBER |
IMEI |
No comment. |
DETAIL.ASS_GPRS_EXT.GGSN_ADDRESS |
Recording Entity ID |
Rec Entity Code Element Group. Recording Entity Code is used to get corresponding Recording Entity ID. The obtained Recording Entity ID is stored in the EDR field. |
DETAIL.ASS_GPRS_EXT.GS_PACKET |
GPRS Service Used |
This is a block. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.CHARGING_START_TIMESTAMP DETAIL.ASS_GPRS_EXT.GS_PACKET.UTC_TIME_OFFSET |
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_DELAY |
QoS Requested:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_MEAN_THROUGHPUT |
QoS Requested:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_PEAK_THROUGHPUT |
QoS Requested:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_PRECEDENCE |
QoS Requested:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_RELIABILITY |
QoS Requested:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_DELAY |
QoS Used:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_MEAN_THROUGHPUT |
QoS Used:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_PEAK_THROUGHPUT |
QoS Used:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_PRECEDENCE |
QoS Used:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_RELIABILITY |
QoS Used:
No comment. |
The EDR field is mapped into concatenated and comma-separated tag-value pairs in UMTS Quality Of Service Requested. The tag values of the corresponding fields are as follows:
The EDR field is mapped into concatenated and comma-separated tag-value pairs in UMTS Quality Of Service Used. The tag values of the corresponding fields are as follows:
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.VOLUME_RECEIVED |
No comment. |
DETAIL.ASS_GPRS_EXT.GS_PACKET.VOLUME_SENT |
No comment. |
DETAIL.ASS_GPRS_EXT.LOCATION_AREA_INDICATOR |
No comment. |
Network Initiated PDP Context |
No comment. |
DETAIL.ASS_GPRS_EXT.ORIGINATING_SWITCH_IDENTIFICATION |
Rec Entity Code Element. Recording Entity Code is used to get corresponding Recording Entity ID. The Recording Entity ID is stored in the EDR field. |
PDP Address |
No comment. |
No comment. |
DETAIL.ASS_GPRS_EXT.PORT_NUMBER |
IMSI |
No comment. |
DETAIL.ASS_GPRS_EXT.SERVICE_USED_CHARGING_START_TIMESTAMP DETAIL.ASS_GPRS_EXT.SERVICE_USED_UTC_TIME_OFFSET |
GGPRS Service Used Block:
No comment. |
DETAIL.ASS_GPRS_EXT.SGSN_ADDRESS |
Rec Entity Code Element. Recording Entity Code is used to get corresponding Recording Entity ID. Recording Entity ID is stored in the EDR field. |
DETAIL.ASS_GPRS_EXT.SGSN_INFO_LIST.SGSN_ADDRESS DETAIL.ASS_GPRS_EXT.WLAN_ADDRESS |
Rec Entity Code Element. The Recording Entity code is used to get corresponding Recording Entity ID. The Recording Entity ID is stored in the EDR field. |
DETAIL.ASS_GSMW_EXT.A_NUMBER_USER |
No comment. |
This is a block. |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.CHARGING_START_TIMESTAMP DETAIL.ASS_GSMW_EXT.BS_PACKET.UTC_TIME_OFFSET |
No comment. |
No comment. |
The EDR field is mapped as a comma-separated list of channel coding. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.CHANNEL_CODING_USED |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.NUMBER_OF_CHANNELS |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.NUMBER_OF_CHANNELS_USED |
No comment. |
No comment. |
This is a block. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.AIUR |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.CHANNEL_CODING_USED |
No comment. |
Initiating Party |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MAX_NUMBER_OF_CHANNELS |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MODIFICATION_TIMESTAMP DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.UTC_TIME_OFFSET |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.NUMBER_OF_CHANNELS_USED |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.QOS_REQUESTED |
No comment. |
DETAIL.ASS_GSMW_EXT.BS_PACKET.QOS_USED |
No comment. |
No comment. |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_GSMW_EXT.CELL_ID |
Cell Identity |
No comment. |
IMEI or ESN |
No comment. |
No comment. |
DETAIL.ASS_GSMWEXT.LOCATION_AREA_INDICATOR |
No comment. |
DETAIL.ASS_GSMW_EXT.MS_CLASS_MARK |
Mobile Station Classmark |
No comment. |
DETAIL.ASS_GSMW_EXT.NUMBER_OF_SS_PACKETS |
No comment. |
DETAIL.ASS_GSMW_EXT.ORIGINATING_SWITCH_IDENTIFICATION |
No comment. |
DETAIL.ASS_GSMW_EXT.PORT_NUMBER |
IMSI |
No comment. |
DETAIL.ASS_GSMW_EXT.SERVING_NETWORK |
Serving Network |
No comment. |
This is a block. |
Supplementary Service Action Code |
No comment. |
DETAIL.ASS_GSMW_EXT.SS_PACKET.BASIC_SERVICE_CODE_LIST |
Basic Service Code SS |
No comment. |
DETAIL.ASS_GSMW_EXT.SS_PACKET.CLIR_INDICATOR |
No comment. |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_GSMW_EXT.SS_PACKET.UTC_TIME_OFFSET |
UTC Time Offset |
No comment. |
Call Reference |
No comment. |
This is a block. |
This is a block. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ID_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ID_LIST.TYPE |
No comment. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ISP_LIST |
This is a block. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ISP_LIST.IDENTIFIER |
LCS SP Information:
No comment. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ISP_LIST.TYPE |
LCS SP Information:
No comment. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.NETWORK_LIST.IDENTIFIER |
LCS SP Information:
No comment. |
DETAIL.ASS_LOCN_EXT.LCSSP_INFO.NETWORK_LIST.TYPE |
LCS SP Information:
No comment. |
DETAIL.ASS_LOCN_EXT.REC_ENTITY_CODE |
Location Service:
No comment. |
This is a block. |
Age Of Location |
No comment. |
No comment. |
Tracking Period |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQUEST_TIMESTAMP DETAIL.UTC_TIME_OFFSET |
No comment. |
No comment. |
No comment. |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.REQ_TRACKING_FREQUENCY |
No comment. |
Response Time |
No comment. |
No comment. |
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.TRACKING_PERIOD |
Tracking Period |
No comment. |
No comment. |
No comment. |
This is a block. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.EQUIPMENT.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.EQUIPMENT.TYPE |
No comment. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.HOME_ID_LIST.IDENTIFIER |
Tracked Customer Home Id:
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.HOME_ID_LIST.TYPE |
No comment. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.ID_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.ID_LIST.TYPE |
No comment. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.LOCATION_LIST.IDENTIFIER |
DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.LOCATION_LIST.TYPE |
This is a block. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.EQUIPMENT.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.EQUIPMENT.TYPE |
No comment. |
Tracking Customer Home ID |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.HOME_ID_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.HOME_ID_LIST.TYPE |
No comment. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.ID_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.ID_LIST.TYPE |
No comment. |
This is a block. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.LOCATION_LIST.IDENTIFIER |
No comment. |
DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.LOCATION_LIST.TYPE |
No comment. |
DETAIL.ASS_LTE_EXT.REQUESTEDNUMBER |
Requested Destination:
The EDR value is populated only for the Mobile Session (MO Voice Over LTE) events. |
DETAIL.ASS_LTE_EXT.REQUESTEDPUBLICUSERID |
DETAIL.ASS_ROAMING_EXT.CLIR_INDICATOR |
CLIR Indicator |
No comment. |
No comment. |
HSCSD Indicator |
No comment. |
Maximum Bit Rate |
No comment. |
Mobile Directory Number |
No comment. |
Mobile ID Number |
No comment. |
No comment. |
DETAIL.ASS_ROAMING_EXT.RAP_FILE_SEQ_NO |
No comment. |
No comment. |
SMS Originator |
No comment. |
Home Bid |
No comment. |
No comment. |
DETAIL.ASS_ROAMING_EXT.ISM_SIGNALLING_CONTEXT |
ISM Signalling Context |
No comment. |
This is a block. |
DETAIL.ASS_VAS_EXT.UTC_TIME_OFFSET |
UTC Time Offset |
No comment. |
DETAIL.ASS_VAS_EXT.VAS_CODE |
VAS Code |
No comment. |
DETAIL.ASS_VAS_EXT.VAS_DESC |
VAS Description |
No comment. |
DETAIL.ASS_VAS_EXT.VAS_SHORT_DESC |
VAS Short Description |
No comment. |
DETAIL.B_NUMBER |
No comment. |
DETAIL.C_NUMBER |
No comment. |
The EDR field is mapped to different TAP fields:
No comment. |
DETAIL.CHARGING_END_TIMESTAMP DETAIL.UTC_TIME_OFFSET |
When the EDR is mapped to Completion Timestamp, the DETAIL.UTC_TIME_OFFSET part is not stored. |
No comment. |
Call Type Level 3 |
No comment. |
Contents of the EDR field are mapped as concatenated items to Call Type Level 1 and Call Type Level 2. |
Destination:
SCU Charge Type:
No comment. |
No comment. |
DETAIL.DURATION |
No comment. |
No comment. |
Contents of the EDR field are mapped as comma-separated tag-value pairs. The tag values of the corresponding fields are as follows:
DETAIL.INTERN_A_NUMBER_ZONE |
MSISDN |
No comment. |
No comment. |
DETAIL.OPERATOR_SPECIFIC_INFO |
Operator Specific Information |
No comment. |
No comment. |
DETAIL.QOS_USED |
No comment. |
DETAIL.RAP_FILE_SEQ_NO |
No comment. |
No comment. |
Network Type |
No comment. |
GPRS Chargeable Subscriber:
SCU Basic Information, Call Originator:
No comment. |
No comment. |
No comment. |
DETAIL.VOLUME_RECEIVED |
No comment. |
DETAIL.VOLUME_SENT |
No comment. |
DETAIL.WHOLESALE_CHARGED_TAX_RATE |
Tax Rate Code |
No comment. |
DETAIL.WHOLESALE_CHARGED_TAX_VALUE |
Tax Value |
No comment. |
No comment. |
No comment. |
No comment. |
HEADER.OPERATOR_SPECIFIC_INFO |
No comment. |
HEADER.RAP_FILE_SEQ_NO |
No comment. |
HEADER.RECIPIENT |
Recipient |
No comment. |
HEADER.SENDER |
Sender |
No comment. |
HEADER.SEQUENCE_NUMBER |
No comment. |
No comment. |
No comment. |
HEADER.TRANSFER_CUTOFF_TIMESTAMP HEADER.UTC_TIME_OFFSET |
No comment. |
HEADER.TRANSMISSION_DATE HEADER.UTC_TIME_OFFSET |
No comment. |
No comment. |
TRAILER.OPERATOR_SPECIFIC_INFO |
No comment. |
No comment. |
No comment. |
Total Tax Value |
No comment. |
TRAILER.TOTAL_CHARGE_VALUE_LIST.CHARGE_TYPE |
Charge Type |
No comment. |
No comment. |
